dave1 Samba Member
Joined: September 12, 2003 Posts: 543 Location: United Kingdom, London
Posted: Tue Nov 12, 2024 10:13 am Post subject: 52 split beetle interior light |
A question on the interior light from the doors. Should the interior light work once the door is open or does it only work with ignition key in the 1st position.
The dome rear light works as it should from wiper switch.
Thanks all Dave |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 479 Location: Wisconsin
Posted: Tue Nov 12, 2024 12:48 pm Post subject: Re: 52 split beetle interior light |
per the wiring diagram, the power source is the same terminal as feeds the horn. so if the horn works with only key on, then its the same. _________________ Fritz Custom Products
Fritz Custom Products |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 839 Location: germany
Posted: Wed Nov 13, 2024 1:14 am Post subject: Re: 52 split beetle interior light |
| dave1 wrote: |
Thanks all Dave |
I guess, your electrical system is no more original. Is a ignition switch added or replaced?
Only Export models have the 2 door contact switches. If so, they are originally on terminal 30.
See owners manual. |
dave1 Samba Member
Posted: Wed Nov 13, 2024 4:17 am Post subject: Re: 52 split beetle interior light |
The electrical system is new but a repro vw loom kit which uses the original cloth type material was fitted. It is a deluxe model crotch cooler, originally from Sweden. It has been rebuilt utilising the original parts.
It have been rewired as Fritz has mentioned. As I have an early oval thought they may be the same, obviously not, Thank Fritz |
9secschwim Samba Member
Joined: January 09, 2005 Posts: 120 Location: Lakewood / San Jacinto
Posted: Thu Nov 14, 2024 12:38 pm Post subject: Re: 52 split beetle interior light |
| dave1 wrote: |
The dome light should illuminate with the key off. It is different from oval as in how it is wired. A split uses + positive power to complete the circuit and an oval uses - ground. Two wires from the wiper switch to each door switch should be + powered at all times. When the circuit is complete the other two wires from each door switch complete power to the terminal on the wiper switch which has the dome light wire attached. Oval switches work by completing the - ground circuit and the constant + is at the light itself. Split door switches have two terminals and later cars have one. |
