aquifer  Samba Member
Joined: August 30, 2021 Posts: 286 Location: Nebraska
Posted: Sat Nov 30, 2024 6:14 pm Post subject: 67 clutch Bowden tube wrongness |
Does anyone know where I can source a good quality Bowden tube that has a correct end? See the picture below. The “wrong” one came from WW.
At first, I installed several washers to compensate for the difference, but my OCD was freaking out. The new tube is the same overall length as the original one, but as you can see, the difference is significant. I much prefer to find a correct tube. I’m fine with inserting a washer to achieve the correct dip if needed, but the original one did not have a shim, and I don’t want to have 4 washers in there to compensate for the wrongness!
I would re-use my original one, but the tube at the other end is broken where the steel fitting is crimped on.
Any suggestions? Thanks again!
_________________ Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown). |
Cusser Samba Member
Joined: October 02, 2006 Posts: 32900 Location: Hot Arizona
Posted: Sun Dec 01, 2024 8:39 am Post subject: Re: 67 clutch Bowden tube wrongness |
aquifer wrote: |
At first, I installed several washers to compensate for the difference, but my OCD was freaking out. The new tube is the same overall length as the original one, but as you can see, the difference is significant. I much prefer to find a correct tube. I’m fine with inserting a washer to achieve the correct dip if needed, but the original one did not have a shim, and I don’t want to have 4 washers in there to compensate for the wrongness! |
If mine, I think I'd do the washer thing like you did !
But wait to see what folks more-experienced with your year of VW say.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16510 Location: North Florida, USA
Posted: Sun Dec 01, 2024 9:45 am Post subject: Re: 67 clutch Bowden tube wrongness |
I’m not clear what the actual problem is?
The replacement bowden tube is not an exact replica of OE VW part and you may need to use more/less washers to get the proper “bow” in the tube once installed? That is just normal. Even if you were able to find a NOS VW part it doesn't have to be exactly the same as the part you removed? Manufacturers frequently update parts and the newer parts may not fit exactly the same as the original. This is why you have adjustment specs so they can be adjusted to operate the same.
This clip from an older thread may help:
EZ Gruv wrote: |
Simma down y'all.
1. I added washers one at a time until my chattering stopped. This occurred last October when I had a cable snap (on the way into a VW show), and the bowden tube end broke during install of the new cable.
This still had chatter:
This does not:
2. I have cleaned it all since then. It looks much better now.  |
While I personally view the number of washers used above as excessive… you can’t argue that the purpose of the bowden tube is to allow the trans/engine to move independent of the chassis and not effect the clutch position. When adjusted incorrectly this results in clutch “chatter”. So adding washers until the chattering stops is the correct outcome. _________________ AshMan40
