CIP1 "German ATE master"
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Tue Jan 07, 2025 9:00 am    Post subject: CIP1 "German ATE master" Reply with quote
Doing a set of brakes on Quintilla the Westy. Purchased what I thought and was advertised as "Gernan Master Cylinder ATE" and paid the German price .It arrives...its in the blue ATE box...it says on the box In Espanol..Made in CHINA!!!WTF???? Yes this is bait and switch as its finest(or worse) SEnding this back and getting the real deal OG master . Wanted the fellow Sambaites to be ware of this fuckery
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Jan 07, 2025 9:17 am    Post subject: Re: CIP1 "German ATE master" Reply with quote
Depending on how they handle this, it may be better to post in the "Feedback" forum.
https://www.thesamba.com/vw/forum/viewtopic.php?t=51605&start=640
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
djfordmanjack
djfordmanjack is offline
PostPosted: Tue Jan 07, 2025 10:23 am    Post subject: Re: CIP1 "German ATE master" Reply with quote
Most probably it was not the vendors fault (maybe misinterpreting older info). When you order directly from ATE, you will most probably receive the same off shore produced item.
When ATE introduced their Classic Line a few years ago, they changed to foreign suppliers.
I used to buy (expensive) but great quality og German ATE parts for over 2 decades before that, and I was extremely disappointed to find out the sad news. Same goes for brake hoses, oval beetle wheel cylinders.... There may be other countries of origin mixed in, but probably hardly any German stuff anymore. asfaik. It's a pity they also stopped supply of most if not all master and wheel cyl repair kits and/or cups, seals and such.
The quality of the ATE parts has also become poor. The casting look ugly, isn't properly deburred and I found steel debris INSIDE factory fresh cylinders.
I try to avoid, but when I have to use modern ATE replacement parts, I generally disassemble and inspect/clean them before use.
54 Oval project
62 Dickholmer, Seeblau L360
