Push Rod Tube help needed
TheRookie
TheRookie is offline
PostPosted: Mon Mar 24, 2025 10:26 pm    Post subject: Push Rod Tube help needed Reply with quote
Hi Guys
I have a set of 1.25 Empi ratio rockers ,the ones with the adjustment screw on the Push rod end. The rocker shaft on these are offset at the bolt holes so they sit slightly lower .
Can I get away with stock tubes once geometry is done or is racing tubes recommended
Thanks
jeffrey8164
jeffrey8164 is offline
PostPosted: Tue Mar 25, 2025 5:40 am    Post subject: Re: Push Rod Tube help needed Reply with quote
I don’t know about those rockers personally but if it were me, I’d use the wide mouth tubes to stay on the safe side. Last thing I’d want to have to do is change them later.
Volkswagen!
(Compression 8.7:1)
stevemariott
stevemariott is offline
PostPosted: Tue Mar 25, 2025 7:37 am    Post subject: Re: Push Rod Tube help needed Reply with quote
I’m not familiar with those rocker shafts, but I ran similar 1.25 rockers on Scat solid rocker shafts for a little while (measured around 1.2 IIRC), and the pushrods showed signs of rubbing the Scat pushrod tubes I was running at the time.
I upgraded to CB pushrod tubes, and didn’t see any more rubbing on the pushrods.
1963 Manx copy
1968 Bus
