What sealant to use underneath 1500 head bolt washers
aircooled
aircooled is offline
PostPosted: Mon May 26, 2025 6:06 pm    Post subject: What sealant to use underneath 1500 head bolt washers Reply with quote
What is the best sealant to use underneath the head bolt washers on a stock 1967, with a 1500 engine?
67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon May 26, 2025 6:06 pm    Post subject: Re: What sealant to use underneath 1500 head bolt washers Reply with quote
Permatex Right Stuff
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
aircooled
PostPosted: Mon May 26, 2025 6:36 pm    Post subject: Re: What sealant to use underneath 1500 head bolt washers Reply with quote
Thank you Glenn.
Member of 67 Posse
aircooled
PostPosted: Mon May 26, 2025 7:02 pm    Post subject: Re: What sealant to use underneath 1500 head bolt washers Reply with quote
Glenn, can I also use the same sealant to seal the cylinders to the case? Is there any chance of this sealant coming loose under the washers and causing a blockage?
Member of 67 Posse
daveblank
daveblank is offline
PostPosted: Mon May 26, 2025 7:27 pm    Post subject: Re: What sealant to use underneath 1500 head bolt washers Reply with quote
Yes you can use it for the cylinders. Use it sparingly under the washers & you'll be fine.
slalombuggy
slalombuggy is offline
PostPosted: Mon May 26, 2025 8:31 pm    Post subject: Re: What sealant to use underneath 1500 head bolt washers Reply with quote
Put a small dab of right stuff on one washer and rib it against another one. You'll end up with a thin film of sealant on both washers which will be enough to seal them both.
Right Stuff is all I will use to seal cylinders to cases. IMO it's tge best sealant for the job
