DSVW Samba Member
Posted: Tue May 27, 2025 5:13 pm Post subject: Oil drain plug? |
Hi,
All original 1966 Bug here.
My car does not have an oil drain plug, but the manual shows one.
I have to remove all of the small bolts holding on the oil strainer cover and let the oil drain out on an angle....a real mess.
Is this something that I can add and why would my owner's manual show one?
Thanks. |
zerotofifty Samba Member
Posted: Tue May 27, 2025 6:44 pm Post subject: Re: Oil drain plug? |
DSVW wrote: |
Hi,
Thanks. |
Some sump plates have the drain bolt, others do not. It might be the sump plate was changed at one time.
You can buy a sump plate with a bolt.
I also like to place magnets on the sump plate, under the filter screen, this will capture ferrous metal bits from the oil.
Besure that the nuts used to hold the sump plate are acorn style (sealed ends) else oil will drip around the threads and leak. also be sure to use real copper gaskets under each of the nuts. You will want soft copper washers. BEWARE some steel washers with copper plating are sold for this application, These will allow leaks as they dont crush tio make a nice seal. the fake copper plated steel washers can be found out with a magnet test. The copper washers can be hard if they were rapidly cooled, you may soften them by heating to red hot on your stove top, and then allow to slow cool, this will make them soft and allow them to crush into a good seal. a soft copper washer will make a thud sound when dropped on a cement floor, and bounce very little. A copper washer that has not been slow cooled and is hard will ring and bounce when dropped on a cement floor.
Two paper washers are required for the sump plate, on goes on each side of the filter screen.
Note I usually drain the hot oil from the drain plug, then after all is drained, remove the sump plate to clean it, the filter screen and the magnets which I have added. Do this for the optimal oil change.
Have fun, Keep a Bugging. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Joined: April 27, 2002 Posts: 6722 Location: Pentwater, Michigan
Posted: Tue May 27, 2025 6:45 pm Post subject: Re: Oil drain plug? |
As you suspect, there should be a large center drain bolt in the center of your cover. You don’t ad one to your current cover you replace it with a cover that has the drain bolt. Any of the vendors on here will have one for you. _________________ Roads Scholar
Member# 2059
DSVW Samba Member
Posted: Tue May 27, 2025 7:03 pm Post subject: Re: Oil drain plug? |
Great info. Thanks! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Tue May 27, 2025 7:13 pm Post subject: Re: Oil drain plug? |
Gee whiz info, VW changed over to a sump plate without drain plug roughly around the introduction of the '73 model. Supposedly this was done because too many people were just draining and refilling without dropping the strainer to clean it... or maybe VW just wanted to save a few pennies per car produced. _________________ 1960 Ragtop w/Semaphores "Inga" |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6086 Location: 37.5N 77.1W
Posted: Wed May 28, 2025 7:51 am Post subject: Re: Oil drain plug? |
mukluk wrote: |
Gee whiz info, VW changed over to a sump plate without drain plug roughly around the introduction of the '73 model. Supposedly this was done because too many people were just draining and refilling without dropping the strainer to clean it... or maybe VW just wanted to save a few pennies per car produced. |
Weren't some cases made with a drain bolt beside the drain plate? Early engines....I think. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11111 Location: Huntington Beach, CA
Posted: Wed May 28, 2025 8:30 am Post subject: Re: Oil drain plug? |
runamoc wrote: |
mukluk wrote: |
Weren't some cases made with a drain bolt beside the drain plate? Early engines....I think. |
Yep! The later cases did not have the drain plug. Here is the early
Case that I rebuilt for the 54. Bottom view so you can see the hole, to the left of the sump plate opening, is for the drain plug.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
indianpeaksjoe Samba Member
Posted: Wed May 28, 2025 10:41 am Post subject: Re: Oil drain plug? |
Is that a wax paper case seal? _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35832 Location: Conejo Valley, CA
Posted: Wed May 28, 2025 10:48 am Post subject: Re: Oil drain plug? |
Cosmoline-soaked paper to prevent rust or chafing on the machined faces when shipping? _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79415 Location: Sneaking up behind you
Posted: Wed May 28, 2025 11:51 am Post subject: Re: Oil drain plug? |
I would not trust a chrome EMPI plate to not leak. If you want aftermarket look at one of the billet aluminum ones.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
splitjunkie Samba Member
Posted: Wed May 28, 2025 6:10 pm Post subject: Re: Oil drain plug? |
Only 25hp and 36hp cases had a drain plug on the case next to the sump plate. For '60, which was the last year for the 36hp in most markets, they added a drain plug to the sump plate and didn't tap the boss on the case for the drain plug. 1200, 1300, 1500 and 1600 never had a drain plug in the case. Only on the sump plate. As mukluk said, they removed the drain plug in '73 to encourage people to pull the sump and clean the strainer.
There really is no need for the drain plug when you get down to it. Just remove all but one of the sump nuts and loosen the remaining one enough to allow you to pop the sump plate loose to allow the oil to drain. Once drained, remove the remaining nut and pull the plate and the strainer. _________________ Chris
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4463 Location: viroqua wi.
Posted: Wed May 28, 2025 6:56 pm Post subject: Re: Oil drain plug? |
How does it make a mess? Sounds like you need a bigger pan. You should clean the screen every oil change, 2500 miles. |
Zundfolge1432  Samba Member
Posted: Thu May 29, 2025 8:57 am Post subject: Re: Oil drain plug? |
115.00 for a sump plate? Maybe for a show car, the kind with mirrors underneath the kind that get trailered to the shows. As for the chrome it would help to lightly abrade the sealing surface where the plate meets the gasket. Pay attention to the magnetic plugs sometimes they can ride high an restrict the oil suction especially if the strainer is missing.
Here’s an oldtimer not pretty but it works. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 239 Location: Eastern north carolina
Posted: Fri May 30, 2025 4:04 pm Post subject: Re: Oil drain plug? |
I'm sure one of the vendors on here could fix you up with an original German one with drain bolt. I have always changed oil every 2 to 3 thousand miles and found that I only needed to drop the screen every 2 or 3 oil changes as it was very clean. Good luck |
Glenn  Mr. 010
Posted: Fri May 30, 2025 4:27 pm Post subject: Re: Oil drain plug? |
1973 and newer didn't have a drain bolt from the factory _________________ Glenn
Member #1009
#BlueSquare
my3bugs Samba Member
Joined: June 18, 2003 Posts: 825 Location: Moreno Valley
Posted: Fri May 30, 2025 4:33 pm Post subject: Re: Oil drain plug? |
i have a magnetic drain plug in a 1600 motor in the drain plate . can you just add another magnet or two to the drain plate ? like stick one of these new small rare earth magnets to the plate ? would it just hold its self ? of would it need to be glued ? is just the one more than enough ?
i have seen a thread showing how VW made a magnet to fit some of these filter screens . |
Posted: Fri May 30, 2025 4:51 pm Post subject: Re: Oil drain plug? |
my3bugs wrote: |
I stick three or four magnets to the plate, under the filter screen. These magnets are roughly 3/16 th x 3/4 th x 7/8 th of an inch. No glue needed, they stay in place. _________________ Sorry About That Chief.
Words to live by. |
Posted: Fri May 30, 2025 4:56 pm Post subject: Re: Oil drain plug? |
thanks for sharing ZERO !!! ill prolly add some next time , but i have these small round super strong ones im thinking of , like the ones used in name tags . |
