At what point do you consider an engine rebuild?
Jason Rolfe
Jason Rolfe is offline
PostPosted: Wed Jul 02, 2025 8:32 pm    Post subject: At what point do you consider an engine rebuild? Reply with quote
The basics:
I'm at a point in my engine's life (2.2 rebuild done by Wolfsberg in Seattle RIP about 14 years ago, with 110,000 miles on it), where I'm wondering if it might be worth considering a rebuild.
Top end has been rebuilt twice in that period, most recently a few years ago when, upon noticing some coolant leakage at one of the head gaskets, I decided to replace the heads (there were cracks between valves).
The van runs pretty well these days, overall. In fact, just got done with a 2 week, 1,000 mile+ road trip through BC/Alberta and it did great. But boy, it really seems to go through oil, and there are no obvious leaks. I know that a leak down and/or compression test will tell me more, and I plan to do both this summer just to see what I find out.
In any case, as I said, considering engine age/mileage, at what I'm pretty sure is more than 1 qt/1,000 miles oil consumption, is it worthwhile to think about taking on an engine rebuild this winter?
What other signs of wear can I look for? Fouled plugs? Other?
Just trying to stay ahead of things and avoid a complete failure at a more inopportune time.
Thanks for any tips/advice.
zerotofifty
zerotofifty is offline
PostPosted: Wed Jul 02, 2025 8:44 pm    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
compression and or leak down test, plus oil pressure test are good to do. best to install a permenant oil pressure gage so you can detect oil shortage seeing as you indicate she burns oil. Mine drinks oil if I keep here topped up to the full line on the dip stick, but consumption drops greatly is I leave the oil level a bit below half way between full and low marks
Two head jobs do to coolant leaks! Consider doing something different next time, she should not have such recurring leaks. Are you using antifreeze, minimum 50%, AND doing every two years flush and renewal of antifreeze?
Anyway, your job is to do the compression and or leak down test, and oil pressure test, do the oil pressure test fully warmed up at highway speed. a cold test in the driveway is no as helpful.
save the worry for after you do the tests, it may be fine.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Jason Rolfe
PostPosted: Wed Jul 02, 2025 8:56 pm    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Hey thanks for the reply.
Should have mentioned I do have a permanent oil gauge in the cockpit. So I am able to keep an eye on things. The typical sign I use to check the oil is when I'm turning one way or the other and the pressure drops and I get a blink in the oil light.
At highway speeds (55-60 mph in 4th), the pressure seems to hover in the 20-24 psi zone. At idle, psi sits between 0-5.
Re: heads. Prior to that last head replacement, I actually had let the coolant change go overdue for too long. A stupid mistake. But since then I've stayed on schedule with the correct coolant (due for a flush in September). I ended up replacing the heads after discovering the cracks. I don't remember the reason for the previous head replacement, though I'm sure I have the receipt for it (the first one was done by a mechanic).
In any case, leak down test and compression are on the to-do list.
vanis13
vanis13 is offline
PostPosted: Wed Jul 02, 2025 9:07 pm    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
1) has that changed over your ownership time (and how long is that time?)
2) double check oil pressure with a known good gauge. Just now working on a van that the dash gauge is 1/2 PSI of the test gauge....and comparing against other gauges out of curiosity the readings are al over the place on the diff gauges.
Jason Rolfe
PostPosted: Wed Jul 02, 2025 9:16 pm    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
I've owned the van for about 16 years, but only had the dash gauge for the past 2 or 3 years. It's the Van Cafe Pressure Gauge kit, and these readings have been consistent since I've had the gauge.
But, could check that against another gauge, just to see if there's any discrepancy.
dhaavers
dhaavers is offline
PostPosted: Wed Jul 02, 2025 9:44 pm    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Jason Rolfe wrote:
…At highway speeds (55-60 mph in 4th), the pressure seems to hover in the 20-24 psi zone. At idle, psi sits between 0-5…
For a stock 2.1 engine, those numbers would mean it’s time to stop driving & plan your rebuild now. That’s what I decided last fall with my stock 2.1 giving identical numbers at 217k miles. No idea how that compares to a “Wolfsburg 2.2” rebuild. Did Wolfsburg use the trouble-prone 2.1 stretch rod bolts on the rebuild, or something different? That would be cool to know…probably critical, in fact.
Good, healthy OP numbers are more like 8-10psi at hot idle and about 10psi additional for each 1000rpm above idle. At “highway speed” in 4th gear you’d like to be in the ballpark of about 35psi. Yes, get a known good gauge on there, drive it until it’s hot (minimum 15-20 minutes on the highway) & report back.
Oil level-wise, where do you run on the dipstick? The stock 2.1 is arguably happier in the bottom half of the dipstick. Running more than that typically just burns off or leaks out…depending on your level & with no reported leaks, yours may simply be burning off, with no major downside other than the cost of excess oil.
- Dave
"The WonderVan"
MarkWard
MarkWard is offline
PostPosted: Thu Jul 03, 2025 4:31 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Pressure reported does sound low. That the pressure drops and the light comes on is more concerning. A recent thread had similar symptoms. In that case it was determined by the owner the oil level was too low. VW stated a qt in 1000 miles was acceptable. I don’t agree.
Jason Rolfe
PostPosted: Thu Jul 03, 2025 6:02 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
- Dave
Thanks Dave. Yeah, I've always thought those numbers seemed low. But they've been consistent, and the van drives well, so I've mainly crossed my fingers and hoped for the best. But hope can only get ya so far.
No idea about the stretch rod bolts. Wolfsberg was known for doing excellent rebuilds, so I would guess they wouldn't have used a known bad part.
As for oil level, I'm typically filling until I just see it show up at the lower indicator mark or thereabouts. I'll check back over my notes from the recent road trip and try to give a more thorough accounting of oil use.
In any case, much appreciated.
Jason Rolfe
PostPosted: Thu Jul 03, 2025 6:04 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Any recommendations on a good gauge to buy? I'm wary of using a loaner from the FLAPS.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jul 03, 2025 6:24 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
More oil usage than 1qt/1,000 and low oil pressure. It's past time for a rebuild. 110,000 on the motor with two times doing the top end is terrible cost/unreliability.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Thu Jul 03, 2025 7:00 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
My experience with all my VWs (except my EuroVan Westy) has been to find a spare engine to have on hand. There is big business in engine transplants, going away from the WBX in favor of a Subaru, or TDI, etc. and those that are getting transplants done are not usually doing it because of low OP, consumption, etc, but just wanting more gogo juice, thus the WBX is fine, and sometimes free for the taking, or at a very reasonable price. And, since I have a few spare engines, I am not as worried about my low OP at hot idle, if my gauge was graduated in the 0-10 range better, I could actually have a number for you, but it goes 0-10-20-30-40 and so on, and I can tell very clearly hot OP is under half way from 0 to 10 at hot idle. BUT, I think the wire I ran from the dash to the sender in the engine compartment might be the wrong kind to be accurate anyway, so who knows why I've gotten nearly 80K miles running it like this. Just saying, there are plenty of ideas out there. I agree though, throwing a rod would not be much fun.
dhaavers has done a great thing on his approach to watching his OP closely, and getting a fantastic build from a really great shop, so be sure to chat him up on further thoughts, since he has just gone through something very similar to your situation. I am not sure how the shop he used would view your 'core' though, I think they don't much go for anything that has been taken apart/rebuilt before.
-bobby
Jason Rolfe
PostPosted: Thu Jul 03, 2025 9:03 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
I really appreciate the insight and feedback. It's more or less confirming suspicions I've had, though I do still wonder about a few things.
If the engine is worn to the point of needing a rebuild immediately, would there be other signs like poor gas mileage and/or performance.
I get relatively good mileage (I think): typically around 18 mpg average.
And the van runs well as far as I can tell. Accelerates strongly on the freeway when I want to pass someone, doesn't struggle too much up hills (aside from the steepest ones). I know some of this is somewhat subjective.
But, of course, the oil consumption is a big question mark, as is oil pressure.
I'm going to try to get compression and oil pressure tested this weekend and will report back with some numbers.
In the meantime, happy to hear any add'l thoughts.
And, for what it's worth, my mention of "top end rebuild" only included replacing heads; didn't mess with pistons/cylinders. Just want to avoid any confusion on that front.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jul 03, 2025 9:10 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Not necessarily. An engine can toss a rod without any prior warning other than low oil pressure. Full power, full fuel economy, and then BAM!
You usually get some knocking right beforehand, though.
You also already have the 'other signs' of high oil consumption and low oil pressure. I would also add that having a catastrophic failure like a tossed rod renders your core un-rebuildable. Also having the engine lock up suddenly while underway can sometimes damage the transaxle as well. Usually the trans is fine, but not always.
dhaavers
dhaavers is offline
PostPosted: Thu Jul 03, 2025 10:08 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Classic literature here…if you haven’t yet, read this NOW:
http://volksweb.relitech.com/21rodbrg.htm
Bottom line: Do ya feel lucky?
Evil or Very Mad
- Dave
"The WonderVan"
Ahwahnee
Ahwahnee is offline
PostPosted: Thu Jul 03, 2025 10:13 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Jason Rolfe wrote:
...At highway speeds (55-60 mph in 4th), the pressure seems to hover in the 20-24 psi zone...
On a warm day, been on the road for about 3 hours, 83,000 miles since the engine was rebuilt...
Your numbers suggest to me that the end is near.
Jason Rolfe
PostPosted: Thu Jul 03, 2025 10:30 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Evil or Very Mad
- Dave
I feel like I've probably used up most of my luck by now. Confused
Jason Rolfe
PostPosted: Thu Jul 03, 2025 10:35 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Another (disheartening) data point:
Looks like my oil consumption was even more drastic than I thought going back over my notes from the trip.
I did an oil change before our recent trip. Put 4 qts of 10w-60 in. (I'd been running 20w-50 for years but thought I'd try a different oil out to see if I noticed any difference in pressure, etc).
Road trip was about 2,500 miles. I put 4 quarts in over the course of the trip.
Just went out to recheck the oil, and it took 2 quarts to bring the level up to the bottom mark on the stick.
So that's 10 quarts in the last 2,500 miles. Embarassed
Oof.
Jason Rolfe
PostPosted: Thu Jul 03, 2025 10:37 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Yeah, that's what I really don't want: catastrophic failure while underway. I try to take good care of this old gal, and we've been lucky to never have anything serious happen on a trip. Looks like I'm headed for a rebuild.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jul 03, 2025 11:19 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
You shouldn't count the 4 qts of oil from the oil change as 'oil usage'. However, you still added 6 quarts of oil over 2,500 miles in order to maintain that initial level and that oil usage is very excessive IMO (more than 2X what I would consider the limit of acceptable), so it doesn't really change the situation.
Jason Rolfe
PostPosted: Thu Jul 03, 2025 11:44 am    Post subject: Re: At what point do you consider an engine rebuild? Reply with quote
Yeah, 2500 miles/6 quarts=less than ideal.
I guess my next question would be: should I even bother going through with compression and leak down tests, and oil pressure check with a different gauge?
Or should I just pull the engine and get a closer look at things, since it would appear the engine probably needs to come out anyway?
Put another way--is there any chance that further testing will reveal a simpler fix/solution?
