Redbarnresto Samba Member
Posted: Wed Jul 09, 2025 3:53 am Post subject: Autostick Experts Needed; no gears after reverse? |
I’ve got an issue with a ‘74 autostick (which has the Park function) that’s got me wanting to pull my hair out. It shifts through the gears okay (usually) but there seems to be a specific issue with when you select reverse, you then can’t select other gears, as if the clutch is no longer disengaging. Sometimes you can’t even get it out of reverse. Now, why in the wide world of sports selecting reverse causes this issue, I can’t guess. What’s equally weird is that if you put it in park for a few seconds, it’ll usually reset somehow and you can then find your gears. I’m bamboozled by it, so any input would be greatly appreciated. Naturally I’ve cleaned and adjusted the contacts in the shift lever and did all the other checks and adjustments listed in the Bentley, at least to the extent I was able to understand them. I have some questions about that, as the Bentley is surprisingly vague and nondescript.
1) Unless I missed it, the Bentley makes no mention of the neutral safety switch except for that it’s in the electrical diagram. As near as I can tell, when the car is in neutral it first of all completes the starter circuit, obviously, but there’s a secondary function in which it grounds the control valve so that the clutch is always disengaged when the car is in neutral. Is this correct? I’ve done a test and this is what is occurring on this car, at any rate.
2) I’ve tried to adjust the clutch but am very confused by the instructions given. It says to pull the pushrod out from the servo and if the adjustable collar is more than 4mm away from the edge of the bracket, to loosen the lock nut and spin the collar 6.5mm away from it on the eyelet end. Only thing that’s really throwing me here is that this collar is like a tie rod, with reverse threads on the eyelet end. When I thread it away from the locknut I make it longer on both sides, which results in it now being vastly further away on the opposite end than it was to begin with as opposed to closer. I can’t think what I’m missing here. They ostensibly want the gap between the collar and the bracket to be 4mm at the most, not 4mm at the least, yet all you do when following this procedure is make it bigger and bigger. I’ve alternatively followed the instructions from the section describing how to do a preliminary adjustment of the rod and clutch arm, and the results are wildly different. I’m at a loss on what I’m missing and how these two procedures from the same manual can yield such different results.
Okay that’s all for now. I greatly appreciate any input at all.
Dan _________________ Red Barn Restorations |
Posted: Wed Jul 09, 2025 7:25 am Post subject: Re: Autostick Experts Needed; no gears after reverse? |
Update: I found a couple holes in the servo diaphragm. I’m surprised it worked at all, but they were pretty small holes so I guess that explains the intermittent nature. Still odd that it seemed to work great until I put it in reverse, and I admit I’m a little unsure if I think replacing the diaphragm will actually cure the issue. It certainly isn’t helping things, though, so naturally I’ll start there.
I’m still curious to hear input into my questions if anyone could shine some light on that. Thanks!
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13519 Location: West Coast, USA
Posted: Wed Jul 09, 2025 11:55 am Post subject: Re: Autostick Experts Needed; no gears after reverse? |
Very cool. Never seen one, and just reading that part of Bentley for the first time…
When you are “stuck” in reverse, does the shifter still allow movement? Or does it feel like you have movement but the transmission is stuck in reverse?
IF your clutch system is perfect, it sounds like a shift interlock pin/spring issue, but that’s really rare unless it was built with issues.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Wed Jul 09, 2025 12:57 pm Post subject: Re: Autostick Experts Needed; no gears after reverse? |
No the gear lever won’t move, presumably because the clutch isn’t disengaging. Feels just the same as trying to select a gear in a manual without stepping on the clutch pedal.
sb001 Samba Member
Joined: May 19, 2011 Posts: 10463 Location: NW Arkansas
Posted: Fri Jul 11, 2025 11:36 am Post subject: Re: Autostick Experts Needed; no gears after reverse? |
Redbarnresto wrote: |
I’ve got an issue with a ‘74 autostick (which has the Park function) that’s got me wanting to pull my hair out. It shifts through the gears okay (usually) but there seems to be a specific issue with when you select reverse, you then can’t select other gears, as if the clutch is no longer disengaging. Sometimes you can’t even get it out of reverse. Now, why in the wide world of sports selecting reverse causes this issue, I can’t guess. What’s equally weird is that if you put it in park for a few seconds, it’ll usually reset somehow and you can then find your gears. I’m bamboozled by it, so any input would be greatly appreciated. Naturally I’ve cleaned and adjusted the contacts in the shift lever and did all the other checks and adjustments listed in the Bentley, at least to the extent I was able to understand them. I have some questions about that, as the Bentley is surprisingly vague and nondescript. |
This issue sounds distinctly gear shit lever related to me-- either the contacts in the base of the shifter are not adjusted quite correctly, or (I suppose) it's possible that you have the wrong or broken shifter lockout plate at the base of the shifter, or maybe a loose autostick shift rod coupler (or a missing spring there) that is allowing the shifter to be out of place when in reverse, causing the contacts to keep in contact with each other and not allowing the clutch to disengage when in reverse. (Just spitballing here.)
The stop plate for an autostick looks like this (#17 in the diagram below):
Note it has a diagonal "ridge" at about the 4:00 position when mounted to the transmission tunnel.
Make sure yours is the correct stop plate and that it is oriented the right way.
You might also check the shift coupling-- in the back under the rear seat, you will see an oval-shaped panel held on by a screw. Remove this screw and the panel and take a look inside- you will see the sort of u-joint coupling where the shift rod coming out of the transmission case attaches to the shift rod that goes up to the front of the car. On the left (driver's) side of this coupling there is supposed to be a spring (#18 in the diagram below.) It hooks on one end to a tab on the transmission tunnel under the coupling, and the other end hooks into the hole on the flat end of the connecting bolt that runs through the coupling:
If you don't have that spring in place your gear shifter can feel very sloppy especially in neutral, that spring provides tension on the shift rod to the front of the car to keep it properly positioned (in neutral the gear lever should actually look like it is leaning to the right--passenger side-- just a bit, that spring holds it in this position.)
1) Unless I missed it, the Bentley makes no mention of the neutral safety switch except for that it’s in the electrical diagram. As near as I can tell, when the car is in neutral it first of all completes the starter circuit, obviously, but there’s a secondary function in which it grounds the control valve so that the clutch is always disengaged when the car is in neutral. Is this correct? I’ve done a test and this is what is occurring on this car, at any rate. |
This is correct.
Dan |
The threaded rod sticking out of the diaphragm is a totally separate rod from the eyelet end, and the adjuster sleeve acts as a coupler between the two:
On the diaphragm end, the threads are normal. So if you loosen the locknut on the eyelet end, you should be able to turn the adjuster sleeve normally (righty-tighty) and it should thread inward toward the diaphragm. However, since the threads on the eyelet end are reversed, when you do this, you might actually end up tightening the locknut back up against that end of the adjuster sleeve. So you might have to actually back off the locknut more than just a little, to give ample space to thread the adjuster sleeve in toward the diaphragm without the locknut tightening back down.
If you want to get a little further into the weeds, you can actually drive the hinge pin out that holds the eyelet end to the clutch arm, and completely remove the diaphragm canister and adjust all this off the car, then bolt everything back up. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Fri Jul 11, 2025 6:05 pm Post subject: Re: Autostick Experts Needed; no gears after reverse? |
I was wondering if you’d chime in, sir, as you seem to be the autostick expert around these parts. Although I’ll share with you one thing which is that the ones with the park function actually use the exact same lock out plate as a manual, as opposed to the unusual one the early autosticks had like you’ve shown (the Bentley makes no mention of this, however, but it’s true).
I ordered a new servo diaphragm and got a shift rod bushing and new coupler as well, for good measure. I agree that it could be related to all that.
I understand how it’s possible to adjust the rod to 4mm if you want but the instructions they give you in the manual make no sense at all. I’d really love for someone to explain it. It says to turn the adjustable sleeve 6.5mm away from the locknut at the eyelet end, which, again, only causes the distance between the sleeve and the servo bracket to grow considerably larger on the servo end. Which is funny, because if you check your work afterwards, you’ll find the sleeve is still greater than 4mm from the bracket, causing you to make the adjustment yet again, with this cycle continuing indefinitely until the sleeve finally falls off because the threads have run out haha. It’s truly a head scratcher and I can’t fathom what they’re on about. Nevermind the fact that the distance between the bracket and the sleeve being 4mm is completely irrelevant, because how long the entire assembly is overall is what matters. In other words, I can remove the eyelet from the clutch arm and thread it in or out of the sleeve on just that end however I please, making a 4mm measurement on the servo end irrelevant overall. They’re presumably assuming it was all set at the factory, and therefore a 4mm measurement would be consistent with assumptions of the overall length, but why assume it hasn’t been altered? Why wouldn’t they just give us a measurement from the bracket to the center of the eyelet to shoot for instead? Again, I’d love to talk to anyone that can really explain this (I’m guessing no one can).
Okay, rant over. I’m just pretty bamboozled by this because it really is the strangest thing I’ve ever seen in the Bentley. All that said, I did adjust to the specs listed in a later section. This being 8.5mm from the beginning of the threads on the servo rod to the beginning of the adjustable sleeve, and 77 to the center of the eyelet.
I’ll let you know how things go when I have the new parts in. I appreciate the input!
sb001 Samba Member
Posted: Fri Jul 11, 2025 8:02 pm Post subject: Re: Autostick Experts Needed; no gears after reverse? |
I agree that the way the servo rod adjustment is explained is well, just wrong. It specifically states to "barely loosen the adjusting sleeve's locknut" and then "turn the adjuster sleeve 5 to 5-1/2 turns away from the locknut." But because of the reverse threads on that end, you would have to turn the adjuster sleeve to the left instead of the right, which - due to the threads being normal on the diaphragm side - would cause the adjuster sleeve to move farther away from the diaphragm bracket, as you mentioned.
I agree it would have been way easier for them to have just given a distance measurement from bracket to eyelet, especially since it's this measurement that really needs to remain consistent in order to compensate for clutch wear and ensure the arm still travels the correct distance for the clutch to engage.
Anyway, keep us posted on whatever you find out. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Tue Jul 22, 2025 8:12 am Post subject: Re: Autostick Experts Needed; no gears after reverse? |
I keep forgetting to update, but here’s the latest.
I replaced the servo diaphragm, the shift rod bushing (which was completely missing), and the shift coupler (which was pretty worn). I adjusted the servo arm to the specs given in section of the manual stating to adjust the sleeve 8.5mm from the start of the threads on the servo and 77mm from the threads to the center of the eyelet. Everything works and shifts like the day it was made and I can only assume it’s one of the better running and driving autosticks on the road anywhere at this point. Just a pleasure to drive and doesn’t miss a beat. I changed three things at once, so I can’t say which was the smoking gun, but I honestly think it was a fairly equal combination of all of them.
Why it worked just fine until it was put in reverse, and why putting it in park seemed to reset things, I can’t guess. Pretty strange phenomenon, but what isn’t when working on these olds cars.
sb001 Samba Member
Posted: Thu Jul 24, 2025 12:41 pm Post subject: Re: Autostick Experts Needed; no gears after reverse? |
Good to hear!
See, most autostick related issues are fairly easy and inexpensive to solve-- contrary to what the haters would have you believe. And that internal autostick clutch will last for decades. Oh how I feel for the poor schmucks who changed out to a 4 speed and have to constantly adjust the clutch cable, replace the worn clutch disc, try to keep the thing running in stop and go traffic, etc. _________________ I'm the humblest guy on this board.
1600 SP engine
