Murt Samba Member
Joined: October 01, 2017 Posts: 594 Location: Kent, England
Posted: Mon Jul 28, 2025 6:59 am Post subject: Help. How to remove this Stud ?? |
Morning Gents
I sure don't think I'll be be building a 2490cc anyday soon but I need some basic advice please ?
Started my engine tear down, and everything was going really really well. I'm really pleased with the case overall, and will definitely be using it to build my next engine.
I have a problem though. Deep Stud #3 will not let go. I can see evidence I think, that it was lathered in blue Loctite ? All 15 of the others came out very easily.
I am absolutely frightened to death of snapping it in the case and actually whilst on here typing I'm getting a text from a friend who's saying to heat the case really really hot, and use about 3 or 4 sets of vice grips on the unthreaded part and try that way ? As I said anyone had to deal with something like this ? I will try and borrow some sets, as I only have one set of vice grips myself, and I do have plenty of Mapp gas, but not sure how hot the case will stand ??
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23291 Location: Oklahoma City
Posted: Mon Jul 28, 2025 7:11 am Post subject: Re: Help. How to remove this Stud ?? |
Acetone softens it. Dribble some down onto the thread joint area and keep doing if. Keep it wet for a while.
Then get a propane torch and heat the thread area in the case from the outside. Don't get crazy. You want about 500° F maximum. Turn the torch off, give it a minute and dribble some more acetone on it. As that rapidly cools, it causes microscopic cracks in the loctite and pulls in acetone.
Repeat this about three times. Right before the last treatment, lock the case down solid, double nut the top thread, and if you can, take a piece of fuel hose and slip it down onto the stud. Clamp a pair of vise grips over it tight but not so tight that you cut through the hose and damage the stud. The object is to have a little bit of grip and twist in the middle of the stud so you do not "wind it up" so hard.
After the last acetone treatment, while it's still hot....apply some muscle. Eventually this WILL work.
Ray |
Murt Samba Member
Posted: Mon Jul 28, 2025 7:17 am Post subject: Re: Help. How to remove this Stud ?? |
Thanks for the tip Ray
My wife is out walking the dog, but I'm pretty sure she will have some acetone somewhere along with all the nail polish and sh*t
Edit : Result will try it tomorrow morning
modok Samba Member
Joined: October 30, 2009 Posts: 27725 Location: Colorado Springs
Posted: Mon Jul 28, 2025 8:27 pm Post subject: Re: Help. How to remove this Stud ?? |
Not sure why you'd be concerned with blue loctite
Blue loctite breaks loose a lot easier than rusted solid.
heat it up to 300 degrees f
If it doesen't come loose then put oil on it, the oil will pull in as it cools. Try again. be patient.
Double nut it + vise grips if you don't have a stud puller
Acetone+ atf can make a decent penetrating oil |
Posted: Mon Jul 28, 2025 10:27 pm Post subject: Re: Help. How to remove this Stud ?? |
modok wrote: |
Oh yeah!...acetone and atf. I was really surprised years back when I tried it. Very good mix.
Ray |
Murt Samba Member
Posted: Mon Jul 28, 2025 10:31 pm Post subject: Re: Help. How to remove this Stud ?? |
You’re up late Ray
Heading out to the workshop shortly and will report back  _________________ 1966 VW Beetle ‘Jules’
Murt Samba Member
Posted: Tue Jul 29, 2025 1:30 am Post subject: Re: Help. How to remove this Stud ?? |
So, some good news and some bad news
#3 Deep Stud is out. Many thanks to Ray and Modok for the advice
I then gave the case a good look over, and found that it was very nice indeed, BUT although the bearings and the case are in remarkably good condition, I am now having second thoughts.
As I said the case bearings are as smooth as a baby’s bottom, cannot drag my nail across and feel anything at all, same goes for the internals of the actual bearings themselves, trouble is that I have measured up and have confirmed that the case is
0.060 - 1.50mm (2.619”)
Thrust is
0.080 - 2.0mm (0.784”)
I have done some searching online and it looks like new bearings for it have the Silverline code C24 111 198 491-60SL on (CIP1) I can’t find anywhere that has STD crank/0.060 case/0.080 Thrust?
This also makes me wonder if it’s worth building something with it ?
Quite disappointing really as was planning on sending it out for machining to 90.5/92  _________________ 1966 VW Beetle ‘Jules’
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 649 Location: South Bay LA, California
Posted: Tue Jul 29, 2025 2:57 am Post subject: Re: Help. How to remove this Stud ?? |
There are 7 pages returned on search term main bearings in the classifieds.
I didn’t get a look through all of them but several are posted by call sign heimlich (vwnos, in TX, unless overseas shipping to you is cost-prohibitive). You could reach out to him and see if he might have what you need… |
Murt Samba Member
Posted: Tue Jul 29, 2025 3:01 am Post subject: Re: Help. How to remove this Stud ?? |
Thanks Rob
I’ll check that out  _________________ 1966 VW Beetle ‘Jules’
oprn Samba Member
Joined: November 13, 2016 Posts: 14991 Location: Western Canada
Posted: Tue Jul 29, 2025 5:46 am Post subject: Re: Help. How to remove this Stud ?? |
If the case does not need an align bore I am at a loss as to why the studs had to come out? I don't like to disturb them without good reason. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Tue Jul 29, 2025 5:51 am Post subject: Re: Help. How to remove this Stud ?? |
He’s pulling the head studs. Going 90.5/92 bore. |
oprn Samba Member
Posted: Tue Jul 29, 2025 6:02 am Post subject: Re: Help. How to remove this Stud ?? |
Ah! That justifies it! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Murt Samba Member
Posted: Wed Jul 30, 2025 7:12 am Post subject: Re: Help. How to remove this Stud ?? |
Hi Rob
Thank you, I will reach out to them
Unfortunately just had a message from Marcel @vwnos in Houston, and he doesn’t have any either  _________________ 1966 VW Beetle ‘Jules’
Posted: Wed Jul 30, 2025 7:31 am Post subject: Re: Help. How to remove this Stud ?? |
A radical idea you could consider in a pinch if you really want/need to use that case….
If bearings are out there for a 10 under crank but not a new one you could have the crank turned 10 under.
Also, sent you a PM.
Apologies if we’re veering too far off subject matter here. |
Murt Samba Member
Posted: Wed Jul 30, 2025 7:35 am Post subject: Re: Help. How to remove this Stud ?? |
Hi Rob
Have responded
I hear you but I have a brand new CBP 74mm CW crank that I am planning to use.  _________________ 1966 VW Beetle ‘Jules’
Posted: Wed Jul 30, 2025 7:39 am Post subject: Re: Help. How to remove this Stud ?? |
Of course. Crazy idea but it’s a lever you could pull if you get in a jam. |
Murt Samba Member
Posted: Wed Jul 30, 2025 7:51 am Post subject: Re: Help. How to remove this Stud ?? |
I’m probably going to save my pennies and get a new case Rob, it would have been nice to use the old case for the 1904cc but think I will need to go down a different route. I went to look at some cases today but none of them were really worth anything. Although I managed to get some other goodies from the seller. There were NOS Mahle B&P sets 90.5 /92’s and even a box of 94’s, I got a good deal on some nice bits and pieces though so I’m happy
daveblank Samba Member
Joined: November 07, 2024 Posts: 185 Location: Dallas, TX
Posted: Wed Jul 30, 2025 8:20 am Post subject: Re: Help. How to remove this Stud ?? |
Murt wrote: |
Just so you know standard size bearings are hard to find too. I just got mine ordered from Pat Downs |
Murt Samba Member
Posted: Wed Jul 30, 2025 8:22 am Post subject: Re: Help. How to remove this Stud ?? |
Our hobby is not getting any easier Dave  _________________ 1966 VW Beetle ‘Jules’
