joeherb53 Samba Member
Joined: March 07, 2005 Posts: 51 Location: hernando mississippi
Posted: Mon Aug 11, 2025 2:50 pm Post subject: 165/65r15 tires on the front of a lowered bug |
Current setup 62 bug, 5 inch narrowed beam, cb 2.5 inch dropped spindles stock rims with 145r15 tires on the front
I'm upgrading to empi sprint star rims (5 inches wide) and was looking at 165/65r15 tires on the front (not going for slammed just a slight lowering in the front). Only brand I see for this size is continental and the reviews are in the good range, not excellent.
I was even considering 175/65r15 on the front, this opens up the option of different brands but this might cause rubbing issues.
don't get me started on the back, I wanted 195/65r15 (closer to stock height) but needs 5.5 rims, next would be 185/65r15.
anyone familiar with these tire sizes? |
geeze Samba Member
Joined: July 30, 2025 Posts: 30 Location: land before time
Posted: Tue Aug 12, 2025 6:33 am Post subject: Re: 165/65r15 tires on the front of a lowered bug |
been running 165/65R15s on the front of beetles and type 3s for years now
its my favourite tire for the front, same diameter as the classic 135 but puts more rubber on the road with more modern tread patterns than the old 135s come in, work a lot better especially under braking and in the wet
dont know about in the US but here in europe they are widely available in a whole range of brands from premium ones all the way through to the budget no name specials
I usually run the continentals and theyve always been good for me
edit to add, my only worry would be running them with a 5" beam, you may find you dont get much lock before they start to rub on the inner fenders |
Posted: Tue Aug 12, 2025 3:15 pm Post subject: Re: 165/65r15 tires on the front of a lowered bug |
geeze wrote: |
it's possible I might swap the beam back to a 2 inch narrowed and go back to drums so I can have shocks.
what size and brand do you run on the back? |
geeze Samba Member
Posted: Wed Aug 13, 2025 4:58 am Post subject: Re: 165/65r15 tires on the front of a lowered bug |
had no problems running the 165/65s with a 2" beam, lost a little lock on 3.5 but thats always the way
back usually go with 205/65 for that classic big and little stance but sometimes 195/65 if thats going to be too close to the archlip, depends a lot what rear end and wheel offset you run |
