How Do You Tighten the Distributor Clamp Bolt?
Ozmello
Ozmello is offline
PostPosted: Sat Aug 16, 2025 10:35 am    Post subject: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
When my starter failed I found out that the distributor clamp bolt was loose. This was discovered when I pulled the cap and the distributor rotated a few degrees. I have set the static timing but am unable to tighten the clamp bolt. The YouTube videos I have watched make it appear that the bolt is captive, whereas mine is a bolt that runs through the clamp and there is inadequate clearance on the end of the bolt to fit a wrench or socket. Have others run into this issue and is there a dogleg wrench specifically for this task? I have set the static timing several times, but while the car starts, I can't maintain an idle, and when I recheck the timing it is off again. Car had a good warm idle before this.
Ozmello
Ozmello is offline
PostPosted: Sat Aug 16, 2025 1:10 pm    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
Finally found the right collection of sockets, extensions, etc, to get the nut off of the hold down clamp bolt only to find that the bolt was stripped. I was able to put a couple of washers on the bolt to allow me to tighten the clamp. I set the static timing using a voltmeter, but still can't get the car to idle. I know that it wasn't replacing the starter that caused the problem, and likely figure it has something to do with the distributor timing, but much like a contestant on Chopped, I am out of time and won't return to the car until November. Any suggestions for troubleshooting the idling issue would be appreciated.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Aug 16, 2025 1:37 pm    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
The nut and bolt are 10mm.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Aug 16, 2025 7:22 pm    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
The clamps are often bent from being overtightened. Once overtightened, they don’t hold the distributor securely. Find a good used one that hasn’t been abused and has a good straight nut and bolt. Do not buy brand new reproduction clamps.
Roads Scholar
Member# 2059
PostPosted: Sat Aug 16, 2025 9:07 pm    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
tasb is correct.
The nut usually sits against the clamp edge and that prevents it from turning but I've had a few that were tweaked or the clamp edge "stripped" (worn out) so the nut would spin.
tasb
tasb is offline
PostPosted: Sun Aug 17, 2025 1:47 pm    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
If you restored distributors you’d find more than a few. I’d say a good 25% of the time the clamp is warped and the bolt is bent. Snug people, snug, is all you need.
Roads Scholar
Member# 2059
Ozmello
Ozmello is offline
PostPosted: Tue Aug 19, 2025 6:59 am    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
Any idea of the bolt to be used? M10 x 1.25 x 70mm?
Olli from NJ
Olli from NJ is offline
PostPosted: Tue Aug 19, 2025 9:51 am    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
It is NOT M10. That is HUGE. A nut and/or bolt that uses a 10mm wrench is most likely M6.
I will go out to my shop and find a distributor clamp bolt and nut and measure it.
Olli
Olli from NJ
PostPosted: Tue Aug 19, 2025 10:05 am    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
The one that I measured is; M6-1.0 x 30mm.
Olli
Ozmello
Ozmello is offline
PostPosted: Wed Aug 20, 2025 5:25 am    Post subject: Re: How Do You Tighten the Distributor Clamp Bolt? Reply with quote
Thanks!
