jonat Samba Member
Joined: July 16, 2013 Posts: 109 Location: United Kingdom
Posted: Thu Aug 21, 2025 2:11 pm Post subject: What is the correct size dynamo V belt to use for 1600 engine? |
Currently I have a toothed Bosch AVX-10x685 in the 1972 1600 engine.
Looking on heritage websites they use 10 X 905.
What is the correct size to use and does it make a difference?
Should it be toothed or flat? |
redhot Samba Member
Posted: Thu Aug 21, 2025 2:49 pm Post subject: Re: What is the correct size dynamo V belt to use for 1600 engine? |
Tooth or flat - I have seen/used both, there are reasons while not critical at all in my experience. Right size first, right tension then, and if anything other there is some variation maybe to tooth vs. smooth, while both shuold work.
https://www.thesamba.com/vw/archives/manuals/Autobahn_Parts_Catalog_1980/Type%201.pdf#page=67
So one size stated for generator and one for alternator
Gen: Belt 9.7x905mm
Alt: 11.3x912mm
This one would assume that pulleys etc. are matching that presumably... |
redhot Samba Member
Posted: Thu Aug 21, 2025 2:52 pm Post subject: Re: What is the correct size dynamo V belt to use for 1600 engine? |
1979 manual; last version and alternator;
Cusser Samba Member
Joined: October 02, 2006 Posts: 33416 Location: Hot Arizona
Posted: Thu Aug 21, 2025 3:01 pm Post subject: Re: What is the correct size dynamo V belt to use for 1600 engine? |
On my 1600cc DP engine with generator, I use IAP 111903137D
111903137D is 905mm x 10mm _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4544 Location: viroqua wi.
Posted: Thu Aug 21, 2025 3:27 pm Post subject: Re: What is the correct size dynamo V belt to use for 1600 engine? |
| It takes about 30 minutes to get the belt to its stretch point. Install it one shim tight or adjust it afterwards. |
