dl1970 Samba Member
Joined: September 25, 2024 Posts: 9 Location: New Zealand
Posted: Mon Sep 01, 2025 2:33 am Post subject: Camshaft wear in oil pump slot |
Just noticed the wear in the cam slot from oil pump on a reground cam. Is this normal and is it ok to use?
g][/img] |
Dusty1 Samba Member
Posted: Mon Sep 01, 2025 3:39 am Post subject: Re: Camshaft wear in oil pump slot |
Since the engine only turns one way and it looks like it's already together I'd grudgingly run it.
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4071 Location: Rapid City, South Dakota
Posted: Mon Sep 01, 2025 6:16 am Post subject: Re: Camshaft wear in oil pump slot |
Press the drive shaft in the oil pump gear out farther. You can do it in a vice with a couple of sockets. I usually have to push them out about .050+” so they get full engagement in the cam. It’s barely riding in the cam now, and it will just keep wearing.
No need to split the case or anything, just check it doesn’t stick out past the pump body when you are done.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3360 Location: Hamble, Hampshire, UK
Posted: Mon Sep 01, 2025 9:49 am Post subject: Re: Camshaft wear in oil pump slot |
I would worry more about the oil pump tang that did that damage. But that was probably in a previous installation if the cam is reground. Whoever did the regrind must have considered it OK.
It will probably wear a new oil pump tang unevenly to match its uneven contact surface as that wear probably does not go as deep as the tang of a new pump. _________________ Ancient vehicles and vessels
dl1970 Samba Member
Posted: Mon Sep 01, 2025 11:28 am Post subject: Re: Camshaft wear in oil pump slot |
Engine is at mock up stage only. Is it worth running this cam or am i best to look at another? Is this wear going to cause any long term issues? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11247 Location: Oregon
Posted: Mon Sep 01, 2025 11:57 am Post subject: Re: Camshaft wear in oil pump slot |
dl1970 wrote: |
As long as you have the oil pump gear tang fully engaged (per Brian's comment) with the camshaft slot. It shouldn't be a problem running it as is.
That said, if you don't correct the pump gear tang engagement, you may end up with this happening,
I found this when my oil pressure was Zero psi at startup one afternoon years ago.
The PO/Engine builder didn't check the tang engagement when he built the engine.
The camshaft slot looked like the OP's did. I ran it with a new 26mm oil pump until I replaced the cam during a recent build. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
mrinnovation1 Samba Member
Posted: Mon Sep 01, 2025 12:16 pm Post subject: Re: Camshaft wear in oil pump slot |
I've usually seen the wear on the pump shaft and not the cam gear. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3849 Location: The Woodlands, TX
Posted: Mon Sep 01, 2025 6:31 pm Post subject: Re: Camshaft wear in oil pump slot |
As Brian said, this is an important step that some builders do not check. I have had to adjust on almost every engine I’ve built. Besides chewing up the tang, it causes low oil pressure at idle. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79791 Location: Sneaking up behind you
Posted: Mon Sep 01, 2025 11:28 pm Post subject: Re: Camshaft wear in oil pump slot |
txoval wrote: |
Agreed _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
dl1970 Samba Member
Posted: Mon Sep 01, 2025 11:46 pm Post subject: Re: Camshaft wear in oil pump slot |
I so appreciate all this advice! I have measured the engagement and adjusted the drive shaft depth. I couldnt find an exact how to but used the following method. Fitted oil pump housing and nuts to hand tight. Offset the drive shaft tang so not in the cam slot. I then measured the distance the drive shaft cog sat out of the oil pump housing (4.2mm). I am assuming it therefore engages 4.2mm when rotated into the cam slot. I then punched the cam drive a further 1.7mm into the cog to give a final measurement of 5.9mm of engagement. Hoping this is the correct method!! Without your advice it would have been well off and adding to the issue! We work in metric in New Zealand so I believe this is initial engagement .165inch. shaft punched in .067inch to give final engagement of .232 inches. |
RWK Samba Member
Posted: Tue Sep 02, 2025 5:24 am Post subject: Re: Camshaft wear in oil pump slot |
There should be some end play, tang shouldn't bottom out in cam slot. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 604 Location: South Bay LA, California
Dusty1 Samba Member
Posted: Tue Sep 02, 2025 8:31 am Post subject: Re: Camshaft wear in oil pump slot |
dl1970 wrote: |
If it sheds chips the metal will go somewhere. The filter will catch it if you're running full flow. Otherwise the main bearings will catch it. I reckon one tiny steel chip equals one groovy main bearing.
modok Samba Member
Joined: October 30, 2009 Posts: 27716 Location: Colorado Springs
Posted: Wed Sep 03, 2025 6:38 pm Post subject: Re: Camshaft wear in oil pump slot |
The old cam here is the victim, the oil pump and case is the perpetrator.
So sure you can use the cam again, but the oil pump alignment in the case is what you might want to re-check.
Get the alignment and engagement depth correct, there will be no more problems.
The problem was because the oil pump was not aligned right before, and not engaged enough either. |
