Single to Dual Master Upgrade
pantone149
pantone149 is offline
PostPosted: Wed Oct 01, 2025 8:02 am    Post subject: Single to Dual Master Upgrade Reply with quote
If I convert my 65 bug from single to dual master brake cylinder, I expect to possibly have to change the adjustment of the brake pedal pushrod. Should I expect to have to lengthen or shorten the adjustment? About how much?
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Oct 01, 2025 8:05 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I don't know specifically, but with so much hardware changed out over the years I wouldn't worry about a numerical measurement.
Follow the right sequence:
1. Set pedal stop to obtain correct pedal tip-to-bulkhead distance (a little under 8" typically).
2. Set pushrod length to obtain 1/4" play at the pedal tip.
3. Lock down locknut and NEVER CHANGE IT AGAIN. Any later change in pedal play should be handled by the pedal stop, not the pushrod length.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
pantone149
PostPosted: Wed Oct 01, 2025 8:17 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Ok, thanks a bunch. If pedal tip-to-bulkhead distance should be a little under 8" typically is that measured from the braking surface (the rubber cover) to the carpet, or to the metal bulkhead?
KTPhil is offline
PostPosted: Wed Oct 01, 2025 8:42 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Measure from the carpet covering the bulkhead to the nearest pedal part (typically the back of the metal pad, or the rubber cover).
Between 7-3/4 and 8" will do it.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
pantone149
PostPosted: Wed Oct 01, 2025 10:56 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I measured several times and got from 7.75-8.0 inches from carpet (no additional padding or insulation) to the back of the brake pedal. In spite of that my pushrod is almost maxed out before touching the cylinder piston. Not sure if that's OK or not.
KTPhil is offline
PostPosted: Wed Oct 01, 2025 11:10 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
If it has full thread engagement it is fine. If not, look for a longer pushrod.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
daveblank
daveblank is offline
PostPosted: Wed Oct 01, 2025 5:46 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
What's a good brand of master cylinder for this upgrade?
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Wed Oct 01, 2025 6:46 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
This one from NAPA:
https://www.napaonline.com/en/p/NMCM2110
Lifetime warranty. New manufacture, not rebuilt or reconditioned.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
daveblank
PostPosted: Thu Oct 02, 2025 4:36 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
OldSchoolVW's wrote:
This one from NAPA:
Thanks. 1 more quick question. Is everyone ising the 67 type of reservoir or the one down on the master cylinder? I'm thinking that fitting the 67 would make it easier to access.
PostPosted: Thu Oct 02, 2025 11:37 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
The third set up would be to use the later ('68 ->) reservoir
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113611301L
with this bracket ...
https://www2.cip1.com/c31-809-021-111/
mounted inside the trunk using the fender mounting bolts.
Run this hose from the reservoir to the master cylinder using the route of your choice (use rubber grommets to protect this hose from the edges of any holes you drill in the sheet metal.)
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211611801
There are pros and cons to each method. The reservoir mounted to the top eliminates all the plumbing, but is a nuisance to get to and is exposed to the elements. The '67 reservoir protects the reservoir, but you still have to do some plumbing to set it up and need to remove the spare to add fluid. The third method outlined above uses the reservoir typically used with this master cylinder ('68->) in the location where it was placed in later models and is easier to access to check fluid level and add fluid as needed, but requires a bit more work to route the hose to the master. All three will work fine, so it's really a matter of what set up you prefer.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
daveblank
PostPosted: Thu Oct 02, 2025 11:54 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I've considered the 67 & the 68 & later. I do like the 67 style because it is hidden but easily accessible. The bracket for the later years seems to be out of stock at a few places. I did see a pic where someone used the 68+ reservoir but they installed it where the earlier reservoir mounts, they just removed the washer bottle to give room.
56Cabrio
56Cabrio is offline
PostPosted: Thu Oct 02, 2025 12:14 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
This is what I did on my oval, kept my original in place for looks though.
Here is a good thread on upgrading
Pic from gallery
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Oct 02, 2025 2:20 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I did the above reservoir on top of the master for a 74 pan that I put together recently. It is simple, no lines to leak or worry about, and the reservoir is cheap and available. I do not think it's location will be a problem with weather.
slave1pilot
slave1pilot is offline
PostPosted: Thu Oct 02, 2025 3:18 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I did the same thing on OL' Herb
Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
pantone149
PostPosted: Wed Oct 08, 2025 5:45 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
OK, so I have all new everything. Master Cylinder (Brazilian, Dual for 1967), steel lines, rubber lines, brake cylinders, and brake shoes (drums all around, 1965 bug). Pushrod is adjusted to allow about .25" pedal travel. All shoes are adjusted "snug" to the drum (drum can be turned manually with moderate effort). Reservoir filled with new fluid, DOT3. If I press the brake pedal nothing happens, no fluid movement. I've had the front bleeders open overnight (rears are closed) and expected some fluid to move by gravity to the MC but nothing happened. I also tried gravity bleeding (a few days ago) only the right front by opening that bleeder but plugging off all the other exit ports of the MC and nothing happened, no fluid flow. Shouldn't the MC get filled with fluid solely by gravity from the reservoir? What am I missing?
Cusser
Cusser is offline
PostPosted: Wed Oct 08, 2025 6:35 pm    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Explain this in detail.
53 years experience with my 1970, and 49 with my 1971, and I've never experienced any such issues with brakes. My 1970 has a new Brazilian dual-circuit MC (installed in 2016) and my 1971 has a warranty-supplied rebuilt MC from Autozone installed in 2020 (the previous lifetime Autozone MC only lasted 20 years).
Bobs67vwagen
PostPosted: Thu Oct 09, 2025 3:38 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Hi did you bench bleed the master before installing it? Do you have one of those hand held pistol grip vacuum bleeders such as the mitey-vac? You should have at least a little flow of fluid by gravity.
Cusser
Cusser is offline
PostPosted: Thu Oct 09, 2025 7:33 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Good question, Bob. Myself - I ALWAYS bench bleed, and it was stated to do that in the instructions of my warrantied Autozone MC.
pantone149
PostPosted: Thu Oct 09, 2025 8:00 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
Bobs67vwagen: Yes, I have a mity-vac and virtually nothing (little dribbles) gets sucked out into the device. The vacuum gauge on the mity-vac show increasing vacuum as I hand pump and the vacuum sticks around pretty well if I don't loosen the bleeder valve. When I do loosen the bleeder valve a little tiny dribble of fluid just might come through, but don't bet the farm on it.
I tested to make sure that fluid is moving from the reservoir (mounted by spare tire) into the MC and when I got a bunch of slippery fluid on my hands I determined that there is flow into the MC.
No I did not bench bleed. Reading a thousand posts on the Samba tells me about 50% of folks bother, the other 50% say it's a moot point. The shop that sells me VW parts told me the same (Wolfgang Int).
This is Brazil MC #2. The first one did OK for a while but gave up after a few thousand pedal strokes (I'm not kidding) and a few thousand mity-vac pumps (not kidding again).
My wife tested the pedal stroke last night and told me the number is not .25" but more like .5". This is something I plan to correct today.
Apostle_
Apostle_ is offline
PostPosted: Thu Oct 09, 2025 8:40 am    Post subject: Re: Single to Dual Master Upgrade Reply with quote
I am using a 67 master and reservoir. Had to drill an extra hole so I can keep the washer bottle. I used 1 meter of hydraulic hose and it was enough for both lines. I'm also using the fuel injection style clamps on the lines to the master. All new hard and rubber hoses.
