Piston Crown Markings
ss3963
ss3963 is offline
PostPosted: Thu Nov 06, 2025 6:53 pm    Post subject: Piston Crown Markings Reply with quote
Pulled the pistons from my 66 Beetle 1300. All four have the size marking of 76.96 stamped on the crown. Three of the four have a small "20" stamped immediately underneath this, and the fourth, an "18". Does anyone know what these additional numbers (18 and 20) are referring to?
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Nov 06, 2025 8:43 pm    Post subject: Re: Piston Crown Markings Reply with quote
Probably inspection marks. Would help to have a image.
Congrats on your first post!! May there be many more......
In Stereo, Where Available!
ss3963
ss3963 is offline
PostPosted: Fri Nov 07, 2025 10:12 am    Post subject: Re: Piston Crown Markings Reply with quote
Here is a photo of the crown markings on one of the pistons stamped with the number 20 below its size marking.
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Nov 07, 2025 10:33 am    Post subject: Re: Piston Crown Markings Reply with quote
Maybe some kind of date code?
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
viiking
viiking is offline
PostPosted: Fri Nov 07, 2025 3:47 pm    Post subject: Re: Piston Crown Markings Reply with quote
Probably a machine or process identifier.
For example most plastic bottles will have a code on the bottom to indicate which mould the bottle was made from. For interest go and have a look at a couple.
When the manufacturing Quality Assurance department identifies that certain bottles are out of specification instead of inspecting multiple machine moulds (multiple tens of them sometimes) they can narrow it down to one machine that is out of specification.
I believe that VW also did that with the case castings for the same reason.
It is modern manufacturing practice to have such identifiers. I assume three of the pistons were made by one machine and one was a different one.
Eric&Barb
PostPosted: Fri Nov 07, 2025 4:38 pm    Post subject: Re: Piston Crown Markings Reply with quote
If memory serves correctly that would be up inside the skirt of each piston.
Top of piston is lathed off.
