Gas Drip at Mounting Flange on 30/31 Solex
AR
AR is online now
PostPosted: Tue Dec 16, 2025 7:32 am    Post subject: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
1970 Bug with a rebuilt 30/31 done by other.
I just installed it as the final part to getting her back on the road. Everything went well and drove well. But I noticed that the mounting gasket(s) were wet with gas which led to a small drip coming off the mounting studs.(see picture)
There are 2 gaskets that are installed because of the emissions control bracket.
I do not know if that is correct or not and may have nothing to do with the gas issue.
Do I have a float problem, a gasket problem or something else?
Thanks
AR
messenger123
messenger123 is offline
PostPosted: Tue Dec 16, 2025 7:39 am    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
Check the throttle shaft to see if that's the source of the leak.
AR
AR is online now
PostPosted: Tue Dec 16, 2025 8:42 am    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
No leaks from the throttle shaft
messenger123
PostPosted: Tue Dec 16, 2025 8:46 am    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
Pull the air filter and look down the carb throat with a flashlight and see if you can see anything leaking.
Cusser
Cusser is offline
PostPosted: Tue Dec 16, 2025 12:08 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
1970 VW is exempt from California emissions testing. If mine, I'd remove that emissions control bracket and the throttle positioner part.
messenger123
PostPosted: Tue Dec 16, 2025 12:44 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
If you don't find any internal leaks, pull the carb and check both mating surfaces with a straight edge; they both need to be flat.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Dec 16, 2025 3:43 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
If the carb float bowl is overfilling it will leak down there. 2 probable causes are faulty float shutoff valve in top half of carb, they get gummed up and stick, and or excessive fuel pump pressure.
my3bugs
my3bugs is offline
PostPosted: Tue Dec 16, 2025 3:51 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
i had a similar looking drip/leak there so i snugged that nut some . a while later i went for a 2 hour drive there n back n see the same thing , so i snugged that nut again thinking it was somehow coming loose . it wasent exactly running right either as it was sucking air in right there making it run lean .
it wasent coming loose , i was pulling the stud out of the carb . at first i added new threads to the carb n JB welded the stud in and it held long enough till i found another carb to rebuild .... may not be your problem . but it fixed mine issue .
have you tried to snugg the carb mounting bolts ?
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Dec 16, 2025 3:57 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
I would do this and ditch the throttle positioner gizmo and plate. It's just more possibilities for leaks like you have.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Cusser
Cusser is offline
PostPosted: Tue Dec 16, 2025 5:56 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
I had this happen like 40-45 years ago; I used a larger SAE stud and nut (drilled the hole in the manifold a tad).
gt1953
gt1953 is offline
PostPosted: Tue Dec 16, 2025 8:24 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
suggets you add this to the fle pump it keeps that pin in and fule pumping
72 type 1
72 Squareback
AR
AR is online now
PostPosted: Fri Dec 19, 2025 10:19 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
Thanks everyone for your comments. I ended up replacing the mounting gaskets and it stop the gas leak. Having the emission control bracket sandwiched between two gaskets does lend to a leak problem.
I am considering removing the emissions like it was suggested to reduce problems down the line. I guess I was trying to keep everything period correct.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Sat Dec 20, 2025 10:53 pm    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
leaking gaskets there will show a symptom and not a cause. The carburetor shouldn't leak or drip, or otherwise discharge fuel after shutdown. Sometimes they do.. but they're not meant to. Float too high can cause it, or fuel pump PSI too high - or even the often-diagnosed, but usually not the problem, vapor lock related heat forcing fuel past the needle.
Robert in Memphis
Engine rebuild thread
Bobs67vwagen
PostPosted: Sun Dec 21, 2025 5:09 am    Post subject: Re: Gas Drip at Mounting Flange on 30/31 Solex Reply with quote
As Robert said above keep an eye on how it's running as there should not be late amounts of liquid gas down there. As said before it could be a float or fuel pressure problem.
