Holley 94's as dual carbs?
Bugman Jeff
Bugman Jeff is offline
PostPosted: Thu Sep 09, 2004 3:05 pm    Post subject: Holley 94's as dual carbs? Reply with quote
Has anyone ever tried using Holley 94's on their dual carb setup? IMO the Holley 94 is one of the best carbs ever designed. Few moving parts, extreamly simple to tune, as compact as a stock VW carb, cheap to buy and rebuild, and easy to get parts for. The 2100 carbs(Bugspray) was Holley 94 based, but got a bad rep. I gather it didn't work well mainly because the manifold wasn't properly designed so it didn't run that well.
But, on short custom fabed dual intakes, icing wouldn't be much of a problem, and I bet they'd work great. What are your opinions? Thanks.
-Jeff
Restorer of Porsche Speedster 80486 Smile
Type4parts
Banned
Type4parts is offline
PostPosted: Fri Sep 10, 2004 4:13 pm    Post subject: Reply with quote
See How to HotRod your VW. It talks about using them.
Arnolds64
Arnolds64 is offline
PostPosted: Mon Sep 13, 2004 3:16 pm    Post subject: Carbs Reply with quote
Good luck fabricating a linkage system or trying to find one that you can modify.
64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels.
Bugman Jeff
PostPosted: Mon Sep 13, 2004 5:07 pm    Post subject: Reply with quote
A standard dual carb linkage will work. Just needs to be adapted at the carb end to fit the 94 linkage. The throttle butterflys open just like on webers.
-Jeff
