Chewbacca Samba Member
Joined: October 27, 2004 Posts: 182 Location: Australia
Posted: Mon Dec 27, 2004 10:07 pm Post subject: Body lift on a full-bodied bug |
I'm planning on making and putting in a 2-3" body lift on the full-bodied baja I'm building, but realised I am going to run into a few problems in doing so.
With the body lift installed, the engine tin-ware will be sittting a good distance from the seal that runs around the engine bay, which in turn will let the hot air from the tranny/exauhst into the engine compartment
Does anyone have any ideas on how I could go about plugging up that gap?
Has anyone else installed or seen a body lift on a stock sedan?
Also, anyone who off-roads a full bodied sedan how does it cope offroad?
Thanks |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Mon Dec 27, 2004 10:41 pm Post subject: |
i remember seeing one in a vw trends a couple years ago. i'll look through the archives...
edit: no such luck...i do remember it though. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Posted: Tue Dec 28, 2004 12:06 am Post subject: |
well thanks for trying mate
I would be REALLY interested in seeing it tho.. |
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
Posted: Tue Dec 28, 2004 9:25 am Post subject: |
I haven't put an engine seal in a beetle in a looonng time but don't (at least some of them) put the rubber in a downward position? Or at least you can force it that way. If so maybe get some rubber as an extention and literally bolt or rivet it to the existing seals? Or maybe even welding some tabs etc.. around the perimiter so you can just bolt some 3" flat rubber around the hole? Just some thoughts don't know if either will do the trick though  _________________ Markus |
plasticman1432 Samba Member
Joined: January 19, 2004 Posts: 1180 Location: Nosebleed seats, NY
Posted: Tue Dec 28, 2004 10:41 am Post subject: |
I'd try to get a hold of Andy Felix, who sells the 'Up Yer Bug' body lift kits; if anyone knows how to make it work, he ought to be the 'go to' guy. _________________ Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/ |
vwclass11 Samba Member
Posted: Tue Dec 28, 2004 2:21 pm Post subject: |
My buddy has a body lift on his class 11 car. What he did was raise the motor and trans 3 inches as well, it came out really nice. I will see if I can get some pictures of his car. Basically what he did was use 2 solid mounts in the rear, welded them together, and custom made his front mount. Hope this helps, later Mitch. _________________ www.lowlifeaz.com
Vanhag wrote:
On a scale from 1-10 I see a class 11.
hotratz wrote: |
I hold a level 2 certification in Tribology |
http://images.thesamba.com/vw/gallery/pix/194538.jpg |
bajabusdoc Samba Member
Posted: Sat Apr 02, 2005 12:02 am Post subject: |
try raising the cooling tin, use thin 16 gauge shape like chanel iron and rivit on stock tin the problem area is the front (by the trans) piece as it has an arch as well. can be done but you trash your hands changing plugs or getting to the intake bolts in dual carbs, perhaps some one makes a comercial wheather strip or seal that could be used. |
Posted: Sat Apr 02, 2005 12:36 am Post subject: |
thanks for the help
I have decided against the body lift
cheers |
