356 pulley on a bus
Page: Previous  1, 2, 3, 4, 5, 6
KOMBI NIKO
KOMBI NIKO is offline
PostPosted: Fri Oct 13, 2017 2:28 pm    Post subject: Re: 356 pulley on a bus Reply with quote
Eric&Barb wrote:
KOMBI NIKO wrote:
Thanks mate noted. I did get the set up on today but had trouble with the belt sizes. Tried a 875mm and was too small ended up with a 880mm which is tight. Trying to find a 888mm which is proving hard in Australia.
How many shims between the pulley halves? Might see if just one more will work and still have the belt ride on its tapered sides properly. Also it will stretch and wear soon to slightly bigger.
Think there's 8 or 9 will have to go check, but I think its ok for tension. Will run it and see if it helps with the cooling problem next hot day.
https://www.instagram.com/demop_vw_garage/
https://www.facebook.com/Demopgarage/
https://www.youtube.com/@Demop_VW_garage
61 Microbus
63 Aussie single cab
52 factory ambulance
57 beetle
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Oct 13, 2017 2:31 pm    Post subject: Re: 356 pulley on a bus Reply with quote
As long as the tension is OK, then that is great. Too much and you can damage the gen/alt bearings.
In Stereo, Where Available!
KOMBI NIKO
PostPosted: Fri Oct 13, 2017 2:47 pm    Post subject: Re: 356 pulley on a bus Reply with quote
I do have a 888mm belt coming in the post too so it might be a better one in the long run. With our summer coming I need to get this over heating problem sorted.
61 Microbus
57 beetle
CapnMark
CapnMark is offline
PostPosted: Sat Jun 30, 2018 12:42 pm    Post subject: Re: 356 pulley on a bus Reply with quote
Does anyone know of a UK supplier who stocks the 356 pulley please?
Page 6 of 6
