KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35704 Location: Conejo Valley, CA
Posted: Thu Mar 31, 2022 3:21 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I graphed the few that I am considering for my '71 Fastback (1776cc)
The yellow and orange are '71/'70 stock curves from the Bentley.
Right now I used the recommended "F" (purple) but is it "too little, too late" and the car is sluggish.
Next I will go as aggressive as "E" (green) but it may be a bit much and I don't want to risk detonation, so I'll watch it.
If it's too much, I may try "B" (blue) which has a little less max advance, and is slightly slower to rise than stock.
The vac advance will add another 9 degrees, though they are not strictly additive, depending on load as well as rpm.
The "123" tables above and the "123" curves I made are engine degrees advance at engine rpm, just as you usually measure it.
NOTE: This graph (and the data posted above and by 123) is not comparable directly to the Bentley curves. Bentley measures distributor advance degrees (not crankshaft degrees) at a given distributor rpm (not engine rpm). Here is an overlay I made years ago from Bentley (ignore the orange dotted line).
KTPhil  Samba Member
Posted: Fri Apr 01, 2022 4:42 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I decided to aim high and selected curve "E".
A brief run around town, on the freeway, and up a long full throttle hill so far, and no sign of pinging.
She pulls much better in the midrange, as you would expect!
I'll be on the lookout for any pinging at the higher final advance this setting allows, even a few degrees higher than stock. I am running premium. I'll keep testing to see if the pinging comes back when she gets hot from long hot drives on the freeway over the next few weeks, but this is a good sign. |
KTPhil  Samba Member
Posted: Mon Apr 04, 2022 4:56 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I am getting an occasional miss/hiccup, more often when cold, but I am guessing this is mixture causing it, not advance. My guess is that it is running rich, partly based on the 24 mpg reading over the 200 mile trip for Meet in the Middle, mostly freeway, where it should have been in the high 20s.
After another valve adjustment, I'll hook up my AF meter/bunged resonator, and have a go at recalibrating the MPS on the road. Last time I did this was before the latest rebuild.
So the final tuning of both advance and mixture will determine which curve is really best for power, economy, and cool running. Everyone likes Cool Runnings.
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7410 Location: Houston, Texas
Posted: Mon Apr 04, 2022 8:39 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
If you can't find a good one ask if you can exchange your unit for the programmable one. Then you can enter into the unit the curve you want. _________________ www.vwnos.com [email protected]
KTPhil  Samba Member
Posted: Tue Apr 05, 2022 10:34 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Is this the Bluetooth model? I saw some reports about interference on those models, but can't locate it at the moment. But thanks for the tip, always nice to have backup plans. |
heimlich  VWNOS.com
Posted: Wed Apr 06, 2022 7:18 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
I asked if he had a unit that is programmable. His reply was 123/TUNE+-4-R-V-V.
It does show wireless on the page for it. _________________ www.vwnos.com [email protected]
Jason37 Samba Member
Posted: Mon Jul 17, 2023 9:53 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Anyone running the tune + version? If so what temps are you seeing on the dashboard? |
NotchVuu Samba Member
Joined: January 06, 2021 Posts: 5 Location: Australia
Posted: Wed Nov 08, 2023 8:52 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Jason37 wrote: |
I have the tune + , i haven't taken it on a long drive yet to test temperatures, but i'm wondering if there is anyone else using the tune+? if so, do they know the best settings for the centrifugal and MAP curves? I have a manual 68 1600 type 3 completely stock. I believe my original dizzy was the 311905205g by the looks of it (i cant find the rights curves for this one). I'm running the "one size fits all" from 123l and it doesn't seem right. its hesitating a bit on initial acceleration and seems to lack power. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23034 Location: Northwest of Normal
Posted: Wed Nov 08, 2023 9:46 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Here you go:
The numbers you can see at the bottom are RPM _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Those who can't? Subaru. |
Posted: Wed Nov 08, 2023 10:26 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Tram wrote: |
Here you go:
The numbers you can see at the bottom are RPM |
Thanks for that Tram, i saw this but it starts with 131 so i ignore it also said it was for vacuum. regardless, so from that curve the crank advance is
i get: 7.5 @500, 10@1100,17@2000 and 25@3000, not sure about the vacuum, any ideas?
I found this number for vacuum 25° (± 3°)
@ 65mm Hg, not sure it fits into that curve. |
Posted: Thu Nov 09, 2023 12:41 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Oops, sorry, I just noticed you are in Australia. Your engine is different than USA which got fuel injection. Your Aus distributor may have had a different curve entirely- I don't know.
If I were you I would try out the 010 and 019 curves here and see which best suits:
Link in case the image stops working
http://www.sparkingplugs.com/resources/_wsb_500x354_Advance_019-010-009.jpg
These were the "hot" VW distributors. The 009 is sort of a dog because it was originally for industrial engines.
The nice thing with this 123 is that you can play with the advance points moving things around till both you and the engine are happy. As we've found out, what works really well on one Porsche engine does not on another identical engine.
You can just bypass the vacuum altogether. My experience with the Tune Plus models has been that it seems every other one does not like the vacuum. It could also be me being an idiot though. On the base 123s where you just select a pre determined curve rather than programming it the vacuum works fine. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
HenrikL Samba Member
Posted: Thu Nov 09, 2023 1:25 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
If I read the manual correctly, a 1968 manual transmission carburator engine would have used one of the three distributors:
311 905 205 F
311 905 205 G
311 905 205 Q
They seem to be vaccuum only and have the same curve. |
Posted: Thu Nov 09, 2023 1:53 am Post subject: Re: Installing 123 Ignition Distributor - advice sought |
Tram wrote: |
You can just bypass the vacuum altogether. My experience with the Tune Plus models has been that it seems every other one does not like the vacuum. It could also be me being an idiot though. On the base 123s where you just select a pre determined curve rather than programming it the vacuum works fine. |
I read a thread on a Swedish VW forum about a user struggling to create a "vacuum only 123+". I got the impression that vacuum works fine on distributors with both centrifugal advance and vacuum (like 1500S 1964), but not on the vacuum only distributors. |
Posted: Fri Nov 10, 2023 4:54 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
HenrikL wrote: |
Tram wrote: |
Thanks for the info guys, yeah mine has PDSIT carbs, one has vacuum, I believe the car was only assembled in Australia, The dizzy should be the same as the one Henrik mentions, looks like i'm going to have test it out as tram says on a number of maps with and without vaccum. |
heimlich  VWNOS.com
Posted: Fri Nov 10, 2023 5:47 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
NotchVuu wrote: |
Jason37 wrote: |
Are you running the original size engine and carburetors or has that changed? _________________ www.vwnos.com [email protected]
Posted: Fri Nov 10, 2023 5:54 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
heimlich wrote: |
NotchVuu wrote: |
Jason37 wrote: |
Are you running the original size engine and carburetors or has that changed? |
Yes its a 1600 stock, duel PDSIT 32. Im creating curves to test now, it had a SVDA accuspark before, and ran ok for a while, but didn't last long till it gave me troubles. |
Posted: Sat Nov 18, 2023 2:21 pm Post subject: Re: Installing 123 Ignition Distributor - advice sought |
NotchVuu wrote: |
heimlich wrote: |
NotchVuu wrote: |
Jason37 wrote: |
Quick update, The one mentioned above from the distributor (311 905 205 G) curve was not so good, I found to be the best was the curve i got from an SDVA...which is :
500:0.0
1000:0.0
1400:8.0
2000:24
3000:28
3500:28
The vacuum Map i used was (above 1500 rpm) 0kpa @ 0, 1KPA @ 8.0, 2kpa @ 14, having the vacuum on made a difference in terms of smoothness.
Mine goes great after i used these settings which i tweaked a bit.. (i also reset the carbs to idle at 850-900 RPM after writing the files to the 123).
The top temperatures after driving it in heavy city traffic on a 25C day for more than an hour was around 70c or 160F according to the app. The top speed i drove at was about 80km or 50mph. Felt like i could go a lot faster.(ill test this on a longer highway drive soon) |
