slayer61 finally has a Dune buggy!
slayer61
slayer61 is offline
PostPosted: Tue Aug 01, 2023 6:38 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
^^ Well, thank you Sir. I appreciate your input. Very Happy ^^
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
slayer61
slayer61 is offline
PostPosted: Thu Aug 03, 2023 6:43 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
So, last night's jetting endevor didn't quite go as planned... Embarassed
I stepped the idles down from 55s to 50. I set the "lean best idle" and the right side was a little... different. No worries Rolling Eyes
Obviously it ran, but it went from "pig rich" to borderline too lean, popping & missing at anything much over idle... WTF?
I got home & went to put the 55s back in and found I'd damaged, err cut, one of the orings!! DAMMIT!! Evil or Very Mad
Back to the drawing board. "hello? FLAPS? Got any o-rings for Weber type carbs?" Rolling Eyes
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
Kafer_Mike
Kafer_Mike is offline
PostPosted: Thu Aug 03, 2023 8:56 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Weber part number for the idle jet o-ring is 41565.002. You may be able to locate the dimensions and/or cross-reference. If I had one, I'd just mail it to you.
Kafer_Mike
Build 'em fast...or let 'em sit.
slayer61
slayer61 is offline
PostPosted: Thu Aug 03, 2023 9:51 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Thanks for the kind offer Mike. I work at a facility that has a cabinet full of viton and buna orings. I have a "dime bag" full of assorted sizes for tonight.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
slayer61
slayer61 is offline
PostPosted: Wed Aug 09, 2023 7:06 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Small update:
I spent a small fortune on an assortment of jets, all smaller than I already had in the carbs. Special thanks to CB Performance & that auction site.
I started out with 55/160/200/F11 and 36 vents. I want to tell you that it was straight forward and simple. I also want to tell you that I wrote down each & every change, so I know for sure what I have Rolling Eyes Sadly, I just kept changing stuff 'till I got a satisfactory result. Embarassed
I ended up with 55/155/210/F11 with 36 vents.
I found that my 3 wire (narrow band) a/f gauge might not have been 100% accurate. In the end, I was just looking for what the car wanted.
Be safe.
ETA: I might still try the F7 tubes, just for kicks
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
vwracerdave
vwracerdave is offline
PostPosted: Wed Aug 09, 2023 11:04 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
I know ever carb jetting is different and depends on geographic location and elevation.
I'm at around 900' elevation. My 2165cc with 44 IDF's has 36 vent, 52.5i, 150m, 200a, F11. I always jet for 12.7 A/F at wide open throttle and never worry about anything else.
A big time VW guru told me to use f11 tubes for duals up to 40mm venturies and F2's for 40mm & larger venturies. Use F7 tubes for single carb set-ups.
slayer61
slayer61 is offline
PostPosted: Wed Aug 09, 2023 11:27 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Thanks Dave.
That's the first time I've heard that about the tubes. Interesting.
The info that I gleened from John's (aircooled.net) posts was
E tubes F7 richens the mixture up at the bottom of the RPM range and under acceleration, while the F11 leans the mixture out on the top end a little bit
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
slayer61
slayer61 is offline
PostPosted: Mon Aug 28, 2023 1:03 pm    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
So! What might be the FINAL Bug-O Rama is coming to Sacramento Raceway this weekend. Shocked
I can't let it go without giving it a go. For the first time since the '70s I will be on the drag strip! Cool
Summit just needs to get my harness delivered before Saturday morning! Embarassed
See y'all there. Be safe!
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
slayer61
slayer61 is offline
PostPosted: Mon Aug 28, 2023 2:06 pm    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Crap,
I forgot to mention that my Mrs. took a Saturday day trip to Columbia state park https://www.parks.ca.gov/?page_id=552 (old gold mining town in the foothills of California) and had a great time. It's been years since we went last, but it is still a worthy trip for anyone interested in that era of history.
Required "scenic overlook" shot
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
torchwerks
torchwerks is offline
PostPosted: Tue Aug 29, 2023 7:33 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
We used to go to Columbia when I was a kid. We dropped in last November. First time I had been back in over 40 years, and it was very much the same.
My brother volunteers at Railtown 1897 in Jamestown.
slayer61
slayer61 is offline
PostPosted: Wed Aug 30, 2023 7:06 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
8/30/23 Update:
I ordered my safety gear from Summit on Monday morning. Tuesday afternoon UPS delivered everything but the shoulder straps. Take THAT jeff bezos! Applause
Now, as long as the shoulder straps come in, all is good!
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
vwracerdave
PostPosted: Wed Aug 30, 2023 10:20 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Just for fun, any guesses on what it will run before you make a pass.
slayer61
slayer61 is offline
PostPosted: Wed Aug 30, 2023 11:24 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
I hoping for a low 13. We'll see.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
slayer61
slayer61 is offline
PostPosted: Fri Sep 01, 2023 6:55 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Sounds like I'm pulling the plug on racing the last Bug-O-Rama. Embarassed
My shoulder straps won't be here untill after the event... on Wednesday FFS! Mad
Maybe I see you in the car show area.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
67rustavenger
67rustavenger is online now
PostPosted: Fri Sep 01, 2023 8:10 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Well bummer! I was hoping for ya to have a couple good passes.
Have fun at the show, just the same.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
y2kbaja
y2kbaja is offline
PostPosted: Tue Sep 05, 2023 1:58 pm    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Wished I would have seen this before the event. You could have used the Simpson belts from my class 9 car. We didn't race this weekend.
slayer61
slayer61 is offline
PostPosted: Wed Sep 06, 2023 6:48 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Thanks very much for the kind offer! Very Happy
But I had bigger problems than the seat belts, so it turns out... Embarassed
If I was racing a sedan, and went slower than 13 seconds, I could do it in shorts & flip flops and not even a helmet, as long as I didn't have a sun roof. Being a buggy (at any speed) I would have needed a full NHRA spec roll cage AND the seat belts, drivers suit, boots and gloves, and, yes, a helmet.
dammit Sad
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
vwracerdave
PostPosted: Wed Sep 06, 2023 9:21 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
Just to clarify the NHRA rules, NHRA does not allow shorts and flip flops in any class no matter how slow the car is. All drivers are required to wear shirts with sleeves, long pants, and full shoes that cover the entire foot. Any car running faster than 14.00 is required to wear a helmet.
Yes, all dune buggy and sand rails regardless of how slow they are, the minimum requirement is at least a roll bar, 5 point racing harness, 1 layer fire jacket, arm restraints, gloves, and a full faced helmet. When you run faster than 11.50 the safety requirements gets more advanced.
y2kbaja
y2kbaja is offline
PostPosted: Wed Sep 06, 2023 9:59 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
I never understood why anyone on a race track, even a drag strip, going any speed would not wear a helmet. Cracked me up last year Bugorama the bugs running the strip with tshirt and no helmet.
vwracerdave
PostPosted: Wed Sep 06, 2023 10:36 am    Post subject: Re: slayer61 finally has a Dune buggy! Reply with quote
You are not required to wear a helmet when driving your car on any public road. Some slower cars can legally run faster on a public road then in a 1/4 or 1/8 mile drag race at the track. You probably have a much higher chance of crashing on a public road than at a drag strip.
My Karmann Ghia with a 2165cc only runs 72 MPH in the 1/8th. There are turnpikes around here where the speed limit is 80 MPH.
Page 8 of 9
