ABA Vanagon Conversion
vw62kid
vw62kid is offline
PostPosted: Sun Jun 08, 2025 8:01 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
I have a good update to this thread. A buddy of mine helped me clean my block for 10 hours on a Saturday. We got the block looking immaculate. Started off by getting the cleaning materials ready and then started the cleaning process.
My dad came over and gave me his engine building expertise. We then started to assemble the short block. We put the IM shaft in, Crank, the JE high compression pistons in with rods, then the oil pump.
Then I started assembling the long block with a TT 266/270 cam.
I haven't finished assembling the long block yet. Next I need to check my valve to piston clearance. Once the long block is built, and ports are covered I'll be getting the vanagon in the garage to rip the old water boxer out.
______________
62 Ragtop Project (Anthracite Grey)
https://www.thesamba.com/vw/forum/viewtopic.php?t=597378&highlight=
59 Logo Single Cab Project (L345 Light Grey)
90 Vanagon tin-top ABA convserion...work in progress
https://www.thesamba.com/vw/forum/viewtopic.php?t=...1a11892111
vw62kid
vw62kid is offline
PostPosted: Mon Jun 09, 2025 6:53 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Just checked my valve to piston clearance. The playdo was about 1/16"-1/8" thick and there were no valve signatures on any of the playdo patties. I'd say I have a good amount of clearance.
I completely forgot till my dad reminded me, I have to calculate my compression ratio. Does anyone have a good method to do this while the pistons are in the block?
______________
vw62kid
vw62kid is offline
PostPosted: Tue Jun 10, 2025 8:33 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Well I made a mistake. I installed 2 of the connecting rods incorrectly flipped. The bump on the connecting rod is supposed to be facing the front side of the engine, but there are 2 of them where they are facing the back. Asking around, there were mixed opinions on if this needed to be corrected or not. At first I didn't feel the need to correct it, but after some time I decided I need to correct this. When I bought my JE pistons, they came with rods that have ARP rod bolts installed in them with what I believe were intended for a Ford 289/302 V8 (APR 154-6002). This was a common alternative to the ABA ARP rod bolts that were twice the price at the time. I'm going to test these and replace the rod bolts if they test good. Bummer to have to step backwards, but better than having the possibility of something bad happening, and I end up with ARP rod bolts installed.
______________
rogertj
rogertj is offline
PostPosted: Wed Jun 11, 2025 10:19 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
vw62kid wrote:
rogertj wrote:
Wow looking awesome!
Im starting again with mine, blown piston and God knows how many damages in the interior of the engine... ill post photos in my thread once I start. Will start with the spare cylinder head that I got just did my Subaru heads on the Outback and it was ok. Seems that the 2.0 heads of my ABA don't seem to be difficult. Will send it out to machine surface.
Keep up the good work!
And I checked pincheallsgarage manuals but the ABA is incomplete... bummer... the cylinder head section for the 4 cylinder engine is missing... Shocked Very Happy Very Happy Very Happy Very Happy If anyone has that section they will greatly appreciate it! (That who says never... it will happen lol) now im looking for a manual. Time to get back to the wagon, Subaru is not yet for me $$$$ but in the future will install all the bells and wistles
Ahh man that's a bummer to hear. Have you made any progress on it since then?
No not yet waiting on some pesos lol
Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
View user's profile Send private message MSN Messenger Twitter Gallery Classifieds Feedback
vw62kid
vw62kid is offline
PostPosted: Wed Jun 11, 2025 10:38 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
I wonder what happened. You said there's a bad piston? Do you know if it's rings? A cracked piston? I'm curious to know, these motors are pretty resilient haha
______________
vw62kid
vw62kid is offline
PostPosted: Wed Jun 11, 2025 9:13 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Well I tested my ARP hardware that came with my pistons on some spare rods. They are ARP 154-6002. ARP states to tighten till the bolt stretches .006" to .0065" or tighten to 35ft lbs. So as a test I tightened to 35ft lbs, but my bolt stretch was .009" to .010". To get the bolt to stretch to .006" to .0065", it only takes 21-22ft lbs. That seems like it doesn't take much torque to get to that stretch. I may call ARP about this and see what their thoughts are.
______________
vw62kid
vw62kid is offline
PostPosted: Thu Jun 12, 2025 10:31 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Just got off the phone with ARP. They said that the bolts may have been yielded during installation into the rods by pulling them through instead of pressing them in. However, I've had multiple people tell me they pull their rod bolts through for installation, torque to spec, and run them so I think thats what I'm going to be doing as well.
______________
vw62kid
vw62kid is offline
PostPosted: Thu Jun 12, 2025 8:11 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Update! Took the rods out, switched out the rod bolts for the ARP stuff, and put them back in correctly orientated. Put the head on and torqued it down for the final time, and we even calculated the compression ratio. We came up with 9.5-10:1. Now I can finish assembling the long block!
______________
vw62kid
vw62kid is offline
PostPosted: Thu Jun 19, 2025 5:47 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Another HUGE milestone today. The long block is successfully built and sealed off for the most part! I have to make a small flange to seal up on a port on the oil pan but that'll be real easy. This conversion is finally about to move to the next step. It's time to bring the vanagon in the garage.
______________
Kdj
Kdj is offline
PostPosted: Fri Jun 20, 2025 4:22 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Congrats, Dancing following your build. Looking forward to forward to next step.
uberaudi
uberaudi is offline
PostPosted: Fri Jun 20, 2025 1:49 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Right on! Nice work man!
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
vw62kid
vw62kid is offline
PostPosted: Sun Jun 29, 2025 3:31 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Just bolted on my ceramic coated AEG exhaust manifold with stainless steel hardware. Still getting things lined up to move the vanagon in the garage. I'll be doing that soon!
______________
vw62kid
vw62kid is offline
PostPosted: Tue Jul 01, 2025 6:43 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Big step today! Started the vanagon and moved it from its 3 year resting spot. Surprised at how well it started up honestly. I took it to the car wash and then put it in my garage! It's time to rip the old waterboxer out.
______________
vw62kid
vw62kid is offline
PostPosted: Wed Jul 09, 2025 6:41 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
First engine pull I've ever done. Got everything disconnected and pull the tired water boxer out of there! Now I'm going to get the engine side ready with the adapter, flex plate and torque converter installed. Then I'll clean the engine bay up, make sure everything is ready to install, and bolt it in.
______________
khughes
khughes is offline
PostPosted: Wed Jul 09, 2025 6:45 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Great engines, have fun!
Popcorn
'86 Westy FAS GenV Turbo (Marvin)
vw62kid
vw62kid is offline
PostPosted: Thu Jul 10, 2025 7:31 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Did some test fitting on the kennedy adapter plate and noticed that the plate completely blocks the oil pan bolts on the engine.
With hardly any room to fit a tool in there incase I ever need to, I decided to modify the adapter plate to allow clearance of a long torx bit.
Small progress today, but hopefully something that'll save me down the road incase I end up in that situation. Next is to drill out the top left bolt on the bell housing so I can mount the adapter plate properly. More pictures coming soon!
______________
vw62kid
vw62kid is offline
PostPosted: Wed Jul 16, 2025 5:44 pm    Post subject: Re: ABA Vanagon Conversion Reply with quote
Got the ABA ready to install now. Torque converter, flex plate, adapter, and carrier arms are mounted on the engine.
Next is to clean up the engine bay, install a new torque converter seal, and start bolting things together!
______________
Abscate Premium Member
Abscate is offline
PostPosted: Thu Jul 17, 2025 2:49 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Well, someone has never heard of piston slap, have they ?
Fix it/
MarkWard
MarkWard is offline
PostPosted: Thu Jul 17, 2025 6:09 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Nice progress. I see the torque converter bolted up. I realize you are replacing the seal, but the torque converter needs to be installed fully into the transmission. There are 3 distinct steps that allow the torque converter to seat completely. Once the transmission is bolted up, then you attach the flex plate.
I donโ€™t believe you could get it correct with the torque converter mounted to the engine. Apologies if I misunderstand your method.
vw62kid
vw62kid is offline
PostPosted: Thu Jul 17, 2025 6:38 am    Post subject: Re: ABA Vanagon Conversion Reply with quote
Thanks for the advice! Ive never installed a torque converter before, let alone one on a vanagon. Now that I think about it, I've read this on another thread before here on thesamba. I'll definitely follow the advice!
TC to transmission > engine to transmission > TC to flex plate.
______________
Page 8 of 9
