Pushrods/valves SEEM dead / engine build
marknmelcom
marknmelcom is offline
PostPosted: Sat Jul 15, 2023 4:57 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Hey @nacho
I enjoyed flipping through your thread a bit last night.
Four things (that you may already know - but I'm writing here as an attempt to help you and others out) :
1. Pushrod tubes. Be sure "stretch" your stock style a bit before you install them. There is an exact measurement somewhere on here. I marked on my workbench that length. This allows the bellows to collapse a bit during install and give the right amount of pressure on the end seals.
2. When your cylinder head is still a bit loose, align the welded seam at the "top" as they sometimes have a tendency to weap.
3. As you are just beginning to snug down your cylinder head, a deep 13mm or 14mm socket on a 6" extension makes a good tool to correct the approach angle for the push rod tube into the head. Ensuring they are square to the head guarantees that they have a good seal, and are not going to rub through your pushrods.
4. 88's are great, as long as they are the thickwall variety, The difference between thin and thickwall: Thinwall can be installed into stock heads. Thickwall requires heads cut for 90.5 cylinders. Thickwalls are just as thick, or perhaps even thicker than stock 85.5 cylinders. Thinwalls should be avoided due to warping issues. With either style - the case is unmodified, and the base of the cylinder that goes into the case is very thin. That's ok, as it's just used as a locator anyway, and the actual sealing surface is between the case deck and the fins on the cylinder. I have a set of 88 thickwalls on my mouse motor (74x88) and they've been great. I wouldn't go any bigger than 87mm on uncut heads.
'67 Beetle - 'Winnie'
'75 Std. Beetle - 'George' - moved to a new owners house
'13 Golf coupe - 'Bitter Bunny'
'15 Tiguan 4mo - 'Tig'
marknmelcom
PostPosted: Sat Jul 15, 2023 5:05 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
NachoCar wrote:
Going to switch out my DVDA dist. for a Magnaspark.
Love my Magnaspork ...er Magnaspark. Worn out 50 year old distributors suck!
I set for 32° total advance with my timing light. I used the lightest springs. Wow - startup/idle/acceleration are amazing! No evidence of any ping! Highly recommended!
NachoCar
NachoCar is offline
PostPosted: Fri Oct 20, 2023 6:53 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Well......she is running better than ever. But still stationary.
I have wired the basics myself, which has been a learning process. Had the power input to pertronix HV coil (Suggested by Alstrup) going thru a distribution block but it SEEMS to fire so much better straight off the battery.
Noticed a grinding/scraping sound coming from the fan after shutdown. This is the second time the alt shaft has hollowed out a fan hole, at least I assume this is the same issue as it has happened once before. What gives? I try not to buy cheap shit so wouldn't think it's the metal the fan is made of. Current is a scat welded/balanced, over $100
Such a pain getting the 4 bolts out that keep the fan in place on the shroud....
Any suggestions on which fan to buy ? I'm thinking CB's 2171.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Oct 20, 2023 9:25 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Are you using a torque wrench to verify the fan is tight enough? Too tight is as bad as loose! Do you have the wavy washer correctly oriented? Those are the 2 items that allow a fan to crack at the hub.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Sat Oct 21, 2023 9:49 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Probably just need to shim the fan gap. It will do that if it’s not shimmed to spec. Might also need to manually adjust the forward side of the fan shroud where the fan sits, it rubs there sometimes.
Robert in Memphis
Engine rebuild thread
NachoCar
NachoCar is offline
PostPosted: Mon Oct 23, 2023 6:27 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Thanks Guys! I had not thought about too much muscle but I can imagine it fatigue-ing the metal. I'll torque to spec this time.
Went ahead and ordered the CB Perf fan hardware kit to be sure and get the proper shims.
Now to get that bottom left bolt back in during installation. Always fun.
NachoCar
NachoCar is offline
PostPosted: Mon Dec 11, 2023 12:44 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Disaster.
Just like the first engine ........ran great while sitting......after driving maybe a couple thousand yards up and down my street.....engine died and would not crank.
Pushed her home and noticed crank was slipping on alt belt when I was trying to turn over by hand. Just now took spark plugs out and rocker arms off and STILL no movement when using breaker bar on alt nut.
Devastated but will have torn down by this weekend to see what the deal is. I'm betting spun #4 bearing. Machinist felt bearing was out of spec and that hand shaving the ID was the solution. Doubted my abilities as a total engine novice and I fear I was right. Just a kick in the nuts.
I enjoy the process and I am trying to look at this as a learning experience but a little frustrating to say the least. I WANT TO DRIVE THIS CAR!!! Been 10 years working on it.
stay tuned for pics.
NachoCar
NachoCar is offline
PostPosted: Tue Dec 12, 2023 2:47 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
#4 bearing was not the issue. It spun #1. pics tomorrow. Brick wall
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Dec 12, 2023 3:00 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Thanks for hanging in there and for sharing pics. We all learn from this. I've crushed bearings on pins before, despite thinking I was careful.
NachoCar
NachoCar is offline
PostPosted: Wed Dec 13, 2023 8:14 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Phil....please look at pics as I honestly think the cause was inadequate oil at #1 bearing. Otherwise wouldn't there be a mark on OD of bearing where pin crushed into it? That's what happened a couple times before I got the case halfs together and torqued down to spec. But I admit I don't know shit, Lol.
I'm worried it was inadequate oil to #1 bearing. Whil I had my crank polished, I could not get it reground because the ONE machine shop within hours from me kept passing my job up for more lucrative Porshe projects. After 3 months I went and picked the crank and case up.
A buddy mentioned the protrusion of the bearing pin. I really think it was ok but it was just a tiny itsy bit lower than the others.
Opinions?
See hairline crack??
Other side to show no dents from misaligned pin.
ANy guidance on what cause was would be helpful.
Thanks Guys
Millionmph
Millionmph is offline
PostPosted: Wed Dec 13, 2023 9:52 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
see the photo of the block where the bearing sits? see the numbers from the bearing stamped in the block? case needs align boring, trying to reassemble that is going to do same thing over and over... the thrust area looks pounded too theres no real definition left there
NachoCar
NachoCar is offline
PostPosted: Wed Dec 13, 2023 10:04 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Thanks!
Another align boring... Brick wall I HATE waiting for machine work. But if it needs it, it needs it.
Millionmph
PostPosted: Wed Dec 13, 2023 11:41 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
NachoCar wrote:
Thanks!
Yeah just noticed on previous posts you just got a line bore, by the looks of that latest post the saddle got pounded again as you can see the number clearly pounded into the saddle, was a new thrust cut made when it was line bored? that whole area doesn't look as fresh as it should considering it was just done, but if that bearing spun then the that soft magnesium is prolly damaged and would need a truing up; something was up for it to fail
NachoCar
NachoCar is offline
PostPosted: Wed Dec 13, 2023 12:14 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
No machinist didn't cut new thrust and sure hope to avoid this crap again so I guess a little waiting is ok.
Maybe third times a charm.
VW_Jimbo is offline
PostPosted: Wed Dec 13, 2023 11:22 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
That bearing was pounded on. Either too tight or too loose. What were the measurements of the crank and bearing at full crush?
Case does not look like it was machined, at all. What are the diameters of the bearing openings measuring?
Jimbo
MuzzcoVW
MuzzcoVW is offline
PostPosted: Thu Dec 14, 2023 4:16 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Absolutely was. And I've never seen a thrust surface bent/warped like that (on the bearing). Looks like it was pried on with a screwdriver
raydog
raydog is offline
PostPosted: Thu Dec 14, 2023 6:23 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Check your oil passages. I am seeing a ton of red silicone on that case. I agree, it looks as if that bearing was a problem from day one. Why the pry marks on the bearing flanges?
Come on, It's not rocket science. KISS
NachoCar
NachoCar is offline
PostPosted: Thu Dec 14, 2023 8:44 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Bearing was stuck on crank. I used a large screw driver with a tap here and a tap there to dislodge.
Started looking for my notes, but I'm not the most organized guy.
If memory serves me, #1 bearing was a hair loose BUT #4 was the biggest issue and my machinist insisted that bearing was off and I needed scrape the ID to achieve enough clearance. I was skeptical but it lasted longer than #1.
Thanks for feedback, I'll update with specs when I find.
NachoCar
NachoCar is offline
PostPosted: Mon May 13, 2024 1:09 pm    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
New Line bore on original case and new AL case purchased for a backup longblock.
Bore was done by Keith's Auto in WV if anyone is familiar. Interestingly he did NOT bore to next size up, just cleaned bore up and did not cut thrust?!?!? I'll get pics of thrust area tonight.
Check out cam saddle of middle cam. I thought there was dirt or debris and went to wipe it off. End broke off which got me looking closer. FRICKEN crack in middle.
This is almost getting comical at this point. This happened after second mockup with crank and camshaft in place. Cam bearings were fine afterwards so thinking this shows it was not damage done by me torqueing down together with something addition in middle cam bearing area, causing the damages. Hope manufacturer agrees.
NachoCar
NachoCar is offline
PostPosted: Mon Jun 09, 2025 6:05 am    Post subject: Re: Pushrods/valves SEEM dead / engine build Reply with quote
Guess I need to work on my clutch adjusting skills Geez
Page 9 of 10
