Replace or repair gas tank
Page: Previous  1, 2, 3  Next
Karl
Karl is offline
PostPosted: Thu Jan 18, 2007 7:45 pm    Post subject: Reply with quote
Campy wrote:
You don't get it. By "new" cap it wasn't meant to be a later model cap. By using the example of the cannister, it was meant to show that, at VW, they developed a better system for their later model cars, because they had to to meet new VOC standards. I thought that I explained it pretty clearly.
The "original" caps don't vent the fumes directlly to the atmosphere like you would have if you drilled a hole directly through it.
Try storing one of those five gallon gasoline containers without the tiny lid for the spout on it, full of gasoline, in your garage. My father did it, once, on a warm day and, luckily, there was no water heater in the garage and I didn't start my bus until the garage was aired out.
Opening up a fuel tank directly to the atmosphere is not a good thing to do; telling people to do it is completely irresponsible.
Thanks for letting people know that the later model gas caps won't work, anyway.
I am done arguing.
Take a look at the original caps. I even posted pics of one. YES, they most certainly do VENT directly to the atmosphere. Around the inside edge are vent holes. If you buy a new cap that is advertised as fitting a 67 and older bus, it is a sealed cap. You WILL collapse your gas tank using it. I know, I HAVE a collapsed tank I took out of my 66 using one that was billed as 'correct for 55-67 buses'. I sent that link too. Do you read anything or just think its all bullshit?? Pre-evaporative emission vehicles DID vent the gas tank directly to the atmosphere.
Campy
Campy is offline
PostPosted: Thu Jan 18, 2007 10:20 pm    Post subject: Reply with quote
Karl, so you think that it is safe to have one larger hole through the center of the gas cap? There was a reason that the engineers at VW didn't design gas caps that had one hole straight through the middle and a reason that they got rid of them. I suppose that you store your filled up gas can in your garage with the small lid off, too?
Do you know any engineers who recommend having one larger hole directly, I repeat, directly, through a gas cap, so the gas fumes could possibly reach an ignition source??
Do you know how to read? I stated in my previous thread that I didn't mean by "new" cap an unvented cap. We all know that the mail order companies are selling unvented gas caps, so you don't need to keep repeating it.
Drill a hole straight through your gas cap. I just hope that you don't have a pilot light in your garage.
Wolffeather
Wolffeather is offline
PostPosted: Fri Jan 19, 2007 6:36 am    Post subject: Reply with quote
There was a thread about the tank leaking around the filler neck and what to do, a few months back. There was some really good points of views on what to do too. I would repair it when ever possible-keep the OG parts as long as you can. I remember ssomeone saying; fill it up with water (safety reasons) and then just braise it and repaint over the repair. I think you'll get a better repair and know what you have. I have broke them there quite a few times and had great results repairing them. Now I always hold the pump nossle, so the weight of it is hot pressing down on that LONG-NECK and I never let anyone else pump my gas. Even here in Oregon where there's NO SELF-SERVE. I always fill-up at the same station and they are to busy checking my bus out to want to pump it anyway
'62 Bus named Biscuit
'62 Bus (go-cart) named Baby Biscuit
'57 356 named Wind
'67 Beetle named Blue Bear
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Jan 19, 2007 8:01 am    Post subject: Reply with quote
Tanks are cheap enough and available to be dicking with an old and cracked one. If you suffer from "stockitis og" syndrome, buy a new stock one. If not then upgrade to a fatchick one and be done with it! Confused
Friedpotatoes
Addicted4life
Friedpotatoes is offline
PostPosted: Mon Jan 22, 2007 2:09 pm    Post subject: Reply with quote
To clarify I didn't drill a hole straight through the cap. The cap does fit nice . The only part i punctured was the the dome part. so it wasn't a straight through hole. it didnt quite vent on the sides. but it did vent. the most I could thread into the hole was door panel screw.
56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green)
Campy
Campy is offline
PostPosted: Mon Jan 22, 2007 2:42 pm    Post subject: Reply with quote
We miscommunicated. It was good that you clariffied it in case someone thought of drilling clear through the cap, which would not be good.
mpribanic
mpribanic is offline
PostPosted: Mon Jan 22, 2007 4:15 pm    Post subject: Reply with quote
What if you had a leaking, earlier non fuel sending unit tank? My '58 does not have a fuel sending unit. The tank has a hairline fracture in the bottom bend of the neck. I think I'll repair, not replace.
Help Help
Help Help is offline
PostPosted: Wed Apr 08, 2015 5:02 pm    Post subject: Reply with quote
Holy thread resurrections batman!!! I'm sure this thread had great information 7 years ago but a few things may have changed....
I've got a leak that I think is coming from around where the neck connects to the tank. It's on a 67 and the entire filler neck is attached.
How good are the repops available today?
Go the POR route?
Have a local shop weld it up?
Thanks in adavnce.
Pinetops
Pinetops is offline
PostPosted: Wed Apr 08, 2015 6:46 pm    Post subject: Reply with quote
People will still tell you to repair yours. I don't believe in messing around with questionable tanks so I bought a Wolfsburg West one. They now have a quality one available. Th '67 "hump" tank is not being reproduced so you'll have to have the flat one if you go new. I did have to clean some paint flakes off my new tanks filter sock after 6 months (I had it out anyway and looked, it wasn't clogged I just noticed some).
I would not use POR liner or anything like it. I've used it on motorcycles and I don't trust it not to flake. If the tanks not too rusty inside, you can CLR and shake bbs or a chain in a rusty tank to clean it. Then rinse and you're better off than coating. If it's not rusty inside don't do anything to the inside.
Opinions will vary on this stuff.
"A rolling bus gathers no rust."
g3bill
g3bill is offline
PostPosted: Wed Apr 08, 2015 7:01 pm    Post subject: Reply with quote
If it were me I'd figure where its leaking from first before asking. Is the tank rusting through, is there a pin hole from a factory weld, crack from stress? If it quite small you might just braze it it a small area after venting the tank for a good amount of time. I see no reason to use the POR sealer if theres not much more than a trace of rust. just what I might do?
I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
'67 Camper PT westfail w/tent, hammock, jump seat. uping the motor to 1900 w/88bore/78crank.
& will be using carb 34 pict 3 ....Someday?
'82 Toyota 4x4 5sp PU lb, daily driver
Many Corvairs /& 4 rag tops
'63 Chevy 20 Truck w/4sp 292
Want, white plastic end pieces for dash grab handle
Das67bus
Das67bus is offline
PostPosted: Wed Apr 08, 2015 7:26 pm    Post subject: Reply with quote
Campy wrote:
It's still dumb to drill a hole in a gas cap where the vapor goes directly out. If enough gasoline vapor accumalates out of the fuel tank and reaches a source of ignition such as a pilot light, so long. It is the gasoline vapor that is dangerous. That is why they developed cannisters in a sealed system where the vapor condenses back to gasoline. Spend a few bucks and buy a good cap.
That's fine. WHERE do you buy a good cap? I've had the problem of the tank pressuring up, leaking, and have tried several caps. I give!!!
SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd
Help Help
PostPosted: Wed Apr 08, 2015 7:32 pm    Post subject: Reply with quote
Oh, I know exactly where it's leaking from, the joint to the filler neck. That's what leads me to a new tank, POR or a Pro to weld/braze it. Given where the crack is, I'm already leaning to the new tank. Better safe than sorry? (As long as the new tanks are not uber chitty?!?) Anyone vouch for the WW tanks?
On a related note, my 18 month old VDO fuel sending unit decided it wanted to die too. That is the gauge went to E and stayed there. So I took it out and expected to find a float filled with gas but it's solid. I've taken it apart and everything is OK, the resistance fluctuates just as it should. However I don't trust it and will likely replace it just so I don't have to drop the engine yet again.
Pinetops
Pinetops is offline
PostPosted: Wed Apr 08, 2015 7:37 pm    Post subject: Reply with quote
Like I said above the new tanks (if you get it from Wolfsburg west only) are nice. Do not buy from another vendor or you will not get the new and improved tank unless you confirm they are carrying the WW tank.
Das67bus
Das67bus is offline
PostPosted: Wed Apr 08, 2015 7:40 pm    Post subject: Reply with quote
What are you using for a cap?
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd
Pinetops
Pinetops is offline
PostPosted: Wed Apr 08, 2015 7:42 pm    Post subject: Reply with quote
The original cap that came on the bus. I haven't had any issues with it.
Das67bus
Das67bus is offline
PostPosted: Wed Apr 08, 2015 7:46 pm    Post subject: Reply with quote
OK, thanks. I guess I'll have to find one. I have a Wolfsburg tank like you.
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd
Pinetops
Pinetops is offline
PostPosted: Wed Apr 08, 2015 7:50 pm    Post subject: Reply with quote
What is the problem you are having with the cap? Maybe I just haven't noticed anything.
Pinetops
Pinetops is offline
PostPosted: Wed Apr 08, 2015 8:02 pm    Post subject: Reply with quote
Have you seen this thread? Have you put on a good fitting, vented cap? Apparently some of the reproduction caps aren't vented which is a problem.
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...p;start=40
Some folks recommended the Stant 10623:
http://www.amazon.com/Stant-10623-Fuel-Cap/dp/B000...ords=10623
Das67bus
Das67bus is offline
PostPosted: Sun May 10, 2015 12:05 pm    Post subject: Reply with quote
I thought I had a vented cap, but I don't think I did. I am looking for a vented cap.
I have a new WW tank for my '67 bus and the Stant 10623 does not fit well.....way too tight to get on and I'm not sure it's going all the way on.
I am trying to find an original, vented cap like Karl mentions above.
Thanks!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd
kbman
kbman is offline
PostPosted: Sun May 10, 2015 10:07 pm    Post subject: Reply with quote
Over the years I've brazed three tanks. Two type ones and one type two and if needed I will do it again. I just saw a repair that made over 25 years ago while replacing tie rod ends a few months back. Still holding knock on wood. A hundred and eighty dollars for a new tank certainly is affordable but is it crap like a lot of after market products. Just because wolfsburg west sells it doesn't always mean its quality.
Page 2 of 3
