pyrOman Fire Master
Joined: July 21, 2003 Posts: 12421 Location: Over 2002 posts deleted!
Posted: Fri Feb 16, 2007 8:18 am Post subject: |
ovalboy wrote: |
I have wondered about using a transmission jack for engine removal/installation. The ones I have seen have a flat surface for the engine to rest on, but they also look like they will also swivel or pivot around to help with installation. Anyone ever used one for that? |
I bought a tranny jack solely for one job, doing the tranny on the Benzo. However, once I got the Plump Truck with the ridiculous "loose" tranny, I've used it more often than not!
Though it does the job quite nicely, it isn't a jack to be used for lifting and lowering as it's a bit of a bitch to do so using a ratchet. It works fine for the use above which is almost on "jackstand" status! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Ozzie Samba Cone Slayer
Joined: May 25, 2005 Posts: 1409 Location: Bluffton, S.C. Living in the duality; a Grateful Skynyrd thang.
Posted: Fri Feb 16, 2007 9:53 am Post subject: |
coW wrote: |
It does have "Craftsman" on it so I wonder if it has that unlimited guarantee as well..
I've asked before in the store about warranty and they said it was on mechanics tools only. |
I wouldn't need it for house painting. Car tools ARE mechanics tools.
What's their problem? _________________ Oversteer is when the back of the car hits the wall... |
coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Fri Feb 16, 2007 10:22 am Post subject: |
Ozzie wrote: |
coW wrote: |
What's their problem? |
It used to be on all sorts of things but that may have changed.
A while back I was given an old sears wooden crawler (at least 60s vintage). The thing didn't really roll well and was all busted up so tried to get it exchanged.
The manager looked at me like I had two heads - but I had to try it. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Feb 16, 2007 10:31 am Post subject: |
pyrOman wrote: |
vw (o\!/o) nut wrote: |
I've got that Motorcycle/ATV jack pictured in the ad.
That's one handy MF'r for engine and/or trans removal. |
Alright, that's the second "for removal" in short order.
I too have one and will third the "removal" use but add that it isn't always as good to install. It just doesn't have the give needed to "wiggle" the engine back in unless everything is lined up just right.
Have tried a few times and more often than not, had to swap jacks for the install! |
Unless you have the car level - not just the back end up on stands - it is hard to use that jack to get the engine back in. With the input shaft on an angle, and the jack flat on the floor its a no go. It's easier with a normal floor jack. However, if everything is leveled out or its a bus, where you can pull the apron off and skip the jacking alltogether, its quite handy.
ovalboy Samba Member
Joined: May 04, 2004 Posts: 1310 Location: Beautiful Northern Cincinnati
Posted: Fri Feb 16, 2007 10:32 am Post subject: |
coW wrote: |
Ozzie wrote: |
coW wrote: |
I took a ratchet back to them a couple years back. They came back with a "rebuild kit" for my ratchet. I said "I'll be damned, I didn't buy it as a kit." They went and got me a new ratchet. |
70 140 Samba Member
Posted: Fri Feb 16, 2007 10:36 am Post subject: |
ovalboy wrote: |
coW wrote: |
Ozzie wrote: |
coW wrote: |
I think it depends on your local store. I have taken some pretty beat looking stuff back and not been given anything but a new tool and a smile. I took back a busted 1/2 drive that had a bent handle with flaking chrome from putting a pipe on it. The business end was discolored from getting to close to the torch. No problem - new ratchet. |
fifty-five Samba Crash Test Dummy
Joined: August 27, 2004 Posts: 1188 Location: over by the Farm
Posted: Fri Feb 16, 2007 10:53 am Post subject: |
70 140 wrote: |
ovalboy wrote: |
coW wrote: |
Ozzie wrote: |
coW wrote: |
I always look for a cashier that looks like they wouldn't know the difference between a drill and a hammer (fake nails to long to even wipe their butt without poking through the paper, to much make-up, etc...) and that's were I go. They generally don't know how whatever tool I'm returning works in the first place and for sure don't know what it looks like if it's been "abused". I like to get grungy looking craftsman tools cheap at the flea market and take them back for a shiney new one. |
coW Samba Member
Posted: Fri Feb 16, 2007 11:25 am Post subject: |
fifty-five wrote: |
70 140 wrote: |
ovalboy wrote: |
coW wrote: |
Ozzie wrote: |
coW wrote: |
That's a great idea!!
I have a sears tools across the street and know exactly which cashier to go to now..
They are losing money on me and screwdrivers, sockets and ratchets - I've returned more than I can remember. |
pyrOman Fire Master
Posted: Fri Feb 16, 2007 12:55 pm Post subject: |
70 140 wrote: |
pyrOman wrote: |
Unless you have the car level - not just the back end up on stands - it is hard to use that jack to get the engine back in. With the input shaft on an angle, and the jack flat on the floor its a no go. It's easier with a normal floor jack. However, if everything is leveled out or its a bus, where you can pull the apron off and skip the jacking alltogether, its quite handy. |
Preaching to the choir here!
I'm so old school that way back too many moons ago, when I didn't even have a bottle jack, let alone jackstands, I'd use a milk crate under the motor. Cut it loose, push the bus forward, do whatever job was needed done, push the bus backward, bolt on, done!
The crate then "doubled" as a box for the left over parts!?! _________________ Some people are so busy being clever they don't have time enough to be wise. |
