busdaddy Samba Member
Joined: February 12, 2004 Posts: 52882 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 30, 2011 12:24 pm Post subject: |
raygreenwood wrote: |
You guys do know...that there are at least 25 different part #'s for these right? They were used on virtually every European watercooled car through the 70's and into the 90's.
That being said there is a huge range of variations and some may be quite difficult. Some are adjustable, some not. Some have larger or smaller inlets and outlets. Some have different size heaters for different time factors. Some have engineered bleed holes and notches in the sliding plate.
The big point being that you should also check for usable part #'s in Mercedes, Volvo, Saab, Audi, Skoda, Seat etc. Ray |
Don't forget Datsun, Nissan, Isuzu plus a few other Japanese makes and Alpha Romeo too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Busdepot Samba Member
Posted: Tue Aug 30, 2011 12:31 pm Post subject: |
geopanoramic wrote: |
Two years later - I still see them advertised at Bus Depot for ~80 $ |
That's because we have them again, as of last week. I found a fuel injection parts distributor that had some leftover inventory. They are brand new Bosch units. Availability is limited to supply on hand.
http://busdepot.com/details.jsp?partnumber=022906045A _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
geopanoramic Samba Member
Joined: September 10, 2008 Posts: 195 Location: Moscow, ID
Posted: Sat Sep 03, 2011 9:42 pm Post subject: |
Hey - thanks for the tips on aux air regulators!
Turns out mine is fine. I figured out the issue when I took a drive and found the brakes to be on manual...
.... therefore it was clear I blew the vacuum assist to the master cyclinder behind the firewall - so that was why my bus was hard starting, and racing and not idling etc, with no help for the air idle screw!
cheers |
77VWBusDude Samba Member
Posted: Sun Sep 04, 2011 8:03 am Post subject: |
Ordered, giggity.
Now get on finding a suitable replacement off a newer vehicle, Ron If you sell them.. they will come, lol. _________________ '77 Bus auto EFI(stock)
WendyArmbuster wrote: |
Oh man, I had forgotten the smell of a running bus. Sort of like a combination of old things and burning dust. Smells like... victory. |
BusBerd Samba Member
Joined: November 19, 2005 Posts: 837 Location: Minneapolis, MN
Posted: Mon Apr 08, 2013 9:46 pm Post subject: |
In 2007 I bought one of the remanufactured AARs from JC Whip-me. I don't know if I didn't see it back then or just that I didn't know any better, but the casing is all bent. Also the last number in the part number is scratched out so i wonder if this is a ...107 instead of a ...101. I don't want to put this back on after my rebuild. It looks like it will leak like a sieve.
_________________ "The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission |
Boesen Samba Member
a2d2 Samba Member
Joined: March 28, 2013 Posts: 366 Location: EastVanagon, BC
Posted: Tue Sep 24, 2013 7:29 pm Post subject: |
Boesen wrote: |
Im looking for the 13 mm ID hose that goes from the AAR to the Intake Plenium. Mine has succumn to age I believe, as its leaking some liquid (oil). |
If that is indeed oil leaking there is some other problem to track down - I could be wrong but I doubt there should ever be anything other than air going through there.
Check the rubber elbow as well, it may be more to blame than the 13mm hose. _________________ 1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.) |
Boesen Samba Member
Posted: Wed Sep 25, 2013 6:11 am Post subject: |
a2d2 wrote: |
Boesen wrote: |
Check the rubber elbow as well, it may be more to blame than the 13mm hose. |
Yes I will be checking the elbow as well. Thanks. _________________ 1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa |
