KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Fri Jul 25, 2014 11:12 pm Post subject: |
Jack Frisch wrote: |
Susan no longer restores the clocks |
Then besides Orange Empire Speedometer, who else? _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Sat Jul 26, 2014 1:12 am Post subject: |
KombiMadness wrote: |
Then besides Orange Empire Speedometer, who else? |
I'm getting ready to send my deluxe clock out to OES. Ryan just restored my speedo and it is immaculate. If you want it to look like it rolled of the line, have him restore it. |
Fredrok Samba Member
Joined: July 06, 2014 Posts: 227 Location: Under the evergreens. CO
Posted: Sun Jul 27, 2014 7:52 am Post subject: |
I have one out of our '64 that would run only for 10-15 minutes, usually less. I removed the back, oiled the cogs and pivot points w 3n1 and filed the points.
Things I found were the points had worn a valley between them and I had to scrape inside that valley to really get a clean surface where they actually contact (they don't contact flush). This was the only way it would continue to run past a few minutes.
I also couldn't get it to run on 6v very long, but now goes an hour+ on a 9v batt. I also had to ground to one of the back cover posts as the clock mounting post would not complete the circuit.
My issue is after all that, I get about an hour and a half out of it then it quits. The points end up contacting and then don't break the circuit to wind as usual.
Any suggestions? Just connect to 12v and let er rip?
Thanks |
Jack Frisch Samba Member
Joined: August 12, 2003 Posts: 768 Location: Northhampton, MA
Posted: Sun Jul 27, 2014 8:35 am Post subject: |
How do you remove the back? _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car |
Posted: Sun Jul 27, 2014 2:12 pm Post subject: |
Seems more voltage was my answer. Been running for hours now on 12 so I added the wire and threw it back in the dash.
Jack, use needle nose pliers to break off the anti-tamper pad covering 1 of the 3 nuts on the backside of the white cover. Then unscrew the 3 nuts and carefully work the cover off. You may need to support the power terminal with same pliers and work on the cover closer to that area as the cover fits pretty tight around it so you can break it lose from there. That'll likely be the hold up from sliding it right off. |
Posted: Sun Jul 27, 2014 7:44 pm Post subject: |
My clock has the blue tamper pad ring on and the other two threaded ends have no nuts on them. The white cover wiggles and has a gap of distance between it and the back of clocks face. See my video here:
https://www.youtube.com/watch?v=H9iDdCAIOJg&feature=youtu.be
Any suggestions on how to proceed? I don't neat to break anything, this is how I got this clock came when I bought it on ebay, I haven't taken to apart yet.
Jack _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
Posted: Sun Jul 27, 2014 8:51 pm Post subject: |
Jack, the nuts are missing from the exposed studs and possibly from the 3rd "tamper" stud but curious how they would do that without breaking the tamper pad (the whole reason it's there).
You should not have the play in that cover with the studs still protruding so my guess is someone got into it to try to get it working, was unable or intimidated and threw it back together, without all the hardware.
I'd go ahead and crush that blue pad off, get the nut off if there is one and carefully work the cover off. You need to do some investigating underneath anyway to see why it's so loose the way it is. I suppose it could also be loose like that if the front screws behind the hands are missing or loose as well. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15305 Location: Casa de Oro, California
Posted: Mon Aug 28, 2017 2:27 pm Post subject: Re: Deluxe Clock Question |
How dust tight is the front? I know the rear cover has a gasket.
Is there a gasket on the glass-to-housing or glass-to-bezel?
How tight should the glass be, meaning, should you be able to rattle it? |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71653 Location: Phoenix 602
Buskraut  Samba Member
Joined: March 22, 2011 Posts: 71 Location: San Jose, CA 95125
Posted: Mon Jul 28, 2025 12:29 am Post subject: Re: Deluxe Clock Question |
Passing along a recent success story with my '65 bus clock:
I've owned this clock for 35+ years and its never really worked right. It's spent 95% of its life stopped, or as they say, accurate twice a day. I tried cleaning up the mechanism a bit from time to time, and it would run for a couple of days and then stop. Converting the bus from 6V or 12V supply didn't seem to matter (for better or worse). Eventually the solder fuse blew.
Recently I got serious about getting it working... here is what worked:
1. For research, there is a great thread on the Ghia forum https://www.thesamba.com/vw/forum/viewtopic.php?t=583858 about clock repair.
2. For the fuse, I used his approach of replacing the hard-to-solder low temp solder fuse with standard solder, plus adding an external 1A fuse inline with the 12V supply for protection.
3. For cleaning, I used compressed air only. I think it's risky to introduce any other cleaning agents into the mechanism. Granted the internals on my clock were in good, clean condition... if you've got corrosion to deal with I'm sure it's a whole different story.
4. For lubrication, I used Nye #140-B oil, which you can find cheap (in the clock world) on EBay (I paid $15). For these clocks, I concluded that the type of lube is critical... not too thin (watch) and not too viscous (big clock). This one is synthetic and seems to check all the boxes for this size clock. You want to add it sparingly to the rotating shaft joints, not the gears (I'm sure I'm using the wrong terminology). I probably used 0.001% of the oil I received (which came with a nice oiling pen BTW).
Obviously I'm not a clock guy, just determined to figure it out. BUT, so far my clock has been running perfectly for a couple of months, and I was able to dial in the +/- screw so it keeps good-enough time. And I love hearing the periodic THUNK about once a minute as the solenoid winds the spring. _________________ Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1714 Location: Eerie PA
Posted: Mon Jul 28, 2025 5:40 am Post subject: Re: Deluxe Clock Question |
Thank you updating this thread. I have a small fleet of clocks I have been accumulating for the past 30 years. None of them have been tested and I’m sure need all of this. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12552 Location: Over 2002 posts deleted!
Posted: Mon Jul 28, 2025 12:06 pm Post subject: Re: Deluxe Clock Question |
Don't know how I missed this thread, but I'm sure I have address this before somewhere here. Anyway, here's my 2 pennies:
These old assed clocks, if they had any jewels, were only in the "heart" pivots. Every other gear spun on just plain drilled holes on the brass. The main gear that is pushed by the windup spring receives the most pressure, thus wearing out the hole. After so many years (decades) of this, eventually the gear does not engage properly and slows it all down until it just plain stops! Once it stops, the fuse blows.
I managed once to install a jewel on a clock's main gear before and ended up selling it. Not easy to do even if you can find a jewel that will match. Another option, which I did not do, is trying to find a Mercedes Benz clock from the '70s which runs a motor instead of the wind up type. The mechanism is identical to the old type. Hope this info helps some.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
BigVTwin Samba Member
Joined: May 02, 2006 Posts: 12 Location: United Kingdom - Birmingham
Posted: Sun Aug 10, 2025 1:53 pm Post subject: |
tstracy39 wrote: |
Don't use WD-40, it's hygroscopic (attracts water) and in the long run will cause the steel components to rust. Use 3-in-1 oil. They will have it in the tools section at Lowes. |
WD in WD40 actually stands for Water Dispersal...
it is not an oil as such but originally developed to spray on contact points or electrical systems to displace water...
but it is a reasonably good cleaner for the mechanism.
there is no need to oil these clocks as the spindles turn in plastic which needs no oil, oil simply attracks dust etc and increases the friction within the mechinism which has other effects...
from what I have seen 9 times out of 10 it is the solder joint that melts stopping the clock from being damaged, Keinzle clocks are used on many German cars and I found a full write up months ago on a Merc clock....
Apparently if a car/bus is left then as the battery drains the clock still tried to wind the spring, as the voltage decreases the coil desperatly tries to do this by drawing a higher currrent (made harder if the spindles are turning in a mixtuire of oil and dust)- this increases heat and potentially would burn oiut the coil which is a more expensive repair than simply opening the case and resoldering the safety joint - if your resolder it use low melting point solder (100 degrees C) or try to simply heat the connection..
alternativly you could put something like a 250ma inline fast blow fuse and raise this if the fuse keeps blowing till you find the optimum... |
