1982 Diesel Vanagon Radiator and Cooling Upgrade
Page: Previous  1, 2
rotaecho
rotaecho is offline
PostPosted: Tue Jan 27, 2015 10:25 am    Post subject: Reply with quote
Okay, reread that Mark, and the post previously stating the center prong is the live prong for the switch.
That being said.
Should the 12v live wire of the larger set be placed on the center prong, then the non-live of the smaller & larger placed on the outside prongs? Of which the outside wires may need to be swapped if nothing works right?
crazyvwvanman wrote:
No, that is wrong. The small hot wire is the wire not used anymore.
Mark
rotaecho wrote:
Just to be clear that I understand what peopler stating is that the hot (live wire) of the smaller relay wire should be on the center switch pin. The non-live wire of the smaller pair is tapped up and tucked aside....
-Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Jan 27, 2015 10:31 am    Post subject: Reply with quote
Radiator Fan Temp Switch, 3 wire.
Notice the 2 beveled inside corners on the end labeled +
Heavy wire with constant +12 goes to pin labeled +
Heavy wire to fan low speed connection goes to pin 1
Light wire to fan high speed relay control goes to pin 2
Power comes in on the end + pin. Then when internal temp switch 1 turns on it carries the power out on pin 1. When the switch gets hotter it will also carry power out on pin 2, meant to trigger a relay for fan on high speed.
Mark
Dave Wood
Dave Wood is offline
PostPosted: Tue Jan 27, 2015 10:32 am    Post subject: Reply with quote
what is the reason to swap out the cooling system? I'm guessing a bigger motor was put in? Or existing system needed replaced anyways?
Dave
87 Vanagon GL
rotaecho
rotaecho is offline
PostPosted: Tue Jan 27, 2015 11:23 am    Post subject: Reply with quote
Mark that switch marking helped a lot! Mine doesn't have any of those, so this is a golden nugget. It's much clearer now.
Thank-you!
Mark
-Will
rotaecho
rotaecho is offline
PostPosted: Tue Jan 27, 2015 11:25 am    Post subject: Reply with quote
Well, like many have said:
33yr radiator and pipes. It's ugly, REAL ugly.
My radiator was gunked up bad.
My pipes were rusted, patched, and real real nasty.
The goal is to put a larger engine which I want to do with a properly working coolant system.
It's going to fail, being 33yr, so better to be proactive esp if you plan a conversion or a lot of driving.
-Will
Dave Wood
PostPosted: Tue Jan 27, 2015 1:05 pm    Post subject: Reply with quote
Thanks for the clarification. Good luck with your upgrade
Dave
87 Vanagon GL
rotaecho
rotaecho is offline
PostPosted: Tue Jan 27, 2015 1:15 pm    Post subject: Reply with quote
Thanks, even without upgrading the engine I would recommend this task.
After seeing how bad my radiator, pipes, and hoses were in, I am amazed nothing bad happened.
I have noticed that the temp gauge is lower than it used to be.
Now, to research/figure what the heater hose pipes are that come in next to the coolant hoses. Those were really bad too.
-Will
rotaecho
rotaecho is offline
PostPosted: Wed Jan 28, 2015 9:20 pm    Post subject: Reply with quote
I think I have the radiator lines burped, but I'm kinda curious if this is okay behavior of the gauge.
Before this upgrade the needle idling was a little to the left of the light and when on the highway it was a good smudge to the left of the light.
After the coolant upgrade (SS pipes, new radiator, new radiator hoses, and new temp-switch) the temperature of the needle on the highway stays on the line shown below. When I idle or hit 3rd gear it moves a tad to the right (still before the light). It has not got anywhere near where it used to be.
I'm in St. Louis at the moment (driving back tomorrow). I was curious if this looked to be normal behavior and better heating indication compared to before because of the upgrade? Or if maybe my thermostat is a bit off.
Thanks!
-Will
rotaecho
rotaecho is offline
PostPosted: Mon Feb 02, 2015 9:20 pm    Post subject: Re: 1982 Diesel Vanagon Radiator and Cooling Upgrade Reply with quote
Mark,
The shroud I got was apparently for the AC model. When I was doing the upgrade, I noticed the fan was too small for the mount on the shroud. I fabricated a reducer which isn't working so well (the plastic is giving), but worked in the pinch when I had everything out.
How hard would it be to install a newer AC fan to the 83+ radiator setup? It seems like it may be easier to mount the newer fan on the shroud than draining out the coolant again and lowering the radiator to replace the shroud with another.
Figure you'd have a good recommended course of action here.
Thanks!
You also need the 83+ metal fan shroud, for the small motor fan you have is ok. (the even later bigger fan motor needs special wiring and a matching shroud) You need the 3 wire connector for the later rad temp switch. You need the 3 pin rad temp switch, best to use the one for 86+ , stock setting. Then you need to extend the old temp switch wiring and splice in the 3 wire connector. You will need to do something to hold the top of the radiator firmly in position. The plastic long pipes are bigger diameter so all hoses that attach to the pipes need to have the bigger ends for them.
Mark
Gruppe B wrote:
I am presently bringing back on the road an 1982 Vanagon Diesel.
The existing cooling system is original and in need of replacement.
From the information gathered here I have a list of what I want to do:
-replace front diesel rad with a later model wbx radiator (new front hose too)
-replace rusty front to rear coolant hoses with plastic hoses from an 86 wbx
-replace engine hoses with the silicone greaseworks set
-replace coolant tank from an 84 - 85 wbx
-replace waterpump and thermostat
Is there anything that I'm missing in regards to engine cooling and will all this work together?
Cheers,
Gruppe B
-Will
bowditch
bowditch is offline
PostPosted: Tue May 17, 2016 1:00 pm    Post subject: Re: 1982 Diesel Vanagon Radiator and Cooling Upgrade Reply with quote
So I thought it was appropriate to ask my question here since it is diesel related. I just swapped the steel pipes out for 86' plastic pipes (with some muscle I got both in fine, didn't have to widen anything Laughing) and while doing a coolant flush noticed that when the fan comes on it blasts at full speed on stage two. I left my radiator stock and adapted the pipes so I still have the two fan switches. I replaced the low speed cause I thought it was broken at first but now realize it's coming on full blast at the lower temp. is the relay bad? what's going on? thanks in advance!!
82 Westy AAZ
82 Vanagon 1.6D
bowditch
bowditch is offline
PostPosted: Thu May 19, 2016 8:14 am    Post subject: Re: 1982 Diesel Vanagon Radiator and Cooling Upgrade Reply with quote
I replaced the relay and it still does it. All my contacts are clean. Any thoughts? Also has anyone shown how to upgrade the 82 coolant light to upgrade it with the coolant low warning light?
82 Westy AAZ
82 Vanagon 1.6D
MarkWard
MarkWard is offline
PostPosted: Thu May 19, 2016 11:25 am    Post subject: Re: 1982 Diesel Vanagon Radiator and Cooling Upgrade Reply with quote
On the 82 diesel, the low speed did not have a relay, only the high speed fan used a relay. I just gave similar advice this am. Unplug the switches. Take a piece of wire and jump the two heavy gauge wires that you disconnected from the low temp switch. For low speed, the fan load runs through the switch. The fan must run on low with these two heavy wires jumped.
Now repeat the test with the smaller wires from the other switch. Because they are switching a relay instead of carrying the load, they are a much smaller gauge wire. With those two jumped, the fan must run on high. I am too busy to drag out my manual to look up the actual colors and if the key needs to be in the run position for those tests. In other words the key may need to be in the run position.
If you are able to get both speeds jumping the wire harnesses, then you need to look at the switches. They may look identical, but there should be very tiny print with the operating temp range. Happy testing.
bowditch
bowditch is offline
PostPosted: Thu May 19, 2016 5:04 pm    Post subject: Re: 1982 Diesel Vanagon Radiator and Cooling Upgrade Reply with quote
found a 43 relay for the low coolant light today and wired that up Razz (super easy) and I'll get back with the fan switches. My guess is that the lower fan switch has a gasser switch in it with the lower temp setting.
82 Westy AAZ
82 Vanagon 1.6D
Page: Previous  1, 2
Page 2 of 2
