Subaru Frankenmotor for the Westy
Page: Previous  1, 2, 3, ... 10, 11, 12  Next
a914622
a914622 is offline
PostPosted: Sun Nov 06, 2011 9:55 pm    Post subject: Reply with quote
The early 2.5s are way different short blocks! The 96 used a big cc heads and were the first with longer stroke and shorter rods with smaller dia rod end. (48mm vers 52mm on the 2.2s and 2.5 phase 2) The early 2.5 had failer do to the short rods and smaller bearings.
The phase 2 also got 9 and 10mm oil pumps.
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
D Clymer
D Clymer is offline
PostPosted: Sun Nov 06, 2011 10:23 pm    Post subject: Re: subaru frakenmotor for the westy Reply with quote
Franklinstower wrote:
David C, do you have any knowledge of this build?
Paul
Hi Paul,
I have read about these hybrid EJ22/EJ25 engines on the USMB, but I don't have any firsthand knowledge or experience with them.
I don't see any reason why you shouldn't try it, though. As you said, Phase I EJ25s are cheap and plentiful. It sounds like the head combustion chamber volumes are similar between the EJ22 and the Phase I EJ25, so your cr would still be reasonable.
Another route that seems like a good one to me would be to get a Phase II EJ25 longblock and make adaptors to put the EJ22 intake manifold on the later engine. Without pulling the intake manifold on my EJ25, it's hard to tell how much different the EJ22 intake manifold is, but just comparing the two in the garage today, they seem very similar dimensionally.
I think what you are proposing makes a lot of sense because you already have a running van with the wiring all done. No matter how you look at it, the wiring harness is the most time consuming element of this conversion. You could R&R the engine in a relatively short amount of time.
David
goffoz
goffoz is offline
PostPosted: Sun Nov 06, 2011 11:05 pm    Post subject: Reply with quote
skivan wrote:
The OBD1 small car 'high torque CA special' seems like the ticket if all connections are basically the same. Might be worth asking brian @ small car about it. Though the increase compared to DOHC 2.5 makes it seem a littler rarer. Anybody know what model/year these (OBD1 SOHC 2.5) came out of? http://www.smallcar.com/index.php?dispatch=pages.view&page_id=11
The "one" I've seen 1to1and driven was very impressive. low end torque!!!
The story is...its a 2.5 block, with 2.2 heads, wiring and ECU OBD1..for Kali
Quacks like a 2.2
the trick is the pistons are "special" remachined turbo pistons?
We have a local builder here in NorCal..says its a "Not too difficult" build
He does em for the sand rail/rock jumper crowd.
but has never CARB'ed one
Farfrumwork
Farfrumwork is offline
PostPosted: Mon Nov 07, 2011 9:23 am    Post subject: Reply with quote
I know people with the frankenmotors in their subarus.
There is a difference between the ph1 and ph2 EJ25's blocks, but to get a more freindly compression ratio, go for the Sti short block (EJ257). This will get you closer to 10.5:1 (vs. 11.x:1 with the NA blocks) and has stronger internals.
people spin bearings on Sti's by revving the crap out of them or loading them hard befroe the oil is up to temp. A EJ257 blcok will last forever in a vanagon if you treat it well
Search "Matt Monson" and frankenmotor on legacycentral.org
A local "Souixbe" has one in his '91 legacy wagon. He runs mid-grade here at altitude and has no issues. (Although I would run premium in this setup with my van).
And I would stay away from the delta cams in a van application. I have the "torque grinds" in my '93 turbo leg and have heard many reports of the same cams in the EJ22 which yielda a noticeable lope at idle (which I have in spades - had to increase my idle speed via a custom chipped ECU) <- and that custom chipped ECU is only available for the turbo motors (based of the EJ20 ECU).
I'm going to build a frankenmotor myself in the next few years. Just for the reasons mentioned (more torque and some more HP) - the big gain is in torque, which the small valves/ports on the EJ22 heads really work well to generate. No harness work - bolt in and go!! I'll buy a problem Sti block and have it refurb'd (new Sti blocks are ~$1900 Shocked , but it would be NEW! Smile )
And just to clarify, when you run 2.5l block, you get 2.5l of displacement. It doesn't matter what heads you run (that only affects compression)
sold Sad -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind"
Franklinstower
Franklinstower is offline
PostPosted: Mon Nov 07, 2011 11:20 am    Post subject: Reply with quote
I stopped in Delta the other day and asked them about the torque grind for the Vanagon, he strongly recommended it, He said it would idle fine, and help with the low end torque. Are you sure you didn't get a grind, like the 1000, 1500 or 2,000 grind? Maybe the turbo application also has something to do with the idle lope.
Thanks for the STI block info. I knew the later PH2 SOHC blocks would raise the compression to about 11.3:1, but thought the early DOHC blocks would keep the compression at a more manageable 10.8:1.
As soon as I assemble the parts, I am going to build one too!
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
Farfrumwork
PostPosted: Mon Nov 07, 2011 11:52 am    Post subject: Reply with quote
^^ I bet Delta would say that! Laughing They are good cams, but they DO add lope to the idle. I have the Torque grinds, same as the NA application, the 1000/1500/2000 are for the NA 2.5 SOHC heads.
Lucas of Wildwesty here in Boulder actually had several cam sets for sale due to customers not liking the change at idle (in there suby converted vanagons). I'm sure my turbo motor does react differently than the NA motors (worse) but all acounts from the 2.2 crowd say you will have a noticeble lope. Some may like that though... I kind of like it on my hot rod '93 turbo.
I need to look into it again - like you've found there is lots of information (and misinformation) out there - but I'm pretty sure both NA 2.5 blocks yield quite high compression ratios. The Sti block keeps it reasonable as the block is meant for lower compression in the end (but the 2.2 heads have low volume, raising it back up) - - - not stating anything you don't know already most likely.
I'll see if I can find some documented results...
Farfrumwork
PostPosted: Mon Nov 07, 2011 1:07 pm    Post subject: Reply with quote
more ramblings from various threads...
From Siouxbe (on legacycentral.org):
"I am already driving my 2.2l SOHC heads with the STi short block set-up and I love it!
Use the 4 layer steel OEM Subaru 2.5l headgaskets and you'll be able to run 87 oct. pump gas no problem!
My dyno test showed 125 ft./lbs. of torque at the wheels!"
"IIRC the C.R. is closer to 10.3
BTW the SOA part # for the H.G. I used is 11044AA610 4 layer multi-steel 2.5
I carefully drilled holes to match-up to the 2.2L heads.
End result is it works GREAT!"
Others use Cometic Head Gaskets - you can get any thickness you wish (but I'd go OEM if possible)
Some guy named elwood on nasioc:
"hey all,
I wanted to throw my $.02 into this thread. I just put one of these together, with great results so far.
Ingredients:
94 Leggy Wagon, 5spd, 2.2L with spun rod bearing at 115k miles. ($cheap)
99 (phase 1) 2.5L shortblock, unknown mileage ($super cheap)
98 (phase 1) head gaskets ($23/ea at 1stsubaruparts.com)
The conversion was extremely straight forward. absolutely everything form the 2.2 bolted onto the 2.5. The only trick was on the head gaskets. the coolant passages at the tops of the cylinders didn't line up with the 2.2 head. I used a drill and a dremel to make some new holes in the gaskets to line up. It was kind of a pain to get the edges of the new holes cleaned up on the multi-layered steel gaskets, but it is doable.
The results so far have been pretty rewarding. Using the head volumes on the EJ calcs page, I figure about 11:1 CR with this combo. I've got over 1000 miles on it now. I've run a couple of tankfuls of shell 93 octane and one tank of speedway 92 octane... have not yet heard a bit of detonation.
Performance wise, it's a nice step up from the 2.2. It's not OMG fast, but man is it torquey. Between 2000 and 4000 rpms, it tugs like a V8 compared to the old 2.2. With the 5 speed and 4.11 final drive, it makes for a fun car to drive around town. I put an RS pressure plate in at the same time. I believe it's a little stiffer than the stock 2.2 plate, but I don't think it's quite enough for this motor. It'll slip all the way through 1st with a moderately agressive launch.
It does seem to fall flat at higher revs. It will certainly still out run a stock 2.2 all the way to the redline, but it doesn't seem as fast up high as the 2.5 cars I've been in.
I really don't have any idea what the long-term durability of the setup will be, but if it keeps performing this nicely, without detonation, I'll say it's a highly recommendable setup for someone looking to replace a dead 2.2 or just make a fun car on a budget."
followup:
"15k and counting on mine! and they haven't been exactly "easy" miles." he comes back later with 45+kmi and a-ok
there's more out there to read/sift through, but safe to say the combo works.
I'd probably still go Sti block for a more normal CR (low 10:1 range), or maybe the EJ255 block (2.5l wrx & legacygt) but I'd have to compare the piston volumes.
Franklinstower
PostPosted: Mon Nov 07, 2011 2:37 pm    Post subject: Reply with quote
good info, thanks.
Cometic I believe now makes a 'hybrid' gasket for the 2.5 block and 2.2 heads. just got to call the dude at cometic.
I would still like to see a chart of the different block and head configurations with the compression ratio's...
Paul
YITB
Franklinstower
PostPosted: Sat Nov 12, 2011 10:27 am    Post subject: Reply with quote
i posted a question on the USMB regarding the frakenmotor for a Vanagon - GeneralDisorder - a very knowledgable subbie mechanic stated the following info:
EJ25D compression is about 10.5:1. It's actually the lowest of the frankenmotor combo's. There are quite a few people running a lot higher though without any problems - there's a guy on NASIOC running 12:1 on 89 octane and he says his monitoring software indicates no knock and his ECU isn't pulling his timing at all
It will still be a little lumpy with the torque cam - especially when cold. But it's not terrible. And the '92 harness/ECU is fine. Not as sophisticated as the later stuff but you don't need to rewire it just because of that. If you do rewire it I would go with Mega-Squirt.
The frankenmotor is big on torque - max NA HP on the EJ22 heads is around 185 to 190 - they just don't flow for beans up high. But the torque curve is INSANE - it hops up to about 200 ft/lbs of torque at 1200 - 1500 RPM, then climbs a bit more to around 220 and stays pretty much flat all the way to 5500.
you will have to "retune" your idle air control valve (IACV) by rotating the thermostatic air inlet valve inside it to give the engine more air at idle. The larger displacement and duration of the torque cams causes problems with the engine needing more idle air than the 2.2 valve was setup for.
Boy do I like those torque numbers. Apparently the small valves with the higher compression is where the torque is developed. Reminds me of my old Chevy C-50 dump truck. It had the 350-I V8 - steel crank, 178 valves and a two barrell carb. it had all its torque coming right off idle but had no upper end oomph.
YITB
JeffRobenolt Premium Member
JeffRobenolt is offline
PostPosted: Sat Nov 12, 2011 11:30 am    Post subject: Reply with quote
What years are the EJ25D?
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
Franklinstower
PostPosted: Sat Nov 12, 2011 12:15 pm    Post subject: Reply with quote
those are all of the 2.5 Dohc's - hence the 'D' - EJ25"D" - so '96 to '99 I believe. the block is pretty much identical to the 2.2. so you can just swap all of the 2.2 timing components over.
YITB
a914622
a914622 is offline
PostPosted: Sat Nov 12, 2011 1:13 pm    Post subject: Reply with quote
The 96 ej25D had larger head chambers so the pistons have a smaller dish. Used with the ej2.2 heads you may end up with comprection over 11.5-1.
Hey Im going up to drill the jag calipers today.
jcl
Franklinstower
PostPosted: Sat Nov 12, 2011 5:55 pm    Post subject: Reply with quote
jcl
I see that now, I haven't figured out what the differences are, besides the '96's used HLA's and the later DOHC's all had roller rockers but I do see the '96 2.5's had less power, but required 91 octane. That alone tells me those had higher CR's. Therefore I will have to make sure I am using a '97 to '99 block.
Cool on the drilling of the jag ports. let me know how the turn out. Thanks Jeff.
YITB
Franklinstower
PostPosted: Sat Nov 12, 2011 10:17 pm    Post subject: Reply with quote
i found further info that confirms what A914622 says - the '96 had much smaller dishes in the pistons - 8-10cc's so using the EJ22 heads on that would yield 11+:1 cr. 97-98 blocks are just standard ej25d blocks and the '99 is the best 25D block because it's actually a 253 with 25D pistons. 8 bolt bell-housing, 52mm rod journals, and #5 thrust bearing. It's the ultimate 25D. So building a frankenmotor with the 2.2 heads and intake is best done on the 97 to 99 blocks with the '99 being the strongest.
YITB
Escorial Syncro Premium Member
Escorial Syncro is offline
PostPosted: Sat Dec 03, 2011 8:22 am    Post subject: Reply with quote
Cool thread, great stuff. But a question from a guy not experienced at all in engine building:
If you do a swap like this, say a '99 EJ25D block and '94 EJ22 heads, do you then have an interference engine? Meaning if you snap the timing belt are you going to have piston/valve contact?
Thanks, Joel
Joel Lane
1985 Vanagon converted to syncro, ALH TDI w/GTB2056 turbo, Reimo clone top with Westy interior
2002 Toyota Tundra 4x4
oneburnedvan
oneburnedvan is offline
PostPosted: Sat Dec 03, 2011 10:44 am    Post subject: Reply with quote
Hi,
I traded some email with pro subie / vanagon gentlemen several months ago. I think he's located in the Portland area. Here are some highlights with Ken's info. (Since he advertised on Craigslist, I figure he wouldn't mind me putting it out there.) I did not use his service so this is not a recommendation, just information. But should my 2.2 fail, I'd certainly consider this route. Thanks for a great post. -TG
EMAIL 2_____________________
Yes I ran one for a long time in my auto but now running a quad cam engine in it and putting a highbred in one of the Syncros I have, no interference issues, I use 2.5 head gaskets and I use 2.2 rods which are .050 shorter which lowers the deck hight and lowers the compression, I think this is the best engine for a Syncro as they put out brutal bottom end torque, the smaller valves give better lower end torque and the shorter rods give more rod angularity which gives better lower end torque, they flatten out after about 5500 rpm but under 4000 they will beat any other 2.5
Also you could put a 2.5 quad cam in with no mods to the van but some minor mods to the engine like pull off the EGR valve and switch the wire loom under the intake manifold to the 2.2 loom so as to match up to the loom in your van.
Also for a Syncro I think its a must to go to a 11mm or a 12mm oil pump as you need more oil pressure at low rpm when your lugging it around in low gear as that is torture on rod bearings.
Ken
EMAIL 1___________________
Yes done many conversions, I have two of my own an automatic and a Syncro.
Yes if its a strait forward replacement I would do it for $1800 but I don't do the whole conversions for costumers any more as I am to busy, no the overbore will not increase the power any but I can do a highbred with a 2.5 block and 2.2 heads and it drops in with no modifications.
Ken Welter
[email protected]
LL# 360-834-4089
cell# 360-253-0703
Franklinstower
PostPosted: Sat Dec 03, 2011 11:02 am    Post subject: Reply with quote
I just came home with a 97 2.5 block. no idea of the condition of the block other than the guy i got it from said it needed a head gasket. I am going to start cleaning it up, pull the heads etc. Although My Honey Pie just gave me quite the to do list before I can start any more engine projects. The appeal of all that torque is what really intrigues me.
Paul
YITB
Last edited by Franklinstower on Sat Dec 03, 2011 11:37 pm; edited 1 time in total
Syncroincity
Syncroincity is offline
PostPosted: Sat Dec 03, 2011 6:19 pm    Post subject: Reply with quote
Thanks, Joel
No, the SOHC heads, regardless of displacement or shortblock, will be non-interference. You do, however, have to be conscious of compression ratio as there are several versions of pistons and you can end up with super-high compression if you use the wrong combo. Extra-thick metal headgaskets are available to adjust for this.
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
a914622
a914622 is offline
PostPosted: Sat Dec 03, 2011 9:19 pm    Post subject: Reply with quote
Thanks, Joel
The 2.5 SOHC from a 2001 is an interference motor.I know this from first hand mistakes. If you brake a timing belt on a 2.2 you will also be doing valve job! again first hand. I think all the subys are interference engines. It only takes a tinny bump to bend the valves. If your off 3 teeth on the belt valves hit.
jcl
syncrodoka
syncrodoka is offline
PostPosted: Sat Dec 03, 2011 9:46 pm    Post subject: Reply with quote
What year? Some EJ22s are supposed to be interference and others aren't.
Page 2 of 12
