berniedd1 Samba Member
Posted: Sun May 30, 2004 8:53 am Post subject: |
| Thearn wrote: |
That's never happened to me, how exactly do you shift with no clutch? Sounds like fun...and can you even start it without the clutch? Maybe i'm too young, but i'm sure it will happen eventually  |
First your get the transmission to neutral from an engaged gear , and then try get the engine to turn at the same speed as your transmission input shaft. Once the flywheel and input shaft are turning at the same RPM, you slide the shift stick to the gear you want. Takes a lot of practice. Once you get the hang of it, you can shift without grinding and clashing of gears. |
angela Southern Dumbell
Posted: Wed Jun 16, 2004 2:20 pm Post subject: |
| happened in my 1st bug when i was 16. i got a ride home, my bf at the time took it to his house to fix the next day. the 2nd time was in my 65. i had read before how to drive w/out in my idiots manual, so i figured i'd try it. luckily i had just gotten a new battery earlier in the week. i think i drove her like that for 2-3 days before i got a chance to replace the cable. i kinda liked it. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Fri Dec 09, 2022 7:26 pm Post subject: Re: Driving with no clutch cable is fun. |
Draging this one from the ashes,, Good to hear your tales of the clutch peddle stuck on the floor
70 bus 200 miles from home,just got off the freeway,to take the backroads ,and bang cable breaks,,shit,, had to hit about five intersections with lights crap got caught by two or three, good old battery & starter got me us back to the freeway,I figured less 'stops the better' what a buzz kill that was,,got home on time  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3351 Location: Birmingham, Alabama
Posted: Mon Jan 02, 2023 7:46 am Post subject: Re: Driving with no clutch cable is fun. |
When I was 15 and learning to drive and I got the hang of driving a manual, my dad taught me to roll start and drive with no clutch because he said "one day your clutch cable will break and I'm not going to come get you."
Fast forward a few years and I was leaving class at a community college, the cable snapped as I was backing out of my parking space. Dad was home so I called him and told him. His response was "And what do want me to do?" I told him to come with the tow bar because I had to go through a lot of traffic to even get to the highway. He then goes "Well you want to get home don't you?" Click. and he hung up the phone  _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 115 Location: Sacramento
Posted: Thu May 23, 2024 3:06 pm Post subject: Re: Driving with no clutch cable is fun. |
| Not a clutch cable but hydraulic clutch on my Class 9 race car. I didn't have the jamb nut on and lost the adjusting nut = no clutch. I looked over the entire car and all my parts bags and no 5/16 fine thread nuts. Finished the lap with no clutch which included hills and the need for all 4 gears but made it to the pits for repairs. |
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 764 Location: Riverside,CA Econo Motors
Posted: Sat Aug 31, 2024 8:11 pm Post subject: Re: Driving with no clutch cable is fun. |
| had a jeep with hydraulic clutch burn against exhaust... same dealio, start off at the light in 1st but never had to slam shift, all in timing baby smooth as silk... drove it a whole day like that until my hose came in... good times |
oprn Samba Member
Joined: November 13, 2016 Posts: 15203 Location: Western Canada
Posted: Wed Jan 01, 2025 7:34 am Post subject: Re: Driving with no clutch cable is fun. |
I just found this thread, wow guys! "Slam shift, Bang shift"! Not in my car... ever! There is no need for that! As several have pointed out, with a little finesse you can shift all day long without even a tooth tick if you practice a little. Like 63 vwnotch says, it's all in the timing.
There is a sweet spot on the gas peddle where the engine is neither driving the car or holding back. You can feel it by putting a bit of pressure on the shifter. When you hit it the transmission will just slip out of gear smooth as butter.
Now you need to slowly let off the gas peddle and with the same light pressure on the gear shift, feel for the same sweet spot as the RPMs come down against the next gear. When you hit that magic speed the transmission will slip into the that gear, again, as smooth as butter and off you go.
If you miss it... you lose! Might have to start over from a stop but in the higher gears you have time to try a couple of times before you lose too much momentum.
Now that you know how, get out there and practice, a lot! Get good at it, show off to your friends! If you are doing it right they can be sitting next to you and have no idea that you are not using the clutch. You will have to point it out to them!
I have done this in every standard shift vehicle I have ever owned. About 10 of them and they were not all VWs. It works on any standard transmission. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 862 Location: Eastern north carolina
Posted: Fri Jul 11, 2025 3:48 am Post subject: Re: Driving with no clutch cable is fun. |
| I agree, no need to slam gears. In the early 80s I was living in Fullerton, CA and I went to look at a 67 sunroof squarebacks for sale in Huntington beach about 30 to 35 miles away. The owner told me on the phone that the clutch was not working. I looked at it, liked it. Bought it and drove it home trying to time the shifts as the rpms came down. Not a lot of fun in traffic as you have to try and keep rolling, but it can be done. Bob |
