Windshield Wiper Wiring
Page: Previous  1, 2
alidabiri
alidabiri is offline
PostPosted: Mon May 19, 2025 8:59 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
Eric&Barb wrote:
alidabiri wrote:
Sorry. that didn't help or answer the question.
My question is:
what color wire of the above color wires provide the power to the motor?
Look at the 1967 wiring diagrams a couple of posts below what jhoefer posted and combine those two bits of info.
that didn't help either.
I just want to know which color wire(s) I need to connect to the power source to test the motor, please.
EVfun Premium Member
EVfun is offline
PostPosted: Mon May 19, 2025 9:42 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
On a 1972 Super Beetle the power wire to the motor is black/gray, terminal 53a on the motor. The motor may not run, or only run briefly then stop, if you hook power to that wire. Internally, it will only feed power to the motor until the wipers are in the park position. I believe the black wire, terminal 53 on the motor, is the the low speed power and the place to put power if you want the motor to continue running until you disconnect it. I'm basing this on reading this VW wiring schematic, and information from this user.
Warning: these cars are now over 50 years old and previous owners may have replaced broken wires. Previous owners often don't respect wire colors, so it is best to verify the terminal numbers.
Wildthings wrote:
Eric&Barb
Eric&Barb is offline
PostPosted: Tue May 20, 2025 7:30 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
alidabiri wrote:
it's a 72 VW super beetle wiper motor.
Seems the other bit of info needed is what are you trying to install the '72 wiper motor into??
In Stereo, Where Available!
far rider Premium Member
far rider is offline
PostPosted: Sun Jul 20, 2025 6:36 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
I have a 67 ww motor and want to test it. I understand the power comes from the switch. Correct? So how can I directly connect the motor to a battery. Where does the positive terminal connect? Thanks for helping an electrically challenged individual.
67 zenith blue sunroof
Contentment; when what you have is what you want.
Eric&Barb
PostPosted: Tue Jul 22, 2025 6:33 pm    Post subject: Re: Windshield Wiper Wiring Reply with quote
A little more complicated than that due to self parking and dual speed.
This should cover that.
https://www.thesamba.com/vw/forum/viewtopic.php?t=410119&highlight=1967+wiper+motor
PostPosted: Wed Jul 23, 2025 5:59 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
Just for curiosity- why is there a 31 listed (on far right in pic) but no terminal? Is that VWs way of telling you it’s a ground?
aquifer Premium Member
aquifer is offline
PostPosted: Wed Jul 23, 2025 7:09 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
Yes I believe that's what it means. I just finished rebuilding my wiper assembly and asked myself that same question when I was putting everything back together. There is a copper (brass?) strip that goes from the mounting screw to the chassis to ground it because the assembly sits in rubber mounts.
Project vehicles:
1967 Beetle #1. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1967 Beetle #2. Bought in 2024, mostly original, October 1966 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Original brown rubber floor mats for a '67
Original gazelle seat upholstery for a ‘67
PostPosted: Thu Jul 24, 2025 8:29 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
Trying to finish up my wiring. Car is a. 61 but I’m using a 62 harness and upgraded to 12 volt. The schematic shows dome light wire connecting to 54 on ww switch. I m using a 67 wiper switch and it doesn’t have a 54 terminal any help to sort this out would be appreciated. TIA
Eric&Barb
PostPosted: Thu Jul 24, 2025 10:47 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
The below image from the link last posted.
PostPosted: Thu Jul 24, 2025 10:51 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
Thanks Eand B. Saw that and used it but there’s no 54 terminal on the 67 switch. So I’m trying to find out where to connect the wiring dome harness per the diagram which shows a black wire to terminal 54.
Eric&Barb
PostPosted: Thu Jul 24, 2025 11:01 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
If you look at that wiring diagram detail all but one wire goes from switch to wiper motor. Guess where that one wire that does not go between the switch and wiper motor goes to.....
Eric&Barb
PostPosted: Thu Jul 24, 2025 11:08 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
As for where to connect the interior light positive wire it goes to to the fuse box.
Y is the interior light and the two Vs are the interior light grounding switches.
PostPosted: Thu Jul 24, 2025 11:09 am    Post subject: Re: Windshield Wiper Wiring Reply with quote
Thanks again E and B!
Page: Previous  1, 2
Page 2 of 2
