Quick and Easy WBX Oil Cooler Seal Replacement
Page: Previous  1, 2, 3  Next
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Feb 06, 2015 10:21 am    Post subject: Reply with quote
Thanks for the write up.
I don't the part in hand, so don't know if the end of it could be double nutted, but would an expansion bolt work to remove the pipe?
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 10:33 am    Post subject: Reply with quote
Thanks Nut Wink
The expansion bolt was tried in another thread and snapped clean off inside the pipe, thus my call to Andrew to ask for other ideas.
I am sure there are plenty of tools that could be used, I went with the advice and the T55.
Snap On sockets of this size are $8 shipped off eBay, the internal pipe tool at Blowes, a POS by my standards, was $12+tax Rolling Eyes
Vanagon Nut
PostPosted: Fri Feb 06, 2015 1:15 pm    Post subject: Reply with quote
cool. Thanks. Ironically, your procedure may help out on my Jetta swap. i see an oil leak near the oil cooler. IIRC, it uses the same or very similar oil cooler parts.
Neil.
(VW Gas I4)
VE7TBN
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 1:31 pm    Post subject: Reply with quote
Yes, most VWs and Audis share this same cooler and seal.
I have talked to so many since posting this and it really doesn't matter whether it is a Vanagon or not...great little ditty to remove the oil pipe from whatever engine it may be attached to.
The Vanagon Syncro gives the least amount of room to work, so those who have seen many different cars appreciate getting it done, in the driveway, while snowing...in under a half of an hour Wink
Howesight
Howesight is offline
PostPosted: Fri Feb 06, 2015 2:28 pm    Post subject: Reply with quote
There are a bunch of threads on the topic of "Just bought a Westy and what should I look at or replace?" Similarly, there are a few on the topic "Going on a long trip. What preventive maintenance should I do?"
Dylan's thread on this gasket needs to be linked to those threads. Great pics. Having suffered this oil cooler seal failure years ago in mid winter on a logging road, I could have used this post!
'86 Syncro Westy SVX
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 2:46 pm    Post subject: Reply with quote
I will do my best to link it when I read those posts from now on.
That is a really good idea.
I am going through all of my WBX powered vans that have sat for awhile now, 1. to inspect the gasket and 2. replace any that look like trouble.
The ones I drive regularly and have owned for years have had this replaced at some point, when I resealed the heads most likely.
Placed an order today for more seals from VW Wink
Change your fuel lines AND change your oil cooler seal will be the new mantra Laughing
Altoona
Altoona is offline
PostPosted: Fri Feb 06, 2015 3:20 pm    Post subject: Reply with quote
Yep, did this to my Passat one Christmas. Thank goodness the local dealership was open that day. Plenty of room in there though, way easier than the Vanagon. Thanks for the tip on the T55, I'll have to pick one up for the tool box.
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 3:26 pm    Post subject: Reply with quote
You are welcome.
Andrew was swapping out the same seal on a Passat when I talked to him.
snowsyncro
snowsyncro is offline
PostPosted: Fri Feb 06, 2015 3:36 pm    Post subject: Reply with quote
Thanks for posting this Dylan. Like SyncroJael, I just did this. It took about 4 hours, 3 hours and 32 minutes was dealing with those stupid coolant pipes. It did not occur to me to remove that threaded pipe. I have 3 more vans and 3 Passats to do, so you are going to save me a lot of time. Thanks!
RonC
insyncro
Banned
insyncro is offline
PostPosted: Fri Feb 06, 2015 3:38 pm    Post subject: Reply with quote
RonC
Well Ron,
If billing by the hour, disregard this thread in entirity Wink
Just kidding, glad it will allow you a little "me" time around the shop.
mrlimbo
mrlimbo is offline
PostPosted: Sat Feb 07, 2015 7:53 am    Post subject: Reply with quote
I've had to do them in the van.. nice details.
I did the last one while the engine was on the stand getting new headgaskets. I had one blow out on a very cold day, like we've had recently. Luckily, it was in the driveway and didn't damage the engine. Just an environmental mess.
BTW, the EuroVan takes the same seal.
-Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
'67 Kombi- April, its not original and I don't care.
'87 Vanagon GL (daily driver)
'01 Jetta Honey's car
Looking for a Vanagon weekender or Escorial green camper.
insyncro
Banned
insyncro is offline
PostPosted: Sat Feb 07, 2015 8:00 am    Post subject: Reply with quote
This is why I didn't even move the van and fixed it right there.
I spent more time trying to get all the oil up than fixing the seal.
Luckily the ground is frozen solid.
Damn those oil drippers...leakers Evil or Very Mad
mrlimbo
mrlimbo is offline
PostPosted: Sat Feb 07, 2015 8:19 am    Post subject: Reply with quote
If its not leaking.. its out of oil! Smile
insyncro
Banned
insyncro is offline
PostPosted: Sat Feb 07, 2015 8:23 am    Post subject: Reply with quote
The sound a dry oil pump makes is worse than fingernails on a chalkboard.
You crack me up Jim Laughing
Hope all is well with you.
Get ready for Marcus, our next winter friend Exclamation
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sat Feb 07, 2015 8:46 am    Post subject: Reply with quote
I see you had an MGB, too! Smile
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Sat Feb 07, 2015 8:52 am    Post subject: Reply with quote
Just ordered up that T55 bit and the loctite 518 off amazon. Thank you for posting this. I do this job every couple of years as PM since we get really hard freezes here in MT and have had this seal burst before. Before this post i have always done this procedure the hard and dirty way, always dredding having to do it. Thanks again for the tips!
insyncro
Banned
insyncro is offline
PostPosted: Sat Feb 07, 2015 8:56 am    Post subject: Reply with quote
You are very welcome.
Glad to be of assistance.
Let me know what you think of the 518.
Just coat the seal all around and install.
In my experiences it really helps prolong the life of Orings and keeps them plyable.
It is tough to get off your fingers, hence the nitrile gloves in my list of needed tools.
It smells like candy, but I wouldn't eat it Laughing
kamzcab86
kamzcab86 is offline
PostPosted: Tue Feb 10, 2015 12:15 pm    Post subject: Reply with quote
Bumping this back up to say...
insyncro wrote:
I am honored if this ends up in the FAQs / Stickies Very Happy
...it's now in the FAQ Cool (was out of town for a concert and for some kayaking at Lake Mohave -- won't give the weather report Wink -- hence the delay).
Also, all three of my VW's, spanning 3 decades and 3 very different engines, use this same oil cooler Brick wall and all three have been worked on: The Cabriolet's cooler was leaking externally and internally (oil mixing into coolant); cooler and seal replaced (not that bad of a job since it's an I-4). The van's was leaking externally and the hoses were shot; replaced everything at the same time, including the cooler... PITA! The Jetta's blew out the morning following a freak snow storm up north; had the O-ring replaced at a shop so I don't know how "easy" of a job it is on a 12V VR6 (dropped it off and it was done by the time I got back from a river trip shuttle a day later).
2016 Golf GTI S
insyncro
Banned
insyncro is offline
PostPosted: Tue Feb 10, 2015 12:22 pm    Post subject: Reply with quote
Thank you Exclamation
By the sounds of it, many deal with this pesky Oring.
This thread hopefully gives a few a leg up on the process to replace it.
Merian
Merian is offline
PostPosted: Tue Feb 10, 2015 2:05 pm    Post subject: Reply with quote
how long does that O-ring usually last?
Page 2 of 3
