Joined: April 27, 2002 Posts: 6793 Location: Pentwater, Michigan
Posted: Thu Jul 17, 2025 5:03 am Post subject: Re: 62-65 headlight/parking light wiring question |
Remove the parking light wires from the bulb holder and insulate any bare ends. Move the turn signal wiring and route them to the headlight bucket. Depending upon year there is one wire or two. Connect the turn signal wire to the power for the former parking light bulb connection and install the headlight. _________________ Roads Scholar
Member# 2059 |
far rider  Samba Member
Joined: August 30, 2005 Posts: 967 Location: Rutland, VT
Posted: Sat Aug 09, 2025 2:18 pm Post subject: Re: 62-65 headlight/parking light wiring question |
Here’s another headlight question. I’m finally testing out my new wiring harness. 12 volt. Driver side headlight is fine . Passenger driving light also good Problem- can’t get the passenger headlight to light. Fuses all good. Power from headlight switch coming into fuse block. Passenger headlight wires do not light at fuse block with test light. Ideas? _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1449 Location: San Diego
Posted: Sat Aug 09, 2025 2:57 pm Post subject: Re: 62-65 headlight/parking light wiring question |
far rider wrote: |
Here’s another headlight question. I’m finally testing out my new wiring harness. 12 volt. Driver side headlight is fine . Passenger driving light also good Problem- can’t get the passenger headlight to light. Fuses all good. Power from headlight switch coming into fuse block. Passenger headlight wires do not light at fuse block with test light. Ideas? |
Possible short in the light circuit that caused the fuse to blow? Check for loose/broken wires in the headlight plug. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Sat Aug 09, 2025 3:03 pm Post subject: Re: 62-65 headlight/parking light wiring question |
Thanks Oldschool but no fuses blew and wires are a brand new harness. I checked the connection in the headlight and all is good. _________________ 67 zenith blue sunroof
Posted: Sat Aug 09, 2025 3:35 pm Post subject: Re: 62-65 headlight/parking light wiring question |
Oops. My bad. Had the white wire to the pass headlight on the wrong terminal. Now to figure out the rest. _________________ 67 zenith blue sunroof
