Drilling a 36hp crank and flywheel for 8 dowels
Page: Previous  1, 2
RolandD
RolandD is offline
PostPosted: Sat Jan 11, 2025 5:55 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Thank you for the confirmation
Roland
pig-pen
pig-pen is offline
PostPosted: Sun Jan 26, 2025 7:21 am    Post subject: Re: Drilling a 36hp crank and flywheel for 8 dowels Reply with quote
so... just wondering... if a 356 flywheel is 8 dowel and same 109 teeth, and same 180mm clutch, and same 24mm clutch depth... could you not just use one of those?? A 356 flywheel I mean. Will that not just go straight in?
1954 L227 Type 113
1964 L31 Type 265
esde
esde is offline
PostPosted: Sun Jan 26, 2025 3:11 pm    Post subject: Re: Drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I have read that you need to use the 356 gland nut also.
AA makes a lightened 356 flywheel that is cut to accept a 200mm later disc and pressure plate, if managing the power is a concern.
modok wrote:
pig-pen
pig-pen is offline
PostPosted: Sun Jan 26, 2025 5:33 pm    Post subject: Re: Drilling a 36hp crank and flywheel for 8 dowels Reply with quote
shorter gland nut maybe? cant see any other reason
just interesting the the OP was going to copy the drilling of a 356 flywheel... why not just fit it?
1954 L227 Type 113
1964 L31 Type 265
esde
esde is offline
PostPosted: Sun Jan 26, 2025 8:54 pm    Post subject: Re: Drilling a 36hp crank and flywheel for 8 dowels Reply with quote
See page 2 of this for more info
https://www.thesamba.com/vw/forum/viewtopic.php?t=799156&start=20
Since posting this question, I have just used an 8 dowel flywheel from DPR to make a template, not too hard to do.
modok wrote:
Page: Previous  1, 2
Page 2 of 2
