Automatic Transmission Trouble?
Page: Previous  1, 2
SCM
SCM is offline
PostPosted: Sun May 11, 2025 9:26 am    Post subject: Re: Automatic Transmission Trouble? Reply with quote
clamay wrote:
I have a 91 Carat with automatic transmission.
About 2 years ago I had my transmission rebuilt by GTA. Since then (20K miles) it has worked well, no issues. Yesterday I was involved as an assist vehicle driver for a 100 mile bicycle event. I drove around the back roads of beautiful Skagit Valley tending to the needs of the bike riders. I made many stops and the van ran great, shifted great, no issues. At the end of the day I was offloading stuff at a storage locker. When I started the van and put it in reverse it just creeped back. When I gave it more gas the engine would rev but the van would not move any faster. When I put it in forward, the same thing happened. It would move but only at a creep. I had 2 miles to go to my home so I limped along at 5mph with my flashers on. When I got home I checked under the van, no leaks. I checked the Trans fluid level in Park at idle and it was slightly above the full mark. It looked clean but it was not very warm, maybe 80 deg. F. Any ideas of what is going on?
I would reach out to GTA. I've had a couple questions for them since my rebuild and they've been very responsive.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
clamay
clamay is offline
PostPosted: Sun May 11, 2025 9:41 am    Post subject: Re: Automatic Transmission Trouble? Reply with quote
Good call SCM. I will contact them on Monday. Thanks for the reply.
91 Carat, automatic, GW 2.2, GW EFI, Peloquin TBD
When you come to a fork in the road, take it. --Yogi Berra
kamzcab86
kamzcab86 is offline
PostPosted: Sun May 11, 2025 9:59 am    Post subject: Re: Automatic Transmission Trouble? Reply with quote
In the meantime, browse the auto trans troubleshooting manual.
~Kamz Anxious
2016 Golf GTI S
MarkWard
MarkWard is offline
PostPosted: Mon May 12, 2025 6:35 am    Post subject: Re: Automatic Transmission Trouble? Reply with quote
How does the van roll in neutral. A brake sticking on would cause the same symptom.
clamay
clamay is offline
PostPosted: Mon May 12, 2025 4:57 pm    Post subject: Re: Automatic Transmission Trouble? Reply with quote
Rolls fine in neutral, no brake drag. Also it does work in reverse. Based on the Troubleshooting manual referenced below it could be the forward clutch plates burnt or the forward clutch plate diaphram spring broken. Any other ideas? Thanks for the reply.
Wildthings
Wildthings is offline
PostPosted: Mon May 12, 2025 6:26 pm    Post subject: Re: Automatic Transmission Trouble? Reply with quote
Since the failure happened fast, it sounds like something broke or jammed.
xflyer
xflyer is offline
PostPosted: Wed May 14, 2025 7:31 pm    Post subject: Re: Automatic Transmission Trouble? Reply with quote
Clamay, your best bet is to check with the trans rebuilder. They should know what can happen.
1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C
Page: Previous  1, 2
Page 2 of 2
