Rookie mistake, with pictures.
Page: Previous  1, 2
dasbulliwagen
dasbulliwagen is offline
PostPosted: Thu Jun 05, 2025 6:46 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Skulptorchaz wrote:
Dasbliiwagon,
That is interesting!!! I am still contemplating what to do. I will look into that and see if I can find some. I assume they can still be bought. I'm hoping they also give the comparison.
Thanks!
A quick search finds AA Performance, Jbugs, and Dunebuggywarehouse has them available.
Skulptorchaz
Skulptorchaz is offline
PostPosted: Thu Jun 05, 2025 7:26 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
So, Wagon18, are those drums acquirable?
I'm sorry, I'm just trying to understand. I totally appreciate your time and help!!
Are the '72 onward still wide five? (which is the wheels I have on it.)
Thank you all!
Chaz
Skulptorchaz
PostPosted: Thu Jun 05, 2025 7:28 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Thanks Dasbulliwagon!!!!!!
(I think our messages crossed in the "Net''.)
wagen19
wagen19 is online now
PostPosted: Thu Jun 05, 2025 8:13 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Thank you all!
Chaz
Yes, all things have 5 lug wheels with LK 5 x 205 mm.
I´m thinking about one used drum, just for testing at first.
Find someone with a IRS thing, have a look, evtl. take one rear wheel off and do some measuring.
If it´s not enough, the shorter torsion bars and spring plates can do the rest.
https://www.csp-shop.de/raeder-bremsen/bremstrommel-hinten-501-615-181-13227a.html
https://www.seefeldt.de/de/bremstrommel-hinten-vw-...gLpSx_Pp7T
wagen19
PostPosted: Fri Jun 06, 2025 3:15 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Thank you all!
Chaz
Just found adds with pics for the two versions of used rear Thing drums, already located in the USA. You need, can use the version with the straight ribs (only) plug and play.
https://www.thesamba.com/vw/classifieds/search.php...=rear+drum
oprn
oprn is offline
PostPosted: Fri Jun 06, 2025 4:11 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Just curious here... any chance the early IRS Bus drums are the same as the IRS Thing drums? I am running '68 Bus drums on the rear of my rail but I also have the Bus trailing arms, axles and wheel bearings so don't know if the splines in the drums are the same or not.
wagen19
PostPosted: Fri Jun 06, 2025 4:50 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
That´s something different!
From Aug 63 onwards, the Bus has the bigger and longer splines, shaft diameter 35 mm, as well as a 46 mm nut for the brake drums.
The Thing, both models, swing axle and IRS have the thinner 30 mm shafts and splines, brake diameter allways only 230 mm and allways the small 36 mm nut.
Rear Bus drums with LK 5 x 205 mm till 7´70:
it´s not a question of IRS or swing axle.
From 8´63 to 7´70 there was the same size of brake shoes, brake 250 x 45 mm, shaft 35 mm, nut 46 mm. (for T1 with swing axle and T2 with IRS)
Skulptorchaz
PostPosted: Fri Jun 06, 2025 7:34 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Awesome. Thanks ORPN AND Wagen19!
Skulptorchaz
PostPosted: Fri Jun 06, 2025 7:46 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Wagen19, so to be clear, the drums just need to be "straight spoked". A person raised another question on another site about the stub axle. I'm assuming that is not an issue but, it would seem that it needs to be longer?? Just making sure.
I TOTALLY appreciate ALL the help!!!!!!!!!!!!!
BTW, I found these.
https://www.jbugs.com/product/181501615A.html
Moores has these:
https://mooreparts.com/products/empi-181-501-615a-vw-rear-brake-drum-volkwagen-thing-1973-1974
A bit saltier.
wagen19
PostPosted: Fri Jun 06, 2025 8:23 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
BTW, I found these and I also think Moores VW Parts has them.
These drums seem correct for IRS Thing with original 230 x 40 mm brake, so fitting on your car. (but not knowing the Taiwan quality)
As long you have a stock IRS trailing arm with stub axle from Beetle, Type 3 or Thing with a 230 x 40 mm brake, it fits plug and play.
(issues with IRS thing drums you only can get with some swing axle cars pre 8´67.
IRS came 8´67, model 68 and at the same time the new 230 x 40 mm rear brake with longer splines also for type 1.
To cool down your nervs, you can test fit a 68 onwards Beetle 4 lug drum. If it fits your axle stub and braking system, a IRS Thing drum will fit too!
But what I don´t know is, what kind of drum and brake you have actually installed. (numbers and pics?)
didget69
didget69 is offline
PostPosted: Sun Jun 08, 2025 10:57 am    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Get original Thing drums - the Asian drums are questionable
regarding quality.
BNC
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
wagen19
PostPosted: Sun Jun 22, 2025 2:38 pm    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Only interested, if the "problems" are solved meanwhile and if so, with what parts or methods.
Thanks
Skulptorchaz
PostPosted: Sun Jun 22, 2025 3:33 pm    Post subject: Re: Rookie mistake, with pictures. Reply with quote
Thanks gents!!!! I REALLY appreciate all the help!!!
Page: Previous  1, 2
Page 2 of 2
