Beru coil
Page: Previous  1, 2
EVfun Premium Member
EVfun is offline
PostPosted: Fri Oct 31, 2025 12:58 pm    Post subject: Re: Beru coil Reply with quote
phil60 wrote:
Sorry for delay - life got in the way. I managed to find my multimeter to test the coil. Had a bit of trouble as the leads needed to be pressed hard into the meter before I could get a consistent reading. I will probably replace the meter. Anyway not having done this before I looked it up on youtube (what did we do before?). The first thing it said to do was find the resistance for the meter itself and this showed 0.5 Then the figure I got for the coil was 1.8 which makes an overall resistance of 1.3 Is this close enough to the 1.5 which has been suggested above?
I would run it. The worst that can happen is somewhat reduced point life.
Wildthings wrote:
Ovally
Ovally is offline
PostPosted: Fri Oct 31, 2025 9:15 pm    Post subject: Re: Beru coil Reply with quote
Here are measurements of some German Bosch 6V coils done by "tasb". Anything between about 1.2 ohms and 1.5 ohms is fine.
https://www.thesamba.com/vw/classifieds/detail.php?id=2755056
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
phil60
phil60 is offline
PostPosted: Sat Nov 01, 2025 8:45 am    Post subject: Re: Beru coil Reply with quote
That's great - many thanks. I'll give it a go and keep an eye on the points.
Page: Previous  1, 2
Page 2 of 2
