Where to install an hard start relay ?
Page: Previous  1, 2, 3  Next
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Oct 28, 2025 8:25 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
62ItalianRagtop wrote:
What's the risk of not using it?
Burn up the relay, if so you'll need to bypass it to start the engine. Connect the wires running to the 85 and 87 terminals together.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Oct 28, 2025 10:26 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
You can see in the 12V Bosch WR1 diagram above that they used a 15 amp fuse and I've seen those blow. And if you look up the specs, you'll see why. The pull in current is very brief but it can go a lot higher than 15 amps.
We always changed those for 25 amp fuses.
Andy T.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Tue Oct 28, 2025 10:47 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
Here's where I installed a hard start relay on my 1967 beetle.
The current draw is not exceptionally high so don't over think the wire length. It's only powering the solenoid, not the entire starter motor.
Robert in Memphis
Engine rebuild thread
62ItalianRagtop
62ItalianRagtop is offline
PostPosted: Thu Oct 30, 2025 1:49 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Thank you very much !!
So should I use a 25amp fuse ?
I ordered this fuse box and I will install it on the red cable from WW relay to battery positive (30 pin on realy).
https://www.amazon.it/dp/B005BP55PO?ref=ppx_yo2ov_dt_b_fed_asin_title
LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/
The Android
PostPosted: Thu Oct 30, 2025 9:50 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
We never had any pop at 25, but those were all 12V applications.
6V, by nature, has higher current draws. According to that VW chart, the holding current on 6V was 18 amps, so you need go at least with a 20 amp fuse, and I'd start with 25.
Oh, you're going with an GBC style fuse then. The fuse holder on the WR1 was a ATC style blade fuse and that's what I was talking about when I was talking fuse sizes.
10 years ago, just to have around, I bought a couple of generic 12V power supply relay kits on eBay, these came with ATC fuse holders. And since I have them kicking around already that's probably what I would use.
Andy T.
62ItalianRagtop
PostPosted: Fri Oct 31, 2025 1:36 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Thank you, I'll update you with photos of the assembly.
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Fri Oct 31, 2025 6:21 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Take the relay and harness, a piece of paper and a pencil. Sketch out the relay, which color wire comes from which pin on the relay, and draw where you plan to connect that wire on the car.
Then learn how the electricity should flow, beginning at the battery, when you switch the ignition key on, then where it should go when you move the key to Start.
If the kit you bought doesn’t not have instructions, or no fuse is mentioned, understanding how it all works will also inform you as to whether you need to splice a fuse into the circuit. They can’t hurt but often are not needed. A relay just moves the power connection to the powered component- this case the starter- away from some other switch. In this case, the ignition switch. If the ignition circuit wiring is already protected by a fuse, then the relay will be as well.
Once when YOU are comfortable with understanding how it all should work, only then should you wire it up.
The Android
PostPosted: Fri Oct 31, 2025 8:41 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Now, in the VW, there IS NO FUSE for the starter solenoid circuit. It might use the fuse panel as a junction point but it does not pass through any fuse. The igntion switch gets "raw" terminal 30 in and terminal 50 out goes straight to the starter solenoid.
Andy T.
Schnitzelfuss
PostPosted: Fri Oct 31, 2025 3:12 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
Yup.
Remember the reason we add this relay is to extend the useful life of the ignition switch.
So why would the relay need one? Again, it won’t create any hazard to add one, but- if the engineers at VW decided not to protect the original ignition circuit wiring with a fuse, then why add one when adding a relay? Fuses protect wiring. Wiring is sized according to the amperage requirements of the component receiving power, and the wiring length needed to deliver the power.
If the relay is mounted closer to the starter than the ignition switch, its wiring is the same size as the original harness, and the starter draws the same amperage as the original starter did, then the new circuit, including the relay wiring, would be subjected to less heat than the original design wiring. That would actually reduce the risk of overheating the wiring in the circuit.
If I’m missing something here please let me know, I don’t claim to be an electrical engineer.
62ItalianRagtop
PostPosted: Fri Nov 21, 2025 3:49 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Here some installation pictures on my 62:
I also added a fuse on positive red cable from battery postive to relay.
I have to fix the relay to the tunnel
runamoc Premium Member
runamoc is offline
PostPosted: Fri Nov 21, 2025 8:51 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
added a fuse
For inductive loads, it is recommended to use time-delay fuses, which can handle the higher inrush currents that occur when the load starts. The fuse size should typically be rated at 125% to 150% of the full load current to ensure proper protection without nuisance blowing.
When protecting motors and other inductive loads, fast acting
fuses must be rated at 200% to 300% of the load
currents, which will prevent nuisance opening on inrush
currents. Fuses with such increased ratings cannot provide
adequate protection from overloads and instead, only
provide short-circuit protection.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
62ItalianRagtop
PostPosted: Sun Nov 23, 2025 3:47 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Hi guys, unfortunately the results obtained are not what I expected.
Everything works but the starter is not more powerful than before.
I cleaned all the connections but something is still wrong.
I think that if I make wrong connections or if the relay is not working, the starter would't work. Do you agree?
Do you agree that with the relay I should feel a boost when starting?
What tests could I do to understand the problem?
Here's a recap of the connections made:
BLUE WIRE (85 on realy) --> connect to wire attached to terminal 50 on solenoid (wire from ignition)
RED WIRE (30 on realy) --> to battery positive with 16A fuse
BLACK WIRE (87 on realy) --> terminal 50 on solenoid
BROWN WIRE (86 on realy) --> to battery negative
Thank you
The Android
PostPosted: Sun Nov 23, 2025 9:12 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
The starter motor itself won't change in power. All you are doing is getting more voltage to the solenoid. It's an electromagnet that pushes the gear onto the flywheel while also closing a switch inside there that makes an electrical connection from the battery terminal to the motor windings. Once the solenoid "throws" the motor is going to behave as it always does.
Andy T.
Mr. 010
Glenn is offline
PostPosted: Sun Nov 23, 2025 9:21 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
All it does is bypass the, 60 year old, starter switch and provide a shorter run from the battery to the starter.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
62ItalianRagtop
PostPosted: Mon Nov 24, 2025 9:42 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
Hi all, thanks for the explanations and for your patience Very Happy
I made two videos to better explain the problem I'm having with starting.
As you can hear, the starter doesn't turn smoothly; it's as if it sometimes hits an obstacle and gets stuck.
I completely rebuilt the starter a few years ago (bearings, armature,brushes).
The electrical system was completely rebuild about 10 years ago.
A new ground cable was installed two month ago between the frame and the transmission.
The 6V Optima battery is about 11 years old.
The starter shaft bushing was almost certainly replaced 10 years ago.
Igniton switch changed with a new one one year ago.
I also cleaned all the connections.
One more thing: I have a 1385 engine with an Engle W100 camshaft and two 34 Solex carburetors.
Is it possible that the starting problem is due to the engine's higher compression compared to a stock car?
What else do you think could be the problem?
What else can I check ?
Thank you
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Nov 24, 2025 11:53 am    Post subject: Re: Where to install an hard start relay ? Reply with quote
"The 6V Optima battery is about 11 years old."
Even Optima doesn't last forever. This must be on its last legs.
"The starter shaft bushing was almost certainly replaced 10 years ago."
Replace it. Can be a PITA but it can be done. Between not being sure it was replaced, and ten years of starting, it's probably worn out.
This also sounds like a fouled flywheel ring gear, which is made worse if the starter bushing is worn.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Nov 24, 2025 2:06 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
Both videos show as "This Video Is Private", so not seeing them. You need to make them "Public".
Relay only improves voltage going to the starter solenoid. Which can help with the starter motor only by closing tighter the switch inside the starter solenoid that then switches on the electrical flow to the starter motor.
Relay will not help with:
1. Dirty/corroded/loose battery cables and any ground connections at both ends of each cable. How is your ground cable between the transaxle and body, are the surfaces all clean of crud and paint?? How dirty/corroded/painted are the ground connections of the starter solenoid to starter and starter to transaxle surfaces??? Using a dielectric grease to seal the connections after cleaning will keep oxygen and water from corroding those connections for more like a decade or two instead of having to taker apart to clean every year or two. We have been able to get voltage drops from around 2 volts to less than 1/10th of a volt in the longer bus wiring harnesses.
2. Worn starter bushings. Each standard non-self supported starter has TWO bushings and the front one (closer to the front bumper) can also wear out. Worn out bushings will cause the armature inside the starter to rub against the inner surfaces of the field coils. All you need is about .020" AKA .5mm wear. At first this will cause drag to slow down turning the engine over, later letting out the magic electrical smoke of the stater motor.
3. Dry starter bushings or where someone used grease on those. Bushings are Oillite which are designed to release oil out of the bearing material when under a load. Grease gums up over time and causes drag. So better at most for a drop or two of oil on the starter armature on each end of the shaft before installing into the bushings.
https://duckduckgo.com/?t=lm&q=def+Oillite&ia=web
4. Dry starter and flywheel gears that do better with a tad of grease on them.
5. Regulator not fully charging up the battery. Seen an NOS German regulator only put out 6.2 volts instead of the needed 7.2 volts to fully charge up the battery. For 12 volt battery needs to be more like 14 volts to charge battery properly. EG when startin gour 1963 single cab after sitting for a while the battery will be taking a charge, pulling voltage in the system down around 6 volts. After 15-20 minutes of driving the volt meter will climb up to 7 volts showing the battery is getting charged properly.
6. Bad battery, or too small of battery used. Have you had your battery checked for proper power output?
7. Worn down starter armature brushes. Brushes need to be longer than the cages they reside in. Have seem cheap starter rebuilds that only use two of the four brushes to cut cost, and that does not help to have a strong starter motor. Sure you rebuilt it years ago, but what matters is how many miles and in the case of the starter how many times a trip you used the starter.
What a relay does help with:
A. Gets more voltage to the starter solenoid by not going thru all the connections up to the front of the VW and back to the starter.
Problem with the above is most folks who only do the relay thing do not first make sure all the connections up front are clean and the internal connections inside the light switch and fuse box as soldered up to remove voltage drops there. So while the relay might then get the starter to work better, one still has less than optimum voltage to the rest of the electrical system. So less noticeable running and turn signal lights, slower wipers, less bright headlights and even in some cases a horn that only works with all the lights of the VW turned off. So other drivers do not see you or what your signals are to tell them, or you do not see well enough to drive safely. The latter in dark rainy/snowy situations especially. So have you checked out how much voltage at the battery and how much voltage getting out to various places like taillights, headlights, ect. with them turned on??? In other words fix the real problems in the electrical system, and if one still wants a relay after all is already working correctly, do so then.
B. Less wear of the contact surfaces inside the ignition switch, due to less amperage going thru them so less spark at those contacts. This can instead be accomplished by adding in a under dash hidden push switch to get zero wear on the starter contacts of the switch.
C. Burnt thinner wire between starter switch and starter solenoid. Seen one bus that had this problem.
In Stereo, Where Available!
EVfun Premium Member
EVfun is offline
PostPosted: Mon Nov 24, 2025 4:07 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
There is one exception to this that may affect this poster. If you have a "12 volt transaxle" (1967 or 1968 or later case) in a 6 volt Bug you will be using an adapter starter bushing. That "bushing" is really just a thin ring of steel because the 6 volt starter has a larger shaft than the 12 volt starter. I recommend that starter bushing gets a light coat of CV joint grease (the black Moly grease). It is not Oilite bronze and so not self-lubricating.
Wildthings wrote:
Eric&Barb
PostPosted: Mon Nov 24, 2025 4:26 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
Good intel!! Personally always got another 6 volt transaxle rebuilt with larger starter bushing bore. So could use the bigger OD bushings for more thicker wall thickness.
runamoc is offline
PostPosted: Mon Nov 24, 2025 4:48 pm    Post subject: Re: Where to install an hard start relay ? Reply with quote
if your timing is 'off' and too much advanced it could be 'bucking' against the starter.
Page 2 of 3
