alaskadan Samba Member
Joined: January 09, 2013 Posts: 1957 Location: anchor pt. alaska
Posted: Fri Oct 31, 2025 9:45 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Back on topic, does the cabin air flow through dramatically better with vented rear side windows added ? My 87 van obviously didn't come with them. |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1225 Location: PNW — Washington
Posted: Fri Oct 31, 2025 9:58 am Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| alaskadan wrote: |
The Black Forest engineers must have thought so. Adding this feature without an improvement to airflow would not make sense. They also blocked the front door vents, and eliminated the sliding opening feature. By now the original foam insert to keep dust and critters out of the rear side window vents has long since deteriorated. The good news is that it can be replaced with a modern equivalent filter medium from the outside without disassembly. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4694 Location: United States, Iowa
Posted: Fri Oct 31, 2025 1:45 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
The problem I have with putting things in locations that are generally speaking "hidden" is remembering that you did that in the first place.
For instance, I was doing something that required access to the battery compartment so I swiveled my passenger seat around. I had my wrench roll on the floor, and I noticed that on the Stow and Go seat, at the front, there is a small ledge where if one was sitting in the seat it would be just behind your knees. I wrapped up my wrench roll and set it in that little grotto, it fit perfectly, and I was thrilled to find a good spot. Well, I didn't need those wrenches for a while, and it slipped my mind. I hunted through the entire bus, and garage, and other bus and even another bus, and all around the house where I'd done anything since last I had done any wrenching, but did not find the wrenches. I then proceeded to go back to where I purchased them, and bought yet another set of wrenches in a decent canvas roll. I don't often buy inexpensive tools, so it was a considerable investment, again.
Last week, when I needed to disconnect my battery while dropping my fuse panel, I spotted my first set, and thought, hey!!! That WAS a great place to put those.... Too great!
Anyway, at least now I have two complete sets of wrenches, and two complete sets of ratchets, and, since I have two Westy's, I have to just laugh and say to myself, now I don't have to remember to grab the wrenches when taking the less often used one on trips.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
jimf909 Samba Member
Posted: Fri Oct 31, 2025 2:25 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
^^^ I've done the same thing and wondered if adding a visible ribbon would remind me of my clever idea often enough that I could eventually remove the ribbon and still remember what I hid when I need it.
_________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
mrinnovation1 Samba Member
Posted: Fri Oct 31, 2025 2:39 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Isn't that ribbon reserved for an old oak tree? |
SLOWoody Samba Member
Joined: January 28, 2023 Posts: 126 Location: SLO, CA
Posted: Fri Oct 31, 2025 2:57 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
That ribbon looks more orange than Yellow. _________________ 83.5 Westfalia, GW 2.3L w/ GW EFI, 4 speed |
Posted: Fri Oct 31, 2025 3:06 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| True, but they call it school bus yellow which isn't yellow either. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12415 Location: Santa Cruz, CA
Posted: Fri Oct 31, 2025 6:10 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| jakekoebrich wrote: |
| Hi guys, I'm installing some sound deadening in my 85 Vanagon and I just realized there's an air vent on the door however there doesn't seem to be any port coming from the front dashboard to feed air into the door? Is that sliding vent useless? There seems to be a hole in the door that's supposed to pass the air into the bulkhead behind the cabinetry but again where does that airflow come from? Is this an unknown secret? (cue the spooky music) |
Wait until you find out the oil filler tube extends. |
Posted: Fri Oct 31, 2025 9:15 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| Butcher wrote: |
Guilty as charged.
riceye Samba Member
Joined: March 09, 2006 Posts: 1714 Location: Caledonia, WI
Posted: Fri Nov 07, 2025 1:02 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
| syncrodoka wrote: |
And the dual bottle openers.
_________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
E1 Samba Member
Joined: January 21, 2013 Posts: 8748 Location: Westfalia, Earth
Posted: Fri Nov 07, 2025 1:05 pm Post subject: Re: Did I just discover one of Vanagon's unknown secrets? |
^^^ If that doesn’t work with PBR, I’m selling the van. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
