Fuel sender access hole, to do or not to do? |
To do |
55% |
[ 37 ] |
Not to do |
44% |
[ 30 ] |
Total Votes : 67 |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1127 Location: wherever my baywindow takes me.
Posted: Wed Aug 09, 2023 9:14 am Post subject: |
EZ Gruv wrote: |
busman78 wrote: |
Back in the day if you took your bus to the dealer for a sender replacement you got an access hole cut.
Any idea what they did to seal/cover the hole? |
Yes I recall that VW Campaign. VW had you use a shift coupler cover plate from a Bug. I did a couple of them back in the day, I thought they looked hoakie. But the instruction sheet provided gave all the measurements required to cut the hole directly over the sender. |
metahacker Samba Member
Posted: Thu Aug 10, 2023 11:09 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
I was recently working on a 1990s Brazil Bus (bay nose, split 15 window rear)
It had a set up like this on it...and it came that way from the factory, as far as I can tell
(It had some other interesting stuff...like what appeared to be a factory zerk fitting on the clutch pedal pivot....) |
the dominator Samba Member
Joined: March 18, 2016 Posts: 133 Location: The Netherlands
Posted: Wed Apr 17, 2024 2:27 am Post subject: Re: Fuel sender access hole, to do or not to do? |
Using this thread I cut the hole in my early bay and after replacing my fuelsender have bent a coverplate and screwed it in place.
_________________ 52 Zwitter standard ragtop, parts hunting
67 T2A candywaxred en chestnutbrown
1988 T3 doka synco 2.1WBX |
poundman Samba Member
Joined: April 05, 2024 Posts: 420 Location: Sugar Land, Texas
Posted: Wed Jul 02, 2025 12:13 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
Reviving and old thread.
My tank and engine are out at the moment so I plan to cut fuel sender access panel while I have the chance. I plan to use one of the marine round inspection hatch. I can't decide between 4" and 6" hatch. If I align it 100% correct then I think 4" should work. 6" would give more room for error. My sender is the barrel type. so it should raise directly upward. The outer lip is about .55 - .65 inches
Opinions?
https://www.amazon.com/smartmarine-Hatch-Inspectio...T1zcF9hdGY _________________ -----------------------------------------
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3204 Location: South Benfleet, Essex, UK
Posted: Wed Jul 02, 2025 12:26 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
poundman wrote: |
Opinions?
https://www.amazon.com/smartmarine-Hatch-Inspectio...T1zcF9hdGY |
Don't forget that one might need to gain access with yours or other people's hands, to lever the sender-unit away from its gasket after one has unfastened the small retaining bolts. I have small hands, so I only require a relatively small access hole, but even for me, a 4 inches diameter access hole might be marginal. _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
Posted: Wed Jul 02, 2025 1:18 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
NASkeet wrote: |
poundman wrote: |
Opinions?
Don't forget that one might need to gain access with yours or other people's hands, to lever the sender-unit away from its gasket after one has unfastened the small retaining bolts. I have small hands, so I only require a relatively small access hole, but even for me, a 4 inches diameter access hole might be marginal. |
Good points, I will go with 6" thank you. _________________ -----------------------------------------
Sugar Land, Texas |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42617 Location: at the beach
Posted: Wed Jul 02, 2025 1:52 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
this one
https://www.ebay.com/itm/263584464459
send him a request if they show out of stock. He can cnc a couple in a few hours. Lots of people use them and the are easier to install when the engine is out.
_________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Wed Jul 02, 2025 8:29 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
I thought about this one but in the end I didn't like the look of the finished product. I found another sold in UK that looked nice but shipping would make it expensive. _________________ -----------------------------------------
Sugar Land, Texas |
SGKent  Samba Member
Posted: Wed Jul 02, 2025 8:59 pm Post subject: Re: Fuel sender access hole, to do or not to do? |
poundman wrote: |
I thought about this one but in the end I didn't like the look of the finished product. I found another sold in UK that looked nice but shipping would make it expensive. |
you can use a narrow cut off wheel and seal it with RTV. You do not want a plastic solution due to fire risk. There was carpet over that area originally. I had my auto upholstery guy make me a piece that installs with snaps so the whole area is covered. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Bnanwel Samba Member
Joined: November 10, 2022 Posts: 278 Location: Ft Lauderdale
Posted: Thu Jul 03, 2025 3:39 am Post subject: Re: Fuel sender access hole, to do or not to do? |
I agree with sgkent that the cnc fitted panel backer is the way to go. If, however, you really want the round inspection hatch, buy a metal one. The marine stores jack up the prices, but there are some good options in metal:
https://www.amazon.com/dp/B0FCFY5TR4/ref=sspa_mw_d...V9kZXRhaWw _________________ ‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23911 Location: NYC/Upstate/ROW
Posted: Thu Jul 03, 2025 4:20 am Post subject: Re: Fuel sender access hole, to do or not to do? |
There is a minimal increase of fire risk with a plastic cover on a 40+ year old vehicle. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
