Hebster52
Page: Previous  1, 2, 3 ... , 10, 11, 12  Next
finster
finster is offline
PostPosted: Mon May 19, 2025 3:44 am    Post subject: Re: Hebster52 Reply with quote
so much good work there on small details. Applause how does the rain drain off the catcher?
Hebster52
Hebster52 is offline
PostPosted: Mon May 19, 2025 8:28 am    Post subject: Re: Hebster52 Reply with quote
Thanks! There will be drainig pipes on each side.
Here's a short youtube clip of the top.
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Hebster52
PostPosted: Mon Jun 02, 2025 10:05 pm    Post subject: Re: Hebster52 Reply with quote
Been mostly working on new parts and details the past weeks.
Bent the 30mm tube for the windshield frame. The tubewill have to be cut into two pieces to be able to fit it later.
Btw. The windshield will be split sedan windshield as originally on the first prototype. However the frame will be detailled more like the vert frames just to avoid looking like the Wizard roadsters from the 80's and 90's..
Now turning my work forward on the body I just couldn't look at the half arsed work a 20 years younger me had done... So I decided to make it right...
The sparewheel well also needed new bottom. In this case i decided to not make it myself from sheetmetal.. But could not afford the very expensive and nice panel from wolfparts so I just bought some economy panel for 1/10th of the price.
Off course I couldn't use it as it was so it got beaten right away to look more correct.. The bulge in the bottom needed to be smoothened out!
Also had to chisel out the typical pre-55 tabs for the wiring..
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Jun 02, 2025 10:18 pm    Post subject: Re: Hebster52 Reply with quote
Also making more bits and pieces for the windshield frame tube fastening.
The windshield defrosters will need some modifying too to fit..
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Jun 02, 2025 10:37 pm    Post subject: Re: Hebster52 Reply with quote
Yesterday I got the driver side doorstopper hole some what close to how it's supposed to be on the outside..
The passenger side will need a lot more work.... Confused
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Jun 15, 2025 2:36 am    Post subject: Re: Hebster52 Reply with quote
Not much progress lately. Mostly working on bits and pieces needed for rustrepairs and rebuilding the front section at the moment.
Since my budget don't allow big investments in repairpanels it forces me to be creative instead...
The front wheelwells need some attention and the righthand side is worse so decided to give it a go from sheetmetal...
First created a jig or form.
Then just sketched the profile on the sheetmetal and started hammer the shapes with a chisel.
Pretty happy with it now even though just roughly shaped...
~Kris~
The 912ST
The KidVRod project
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Jun 17, 2025 6:44 pm    Post subject: Re: Hebster52 Reply with quote
Hey Kris! I still drop in and have a looks now and again! Love your work!
On those wire harness retainers. How did you “chisel” them out? By hand? Air chisel? How did you get the radius done?
I modified a cheap spare tire well piece too, for my 54 build and figured if I could not find a way to punch those tabs out by painting time, I would just weld in some. But, maybe you have a method I did not consider? Care to teach a student something?
Thanks man!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Hebster52
PostPosted: Tue Jun 17, 2025 10:12 pm    Post subject: Re: Hebster52 Reply with quote
I just sacrificed ordinary woodworking chisels. Since I know how to sharpen them I didn't mind. However they didn't get that bad with these few tabs.
~Kris~
The 912ST
The KidVRod project
VW_Jimbo is offline
PostPosted: Wed Jun 18, 2025 3:45 pm    Post subject: Re: Hebster52 Reply with quote
Awesome! I am a woodworker by birth. Grew up with a father owning a custom cabinet shop. I started working in it at age 7. I will probably sharpen up one of my old Stanley chisels. Sounds like abuse using my old Marples chisels! Got to save those ones! Irwin bought that company, so who knows what is going to happen to the quality! Glad I got me a few sets scattered through all of the toolboxes!
Thanks for the reply. Never would have thought of using a wood chisel. I was getting ready to use my Dremel and try free handing those 180s. Then slice the long sides with a tiny cut off wheel.
Thank you!
Jimbo
Hebster52
PostPosted: Thu Jun 19, 2025 11:51 pm    Post subject: Re: Hebster52 Reply with quote
Yes. Patience is good here. Had a piece of wood under the panel.
First I basically "marked" the straight sides with the chisel. Just a bit heavier with the corner of the straight chisel to the top of the tab.
Then I took the rounded chisel. Radius 4-5mm, I think. With this I cut the full radius all through. It will distort the panel some. Now that the panel is punctured I cut the straight edges to the base.
I then bent the tab enough so I could clean the edges with a small file. Then hammered the tab and edges flat again.
Hope this explanation helps some?
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Fri Jun 20, 2025 12:01 am    Post subject: Re: Hebster52 Reply with quote
Yesterday I started preparing the leftside wheelwell but realised that it was much worse rusted and pitted than I first had thought...
So I thought it's just not worth patching with small patches and decided to make a similar repairpanel as I made to the right side...
As we have Midsummer long weekend and went to the summerhouse. So I brought some tools and material with me just to be able to start preparing the panel.
I got the panel preshaped.
Also cut the pieces for the forming jig. Just need some shaping and gluing before I can finish the second panel too.
~Kris~
The 912ST
The KidVRod project
VW_Jimbo is offline
PostPosted: Sat Jun 21, 2025 10:01 am    Post subject: Re: Hebster52 Reply with quote
Thank you very much! I will try it out this weekend on some extra sheet stock. Appreciate you sharing your skillset with us all!
Jimbo
Hebster52
PostPosted: Sat Jun 21, 2025 12:09 pm    Post subject: Re: Hebster52 Reply with quote
My pleasure. I happy that my work encourages others towards more diy!
Finished the second repairpanel today!
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Jun 22, 2025 12:16 pm    Post subject: Re: Hebster52 Reply with quote
First panel fitted with cleecos.... It's not perfect but good enough for me.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sat Jun 28, 2025 2:17 am    Post subject: Re: Hebster52 Reply with quote
Well. Since most of the work have already gone out of hands (mopo karannut käsistä, spårat ur.. ) I came to the conclusion that also the framerails and bodymounts under the tank needed to be rebuilt. The rails have been patched at some point but still cracks and bad rust repair attempts..
These rails are available new but since these are pretty simple pieces I decided to make them myself....
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Jun 29, 2025 10:03 am    Post subject: Re: Hebster52 Reply with quote
Now they're almost done! Just a few holes and small pieces left to make. Then they're can be welded!
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Wed Jul 02, 2025 10:30 am    Post subject: Re: Hebster52 Reply with quote
Oh! Some Virtanen restoration panels arrived today!
Yes, I decided that it's easier to weld in new tank carriers than to try repair the old as the old have rusted a lot from inside...
~Kris~
The 912ST
The KidVRod project
VW_Jimbo is offline
PostPosted: Wed Jul 02, 2025 7:35 pm    Post subject: Re: Hebster52 Reply with quote
I love panels from Mika! They always fit and are the right thickness! Plus is an outstanding metal worker!
Those sure look Purdy!
Jimbo
Hebster52
PostPosted: Sat Jul 05, 2025 11:06 pm    Post subject: Re: Hebster52 Reply with quote
Yes. They sure will make my work a lot easier than trying to patch the old ones.
Yesterday I made the final parts for the new body mounts in the VIN tray brackets. Had to make a special tool for shaping the ovak holes.
Now I just have to continue the welding!
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Tue Jul 08, 2025 10:36 am    Post subject: Re: Hebster52 Reply with quote
First panel fitted and tacked in place. Looks like it will be good enough for me.
~Kris~
The 912ST
The KidVRod project
Page 11 of 12
