Inline-4 conversion: What VW engine?
Page: Previous  1, 2, 3 ... 13, 14, 15
danfromsyr
danfromsyr is offline
PostPosted: Wed Mar 06, 2024 3:49 pm    Post subject: Re: Inline-4 conversion: What VW engine? Reply with quote
While I can certainly agree that a OBD-I forged bottom end would be best.
I wouldn't shy away from this stellar deal on a brandy new ABA shortblock.
if I only had one 8v I4 needing vehicle I'd be all over this deal.
but instead I have a barn full of VW stray cats and used ABA take outs..
ohhh to rethink some of my earlier choices.
edit: i see they're the ones with the 3A block too.
as mentioned the biggest benefit of a 3A block is to fit w/o mods into a MK-1 engined car.
https://www.ebay.com/itm/293759623356
Abscate wrote:
joetiger Premium Member
joetiger is offline
PostPosted: Thu Mar 07, 2024 7:07 am    Post subject: Re: Inline-4 conversion: What VW engine? Reply with quote
Yep, that's who I've been working with. Incredibly nice and accommodating people all around.
He's reviewing the blocks he has. The real Audi 3A's with forged internals were allegedly all manufactured in Europe, and what I was going to buy was Brazilian. There are a few additional small differences, for example:
Fits any 1.8 mechanical.
It will work for hydraulic lifters too but it doesn’t have the one way valve so when the car sits, the lifters will be noisy for a bit when you start it.
There are a lot of little things that need to be addressed that would turn this into a longer-term project.
It looks fun and interesting, but now that I'm getting a garage again, I suddenly have projects lined up on the '02 Golf, '04 GTI, '04 R32, and my van. Shocked
Joe T.
'02 Baja-ish Beetle "Bubbles"
Check out my book: Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
www.pigpensyncro.com
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Mar 07, 2024 10:50 am    Post subject: Re: Inline-4 conversion: What VW engine? Reply with quote
I'm curious of this one way valve. Is the vendor referring to a 'non return valve' as per type used on some 16v heads? (Part 4 in linked page). I can't see that part on the 3A "bubble block" head.
"4-cylinder+
petrol eng.+
CCZC,CPSA"
https://webautocats.com/en-us/etka/audi/aq3/728u/103300/
"VW gas I4 Conversions" Google Group is being shut down.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
connorsvw2
connorsvw2 is offline
PostPosted: Mon Mar 11, 2024 7:58 am    Post subject: Re: Inline-4 conversion: What VW engine? Reply with quote
I always assumed the 3A was the same bottom end as the 9A 2L 16v, but with different pistons for the 8v head. I had pondered dropping that into my 85 GTI with some custom forged pistons.
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
jgrosjean
jgrosjean is offline
PostPosted: Fri May 23, 2025 11:56 am    Post subject: Re: Inline-4 conversion: What VW engine? Reply with quote
When I got my Vanagon, the original engine was gone. The owner also had a diesel which I took with it and used the mounting hardware for the 2.0 ABA engine. It has been super reliable and very good performance since the Vanagon weighs about the same as a later Jetta with the same engine.
The main problems are having to make a custom exhaust and the vibration of the in-line 4 which is much worse than the original boxer engine. I used the Diesel engine mounts, but if I had to do it again, I would use the car mounts with the better internal damping. I had to use 2 flexible exhaust couplings to prevent failure of the exhaust due to the engine vibration. I used the engine pan, oil pump adapter, flywheel, clutch, transmission adapter and transmission input shaft from the Diesel engine.
Page 15 of 15
