Oil Cooler ports for Manual Vanagon transaxle
Page: Previous  1, 2, 3 ... 15, 16, 17
4Gears4Tires
4Gears4Tires is offline
PostPosted: Thu Jun 22, 2023 8:46 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
I have one. I think mine seeps oil through the faceplate, been a minute since I've been under there but I think I spotted a leak somewhere. It is pretty freakin loud.
Syncrodelic
Syncrodelic is offline
PostPosted: Thu Jun 22, 2023 8:53 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
The faceplate is likely fixable. I was worried it might be loud; that's too bad. Probably not much you can do about that.
What's freakin loud? Can you hear it on the highway? Do you wish you had spent more on a quieter pump?
4Gears4Tires
PostPosted: Thu Jun 22, 2023 8:57 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
You can easily hear it on the highway at 70mph. If a more expensive pump is inaudible at highway speeds, then yes. However, If you run it for 30 seconds after finishing a long drive to filter the oil, I guess it doesn't matter too much.
Next time the trans comes down, I'm removing it. If I actually do any towing in the future, then I'll consider reinstalling it. At this point, it's just another failure point that is giving me more anxiety.
Syncrodelic
PostPosted: Thu Jun 22, 2023 9:14 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
Interesting. Yes, mine would be running constantly; as soon as the oil gets warm. That might be too much noise.
Thanks for your response.
4Gears4Tires
PostPosted: Thu Jun 22, 2023 9:55 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
If you have a good transmission and stay around 70mph, you certainly don't need the oil cooler. The filtering is good to have, sure.
I had my trans rebuilt a few years ago and Rancho installed both a GT Gears 4th gear and a 4th gear oiling plate. The oiling plate half blocks the return oil stream if you use the fill hole. However, I'm fairly certain it's still mostly spilling onto the gear. The oiling plate is curved and oil would hit it and then keep going along until the edge where it would meet the gear.
The Amarine is way too annoying to run constantly. I did this for the first 200 miles of my transmission's break in period and it was rough. The filter did get a lot of trash out of the trans though.
onwardtothestars
onwardtothestars is offline
PostPosted: Fri Aug 02, 2024 5:45 am    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
During my daily endless samba rabbit-holes, I'm curious if anyone has any updates on gear oil pumps they installed?
-$500 Weddle/TurboWerx unit
-$250 diaphragm pump, sold under many names
- $75-$150 used BMW pump and cooler unit (I'd really like to know if anyone went further then the initial bench testing on these. )
- $75 China oil pump sold under many names and descriptions.
Thank you
Beetle, Ghia, Vanagon Syncro, and more
Kdj
Kdj is offline
PostPosted: Fri Aug 02, 2024 6:04 pm    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
This is what I am planing on using. Its rated for continues duty cycle. We use them at work and they are more reliable then the tilton ones he had being using.
https://www.jmesales.com/marco-up2-oil-12v-gear-oil-pump-3-8-in-npt-21-8-psi-3-3-ft-self-priming/
Photo of cooler port in 091 selctor housing I'm going with, posted in the 091 transaxle thread.
Syncrodelic
PostPosted: Fri Aug 02, 2024 8:37 pm    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
I used a Mocal 17-311 pump. It's reversible, self-priming, and waterproof. Also, it's very quiet--I can't hear it running unless I lean down under the van and listen carefully.
I also used this flow thermostat that limits flow to the cooler rad to keep the oil at 145F. I haven't had to use the fan on the rad yet, but my TDI isn't installed yet either.
https://www.improvedracing.com/compact-high-flow-engine-transmission-oil-cooler-thermostat.html
Sodo
Sodo is offline
PostPosted: Sat Aug 03, 2024 12:35 pm    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
I’d duplicate that oil channel that feeds the thrust gap between 4th & the mainshaft bearing.
Maybe try to nozzle the fitting to point at it.
....KTMs, GasGas, SPOT mtb
Kdj
Kdj is offline
PostPosted: Sat Aug 03, 2024 1:31 pm    Post subject: Re: Oil Cooler ports for Manual Vanagon transaxle Reply with quote
Unfortunately, the transaxle going back in is already assembled. That was a mock up for location in my old core parts. But I agree that would be a very good modification to do. I have drilled the fitting in the rebuilt one. I used your suggestion to pressurize the case through the vent and used a vacuum and grease to minimize the swarth dropping into the fresh rebuild. Worked like a charm! Just finished bolting it up to engine/chassis. Next project is fitting cooler system and tidy up some.Hoping to road test tomorrow Rolling Eyes
Page 17 of 17
