S4VAGE Samba Member
Posted: Wed Apr 16, 2025 6:21 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Jammasterjay wrote: |
After lurking wheel fitment posts for months, I decided to try the Maxilite wheels and KO2’s. I would have liked 15” wheels for the sidewall profile, and I liked the old 14” KO2’s more square profile. The slider is .5-.75 clearance. Balancing was a little heavy because I didn’t want outer face weights.
Those look great! |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 545 Location: Chicago, IL
Posted: Thu Apr 24, 2025 8:47 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Well.. finally got there. After years of being on the fence, I took the leap and now am on 16" CLK320s with 215/65/16 Falken Wildpeak AT Trail tires.
For anyone considering new wheels / tires for a non-lifted westy, I can tell you that this is probably the answer for "how big of a tire can / should I get" I went back and forth for a long time on 215/65 vs 215/70 and I'm very happy with my choice. They look great, they run well (I have a subaru EJ25, so can't speak to pushing 27" wheels with an OEM motor) they don't rub at all. I have GoWesty "zero lift" springs all around with a few leveling spacers in the back.
Black satin powder coated rims. new R12 ball nuts and lug bolts, 45mm studs for the rear hubs, 5mm front 12mm rear spacers, and center caps with VW logos (now painted to match rims) from T3Technique. (Along with lots of free and great advice and timely email replies from Christopher. Thanks!) Silicone lug nut covers for the look and to keep corrosion down and crap out of the open ended lugs on the rear wheels. Fancy machined valve caps on OEM Mercedes valve stems (which for some reason come with tiny chrome caps that don't cover all of the threads on the valve stem)
For the install, the rear hubs had to come off to press in the new studs. I know you can probably do this without removing, but I also wanted to inspect wheel bearings, so was worth it. The grease caps have to come off the front wheels to get the spacers on, which means uninstalling / reinstalling the speedometer cable. Not a big deal, but something I didn't think of before getting into it. Rear wheel has plenty of clearance to slider door. Front tires don't rub even with the Terrawagen fender flares. Still need to figure out the spare under the front situation. Won't fit with just the added spacer to the bolt (that allowed the old 15" wheels to fit) but I have a "new clamshell solution" I'm hopefully going to figure out in the next week or so. Will def post about it if it works.
Hopes this info helps someone in the futurs. Thanks for all the DM replies from the various Samba people I hounded over the last year or so. I'll follow up after the next long trip to give a review on the tires in that thread.
Before (15" GoWesty rims and Michelin Agillis CrossClimate CMetric 205/65/15)
vs after _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
5BWesty Samba Member
Posted: Mon May 05, 2025 2:50 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
cdussault wrote: |
Installed the Mobelwagen Interceptors today...really like the fit. Running Geolander 215 60r16. They were a bit wonky to balance...
Can you tell me what center cap you're using here on the front wheels? Thanks. |
Posted: Tue May 06, 2025 12:56 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
5BWesty wrote: |
Looks like the grease cap to me on the front.. So, no center caps. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
cdussault Samba Member
Posted: Thu May 08, 2025 9:56 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Crooked Designer wrote: |
5BWesty wrote: |
Looks like the grease cap to me on the front.. So, no center caps. |
Correct! No center caps, though cleaned them up and painted to look presentable. |
4Gears4Tires Samba Member
Posted: Fri May 23, 2025 7:49 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
https://www.ebay.com/itm/126623731732?_skw=zender+...R4Dc6tnfZQ
One of my dream sets of wheels are up for sale. $1700 + Shipping.
Zender Turbo in 15x7 et 22 _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
