glutamodo  The Android
Joined: July 13, 2004 Posts: 26548 Location: Douglas, WY
Posted: Tue Oct 16, 2007 4:14 pm Post subject: |
COTC lists these steering wheel/column/handbrake colours in 1961
021 Hydrate Green for body colours (up through Feb.) L380 Turquiose and Ll391 Pastel Blue.
020 Basalt Gray for body colours L41 Black, L456 Ruby Red, L360 Gulf Blue, and (after March) L380 Turquiose and Ll391 Pastel Blue.
023 Sand Stone for L87 Pearl White cars
022 Nepal Green for L478 Beryl Green cars.
It doesn't talk about any convertible-only color schemes in 61 though. |
ruzlkampf Samba Member
Joined: October 25, 2007 Posts: 54 Location: San Diego, CA
Posted: Thu Oct 25, 2007 5:22 am Post subject: |
Hello All, Restoring my Beryl Green bug(early 1961...Nov.1960), as close to original as possible, and am going thru the "finding the correct parts" phase also! Anybody know if these colored steering wheels were molded in color, or painted?
New to the forum, and am surprised to see so many San Diegans on this thread. I lived just across from Kearney Mesa HS for 2 years(just moved to Point Loma) and didn't see hardly any other old bugs at all! Nice to see that I'm not the only one in the area with a '61.  |
Posted: Thu Oct 25, 2007 7:55 am Post subject: |
ruzlkampf wrote: |
Anybody know if these colored steering wheels were molded in color, or painted? |
I think it's paint. Here's a closeup of the wear on on the unrestored gray wheel that came out of my old Ruby Red 61, you can see the color layer is not very thick, the base layer is some brown/tan color:
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Thu Oct 25, 2007 12:37 pm Post subject: |
Man,all of these "experts" failed to mention the '61 only bulb diffusers and lenses on the '61 taillights;'61 diffusers are "fish egg" style,'57-'60 has horisontal lines,and late '55-'56 are smooth. As for the glass lense,it should have two part #'s along each side of the lense opposed to the '57-'60 which had just the one set of #'s on the bottom.  _________________ die schwarzen Schafe #666 |
Posted: Fri Oct 26, 2007 1:49 am Post subject: |
Hey Thanks, Glutamodo! I have never seen another real '61 steering wheel to compare mine to. Mine doesn't have the Nepal Green wheel/column(it's ivory) and I'm not sure if mine are original. Anybody know if all Beryl Green(or the blue/turquoise) bugs ALL had colored wheels? Maybe ivory was an option? Do "61's have a unique steering column also? Splines unique? I read your gallery, and that answered my question about the horn set-up.
Reason for asking; Bug is gutted, and being painted this week. Will have the column/wheel out for repainting. Want to put a '62/later wheel on the car until my original wheel is restored. Possible? Should I go with a later column? I don't have a known '61 set-up to compare to.
Anybody know the detail differences? Your knowledge would be much appreciated! Thanks. |
malley56 Samba Member
Joined: January 29, 2006 Posts: 255 Location: Martinsville, VA
Posted: Fri Oct 26, 2007 5:14 am Post subject: |
Quote: |
Anybody know if all Beryl Green(or the blue/turquoise) bugs ALL had colored wheels? |
I don't know if they all did...But, I know my Beryl green 61 had an Olive green colored Steeering wheel(Must have been Nepal) |
Posted: Sat Oct 27, 2007 1:36 am Post subject: |
Hey All !, Kick boards under rear seat(1st year installed) had no heater hole. Also, my bug is an early "61 and has no vent for the oil filler to carb. Don't think this oil filler is a 36hp part, as they have a bracket to fit integral generator stand and this fits 40hp motor. Anybody know for sure? I'm running a later vented setup right now, cause crankcase pressure blows oil thru front seal with original non-vented.
Thanks for the info malley56, all I can find on interior/steering wheel color combos is; "New for 1961, color matched interiors". Were colored steering wheels unique to 1961 also? I don't ever recall seeing multicolored wheels on 62"s, only black/ivory. Also, colored rubber mats and running boards seem to be unique for '61's. |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Sat Oct 27, 2007 8:59 am Post subject: |
ruzlkampf wrote: |
Hey All !, Kick boards under rear seat(1st year installed) had no heater hole. |
Actually '60 model was the first year.  |
c.davis419 Samba Member
Posted: Sat Oct 27, 2007 5:07 pm Post subject: |
Hey Scotty, I'm just north of you in Vista. I've got a very nice 61 only brake fluid tank thats yours for free if you want to stop by and pick it up.
It even comes with the hard to find green brake hose.
Chris _________________ 1967 beetle
1974 Thing |
PooDoo Samba Member
Posted: Sun Oct 28, 2007 8:34 pm Post subject: |
glutamodo wrote: |
What is the chassis number? The front hood went from 4-tab to the early 3-post midway through the year, at chassis number 3 551 045.
The turn signal switch is mechanically the same for 1960 and 1961, but in 1961 they went to push-on spade terminals for the first time instead of screw-terminals. They both have 6 wires as the switch sends a combined signal to the rear for the brake lights and the rear turn signals.
The steering wheel's horn setup is a bit more primitive, with three spring loaded brass pins under the horn ring that make the contact. The horn ring itself is shaped a bit different too, although I've seen later rings on there and be made to work.
I gotta run so I'll let others add to this discussion...
-Andy |
That is crazy, because if you are correct, I own the very last 4 tab hood bug, my 61 ragtop is chassis number 3 551 044. |
Posted: Sun Oct 28, 2007 9:08 pm Post subject: |
Cool! Well, it had to end up somewhere!  |
Posted: Mon Oct 29, 2007 7:23 pm Post subject: |
c.davis419 wrote: |
Calling that reservoir a 61-only, that's incorrect as well, the rubber-cap reservoir didn't change to the screw-cap style until September 18,1962, a few days into the 1963 model year. |
L572 Samba Member
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Sun Nov 04, 2007 1:42 am Post subject: |
ruzlkampf wrote: |
Also a '61 owner in San Diego (San Marcos), and I bought it in the Clairemont area. Bummer is, mine is a black model. So it did not come with any of the fancy color matched items.
I thought 4 tabs ended in early '60, not '61? _________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
1969 Sunroof Beetle |
ivsamhell Samba Member
Joined: June 12, 2006 Posts: 858 Location: hesperiaCA
Posted: Sun Nov 04, 2007 11:56 am Post subject: |
ive got a pearl white 61 with hydrate green bits, the seats were replaced with leatherette at the dealer so they weren't... ebrake and shifter have been changed along the way and the steering column is sand stone.
bugragtop Samba Member
Joined: April 21, 2008 Posts: 37 Location: The Netherlands
Posted: Tue Apr 22, 2008 2:36 am Post subject: |
glutamodo wrote: |
I vaguely remember my first VW, a 61, having that teardrop shaped nozzle on it. Looking around the classifieds I found this one for sale, this is how I remember mine looking like, look at this listing:
http://www.thesamba.com/vw/classifieds/detail.php?id=232144
and I think I've seen one or two like this one before, in chrome
my '62 beryl green ragtop has this nozzle, so also on a '62. Furthermore it has; a color matching gearlever, handbrake lever but an ivory colored steering wheel with lock. I know, it's not 61, but is this an original feature? The horn ring also has notches (so not only 61)
(testfitting my recently restored Akkord Autotransistor)
_________________ '60 AWO Simson 425T
'62 original paint BeryllGrün ragtop
'67 So42 Westfalia splittie
'64 Constructam Condor caravan |
JDGas Samba Member
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Apr 22, 2008 12:03 pm Post subject: |
I know that some of the color matching of the ebrake and shifter ended in about Feb 61. Only a 6 month or so deal.
I did the research a while back to sell a hydrate set that I had. I found the info here on The Samba, in the tech section. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Tue Apr 22, 2008 3:00 pm Post subject: |
What happened in Feb 61 was they dropped the green/blue keyed interior colors. What they switched to was Basalt Gray and Rock Gray, differenent 1961 colors that were already on use on the L41 Black models. It only affected car colors L380 Turquoise and L391 Pastel Blue. In 1962, L391 was no longer an offered body color, but L41 and L380 carried on, but both of them used different 1962 interior color schemes. |
OvalTeenAZ Samba Member
Posted: Tue Apr 22, 2008 3:11 pm Post subject: Re: Chassis No. |
iamtheredworm wrote: |
RareAir wrote: |
scottyhoffo wrote: |
I have the correct steering wheel, but what about color? The BC says "radscheibe" but that means "wheel disk"... my wheel is painted what appears to be the original L390 golfblau. |
Your steering wheel is painted L390 Gulf Blue? Hmmm I thought only convertibles were equipped with color-matched steering wheels. |
Irish bugs did.
heres mine colour coded steerng wheel,gearstick plus handbrake.
and you can just make out the clover in the top corner.
the us did to
it was a 5 month only thing i know of 2 cars in az this way
i have the shifter ebrake and stering wheel out of one |
