Pinetops Samba Member
Posted: Mon May 11, 2015 7:09 am Post subject: |
kbman wrote: |
Over the years I've brazed three tanks. Two type ones and one type two and if needed I will do it again. I just saw a repair that made over 25 years ago while replacing tie rod ends a few months back. Still holding knock on wood. A hundred and eighty dollars for a new tank certainly is affordable but is it crap like a lot of after market products. Just because wolfsburg west sells it doesn't always mean its quality. |
The WW tank is comparable in quality to my original tank. My original tank had much more "flex" than the WW tank as well, this could be due to age but it's something I noticed. _________________ "A rolling bus gathers no rust." |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1793 Location: Cleveland, Ohio
Posted: Mon May 11, 2015 9:11 am Post subject: |
kbman wrote: |
I put a WW tank in over a year ago and it fit and looks perfect, the quality and fit/finish was excellent. You'd have to be a perfectionist Nazi to consider using an original tank.
As for WW in general, their quality is above average, pricing is competitive, the website works terrific as far as stock and detail, and the orders go out quickly with e-mail notifications when shipped.
Other vendors- missing parts, backorders, free shipping (but it takes a month), unkept promises, parts that don't fit, etc. You don't realize how good a supplier is until you deal with some bad ones. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Mon May 11, 2015 10:36 am Post subject: Darth Vader |
"I find your lack of faith disturbing." - Darth Vader (Star Wars, A New Hope)
Go Vader on those old tanks and if it doesn't work then get a used one...or new...
For fun... |
Gil-bug Samba Member
Joined: February 17, 2015 Posts: 91 Location: Luxembourg
Posted: Thu Jul 17, 2025 10:41 pm Post subject: |
Das67bus wrote: |
Campy wrote: |
It's still dumb to drill a hole in a gas cap where the vapor goes directly out. If enough gasoline vapor accumalates out of the fuel tank and reaches a source of ignition such as a pilot light, so long. It is the gasoline vapor that is dangerous. That is why they developed cannisters in a sealed system where the vapor condenses back to gasoline. Spend a few bucks and buy a good cap. |
5
That's fine. WHERE do you buy a good cap? I've had the problem of the tank pressuring up, leaking, and have tried several caps. I give!!! |
Hello, i have the same problem after filling up. The tank pressurizes up, and leaks between cap and filler neck. I thas the original cap. I tried also an aftermarked vented cap, without success. Any ideas? Thanks |
thom Samba Member
Joined: October 12, 2000 Posts: 6200 Location: Sacramento
Posted: Fri Jul 18, 2025 9:52 am Post subject: Re: Replace or repair gas tank |
After the 3rd iteration of dragging a tank out of my parts stash, cleaning it all up, trying to de-rust the inside and then finding pinholes, I said 'fuck it' and bought one of the WW tanks.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
