BlackDogVan Samba Member
Joined: December 21, 2007 Posts: 855 Location: Vancouver Island
Posted: Tue Jan 18, 2011 2:46 pm Post subject: |
Check the turbo shaft too, excessive play side to side & any axial play can be an indication of shot shaft seals. Your turbo vomiting oil into the intake can cause a runaway. _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka... |
brent239 Samba Member
Joined: September 15, 2004 Posts: 145 Location: Utah...
Posted: Tue Jan 18, 2011 5:51 pm Post subject: |
the oil is definitely coming out of the turbo. I dont know the history of the motor other than what the Junkyard told him. I wanna check the turbo for play. It doesnt look hard to remove, any consequences? any parts I should have? thanks for the help guys _________________ 88 westy suby 2.5 |
Posted: Tue Jan 18, 2011 7:55 pm Post subject: |
Everything you need to know is here. Better chill a few or put the kettle on...
http://www.vwdiesel.net/forum/index.php _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
evansdd3 Samba Member
Joined: May 11, 2005 Posts: 78 Location: Sooke, Vancouver Island
Posted: Mon Jan 24, 2011 3:20 pm Post subject: |
Hope the van's back running again soon.
You have to want to tinker to own one of these...I am reminded of that almost everyday! _________________ C'mon, gimme your 71 type 2...And throw in a dash clock. |
Posted: Tue Jan 25, 2011 2:17 pm Post subject: |
Sadly its not, its out of my hands/hair soon. owner decided he want to run it without me, ranaway now it only starts with half a can of starter fluid, pretty sure theres a cylinder with no compression or something. owner believes it to be the injectors, i think the wasted turbo spitting oil into the cylinders, led to the runaway, that wasted something in the motor. wont let me take the turbo off, do a compression check, or anything, well with my hands tied , I will worry about my own van, and my tranny problems
hopefully soon fixed so I can move on _________________ 88 westy suby 2.5 |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1088 Location: San Francisco
Posted: Sat Jan 29, 2011 4:54 am Post subject: |
I'm contemplating a similar swapped and hoped to hear how things turn out with the existing ratios. Will you be able to report back after the owner sorts out the problems? BTW, you could get some deck clearance by using Syncro mounts.
Anyway, I originally thought of using a TDI but that was shot down due to the ratios. I have an AAZ in my Syncro 16 but it's a Doka and originally equipped with a JX so no biggie doing the swap there.
I'm posting in the hope that you update the thread with a success story.
Cheers,
BenT |
Posted: Sat Jan 29, 2011 10:53 am Post subject: |
FYI I ran a AAZ for 7 years on stock 2.1 wbx gearing & oversized tires. No problems & happy engine. _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Posted: Sat Jan 29, 2011 11:06 am Post subject: |
| BlackDogVan wrote: |
| FYI I ran a AAZ for 7 years on stock 2.1 wbx gearing & oversized tires. No problems & happy engine. |
Do you recall what size tire you used? |
Posted: Sat Jan 29, 2011 11:12 am Post subject: |
yeah the biggest deal was to an automatic gearing, which is way higher. In your syncro, you shouldnt have any problems gearing wise. and im not sure of any syncro diesels mounts, but as in all other syncros, im sure you could drop the motor and clear the lid, thats what my father did over 10 years ago in his diesel westy. I know theres more than a few syncro turbodiesels around.
FYI if youve been following this thread, motor sat over a week, ran some seafoam straight into the injection pump at like 50/50. ran pretty good yesterday, no runaway, idles well, just may have been a ring unseated?? _________________ 88 westy suby 2.5 |
Posted: Sat Jan 29, 2011 11:48 am Post subject: |
No biggie on my Syncro which was a turbodiesel from the factory. Good point that the Syncro trans mount idea would not work on an auto.
I'm interested in the ratios 'BlackDog' used for his AAZ with an auto. I've fitted a great number of shorter sidewall tires in my auto Vanagons but never a taller one.
Congrats on possibly saving that AAZ. We acquired an abandoned conversion before because the DPO thought the water was shot. They couldn't get rid of all the white smoke. Turned out to be a lot of water in the exhaust system. It eventually dried up and was no longer a problem. Maybe your engine problems are history now too. |
Posted: Sat Jan 29, 2011 11:50 am Post subject: |
this auto has 225/70/16!! theyre huge and fit well. but yeah I hope its fixed too! _________________ 88 westy suby 2.5 |
Posted: Sat Jan 29, 2011 12:51 pm Post subject: |
| brent239 wrote: |
| this auto has 225/70/16!! theyre huge and fit well. but yeah I hope its fixed too! |
Great, please post your driving impressions with that combo, if you get a chance. My project is a Doublecab so there's more rear tire options possible. No restrictions imposed by a sliding door. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Sun Oct 02, 2011 9:26 am Post subject: |
Does anyone have pics of the kickdown cable arrangement for diesel swap with an automagic tranny? I'm still debating my transmission options for an upcoming mTDI swap, and really like the idea of a slushbox churning away in front of that bioburner. I'm getting lazy in my old age, and look forward to letting the pump and valve body handle all the shifting duties. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1508 Location: Redmond, WA
Posted: Sun Oct 02, 2011 10:09 am Post subject: |
| vweggie wrote: |
| Let's see some pictures please! |
Indeed..
I regret not going tdi.. uggh.. and my wbx isnt even started!
It would be awesome to see more pics during stages of your buildup.
Thanks! Lookin great!
Al |
91Transporter16" Samba Member
Joined: February 07, 2011 Posts: 267 Location: Tualatin Oregon
Posted: Mon Oct 24, 2011 5:53 pm Post subject: Clutch Parts |
Ben T Syncro, I am putting a AAZ in my Transporter that needs a flywheel, clutch and what ever else is needed to mount a 4 speed to this AAZ. The truck came with a 2.1L and I was told that the clutch is different. This truck originally came with a 1.6L and was converted. I am putting a AAZ back in it this time.
I'm also looking for the carrier bars that support the diesel engine for a syncro.
Thanks
Tony |
