Baja bugs for Volkswagen virgins: The IRS transmission
ABN82
ABN82 is offline
PostPosted: Fri Sep 27, 2013 9:59 pm    Post subject: 002 bus Trans axle Code Reply with quote
Can anyone tell me what this trans axle code means? CA 041 4945 The trans axle is a 3 rib type 2 IRS. I have looked all over the net and still have not found an answer.
JOHN D
JOHN D is offline
PostPosted: Tue Nov 26, 2013 4:07 pm    Post subject: Reply with quote
Here you go ---
Bus Information
CA - CD 68 - 71 / 002 5:38 / 3 Rib
CE - CL 72 - 73 / 002 5:38 / 3 Rib
CM - CN 74 - 75 / 002 4:86 / 5 Rib
CP - CX 76 - 79 / 091 4:57 / 6 Rib
Serial Number Information
CM02 10 3
CM = Leter Code
02 = Day of Production / 2nd day of month
10 = Month of Production / October
3 = Year of Production / 1973
John 0\ ! /0
Mal evolent
Mal evolent is offline
PostPosted: Wed Nov 27, 2013 6:10 am    Post subject: Reply with quote
if it's a CA it's probably a '68. if it's a 68 you don't ant it. one year only, unobtainable parts.
I believe '68s have to vast Phillips head screws holding the side cover on, later 002s have 6 bolts
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
donpedro
donpedro is offline
PostPosted: Sun Apr 27, 2014 11:55 pm    Post subject: Reply with quote
Such good Info! Thanks for all of the hard work Mal, these threads are great and I've had my baja for 13 years.
vwpilotbob
vwpilotbob is offline
PostPosted: Sun Jun 22, 2014 1:43 pm    Post subject: WHICH ring gear, 6 or 8 bolt?? Reply with quote
Hi,
I've been searching for info on this for a couple of hours, so if anyone can help I would REALLY appreciate it.
I have an (unknown history) swing axle trans in a fiberglass buggy. I need to know if it is likely to have a 6, or the later 8 bolt differential housing.
Here is the number: 7147701
Anyone know what year that might be and if it is likely to be a 6, or an 8 bolt???
Thanks a bunch in advance,
vwpilotbob
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sun Jun 22, 2014 1:52 pm    Post subject: Reply with quote
Welcome to the Samba!
That is a late '64 transaxle and will be a 6 bolt ring gear and carrier. The R&P ratio will be a 4.37:1.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
vwpilotbob
PostPosted: Sun Jun 22, 2014 5:59 pm    Post subject: Reply with quote
Hi, and thanks for the welcome and the info.
Would you mind sharing your source for future info?
I checked the differential ratio on this trans, and it is 4.125. So, it looks like I won't really know what is inside until I pull it apart. Bummer!
Thanks again,
vwpilotbob
joescoolcustoms
PostPosted: Sun Jun 22, 2014 7:23 pm    Post subject: Reply with quote
Not many transaxles left that have not been apart at some time or another.
If you sort through the "Technical" drop down above in the tool bar, then go through VIN Numbers for a Type 1, you can see the sequence and judge about where yours was made.
How did you discover it was a 4.12 ring and pinion?
vwpilotbob
PostPosted: Mon Jun 23, 2014 11:59 am    Post subject: Checking differential ratio without disassembly. Reply with quote
Yeah, that's a neat trick I learned a while back.
Put the engine with zero degrees straight up, or mark the engine pulley at a point straight up.
Jack up only one side of the rear of the car.
Now make a mark on both the brake drum and the brake backing plate on the jacked up side.
Put the car into SECOND gear.
Now start turning the engine over until the brake drum makes exactly one full rotation. Count exactly how many turns of the engine pulley it takes to accomplish the full turn of the drum.
Exact turns of the crank:
4 = 3.88 gear ratio
4 1/4 = 4.125 gear ratio
4 1/2 = 4.375 gear ratio
Cool huh? I've tried it on a number of transmissions and it has been correct each time.
vwpilotbob
JOHN D
JOHN D is offline
PostPosted: Tue Jun 24, 2014 6:34 pm    Post subject: Reply with quote
It's easier to drain oil - pull bottom plug - mark a tooth on ring gear with paint - then count the teeth on Ring gear ---- 35 = 4.37 / 33 - 4.12 / 31 = 3.88 --- never wrong.
John
53 willys
53 willys is offline
PostPosted: Fri Jun 27, 2014 5:34 pm    Post subject: Reply with quote
What trans do I have if it's a D0 in a 65 swing axle notchback? I dont see this code in the list?
1965 Notchback type 1 conversion
Fltblkbaja
Fltblkbaja is offline
PostPosted: Thu Sep 11, 2014 7:36 pm    Post subject: Reply with quote
One question, I have a DC code gear box, is that bus or bug?
Everyone chops and drops,
We chop and lift!!!
vwpilotbob
PostPosted: Tue Oct 07, 2014 2:48 am    Post subject: 6 bolt 4.12 ring gear? Reply with quote
Can anyone tell me if all 4.12 ring gears are 8 bolt, or were some made with 6 bolts as well??
Thanks!
vwpilotbob
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Tue Oct 07, 2014 4:08 am    Post subject: Reply with quote
Used with 1500/1600cc from 8/68 in type 3 IRS
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
bluebeetle63
bluebeetle63 is offline
PostPosted: Sun Nov 30, 2014 10:42 pm    Post subject: Reply with quote
anyone ever use a 4.375 ring and pinion with 1.26 3rd and 0.82 4th, stock height tires and put about 100hp behind it? seems like it would have the good take off but be faster in the high gears, with still reasonable about of power.
The time will come when we as a people rise above and free ourselves from the oppression of the most cruel establishment ever known. The Department of Motor Vehicles.
bluebeetle63
PostPosted: Mon Dec 01, 2014 8:11 am    Post subject: Reply with quote
[quote="bluebeetle63"]anyone ever use a 4.375 ring and pinion with 1.26 3rd and 0.82 4th, stock height tires and put about 100hp behind it? seems like it would have the good take off but be faster in the high gears, with still reasonable amount of power.
vwpilotbob, I believe all 4.125 ring and pinions came with 8 bolts stock.
dustymojave
dustymojave is offline
PostPosted: Mon Dec 01, 2014 11:23 am    Post subject: Reply with quote
I've used TALLER offroad tires with a 4.37 diff and stock gear ratios and about 100hp. EZ to light up the rears on takeoff, but it was rather long between 2nd-3rd and 3rd-4th. The engine needs to have a fairly wide power band. Stock diameter rear tires are fine for pavement, but tend to be a drag offroad (as in "drag the bottom of the car on any little obstacle").
Richard
SoCalBajas Member
bluebeetle63
PostPosted: Mon Dec 01, 2014 7:09 pm    Post subject: Reply with quote
I'm building a daily driver and would like to keep stock tires in the rear. The reason for my questions is I like being able to get caught up to traffic quickly with the 4.375, but I would like better top speed. Top speed is fine with the 4.375 and stock gears, but I don't like how high it revs. I want to make the car have good mpg if I can. so if there are holes between 2-3 3-4 I'm still curious about the gears I mentioned. Anyone think there will be a hole between the gears?
Bajabrett
Bajabrett is offline
PostPosted: Tue Dec 02, 2014 10:56 pm    Post subject: Reply with quote
I guess that would help
ORANGECRUSHer
PostPosted: Wed Dec 03, 2014 5:17 am    Post subject: Reply with quote
then you'll need an actual trans code not a part number like you listed ^
Brian H.
Page 3 of 4
