BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1828 Location: Oregon
Posted: Mon Mar 14, 2016 9:24 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
TJs73Vert wrote: |
Thank you to everyone who has contributed to this thread!
Car is at painter now, but looking forward to reassembly of the windows but this thread will help a lot.
Question: source for #42 in this pic? Or a part number? I saw them on Chucks a few weeks ago but his site is down the last few days.
Thanks again!
Edit: found # = 141837563 now to find source |
I think most sites sell them but here's WW.
I got curious about Chuck and sent him an email. He told me he's working on a new site. No ETA but "stay tuned"
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=141837563 |
BWingate Samba Member
Posted: Sun Apr 17, 2016 11:59 am Post subject: |
djkeev wrote: |
Well well well...........
*Remove the single screw found below the rubber vent window seal, there is a hole in the seal allowing access without removing the seal, open the Vent window, you will find the hole.
(Screwdriver is in the hole to loosen the screw)......
So, I'm bringing this thread back from the dead a little bit.
I just picked up a '74 Super Beetle Convertible and the windows are aligned like cr@p and all the scrapers/seals are missing or in poor shape. New ones have been ordered.
This screw - it seems to be missing from one side and inaccessible from the other. What size is it and what does it screw into? Is this screw #19 from the Bentley picture on the first page? |
Posted: Sun Apr 17, 2016 12:13 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
I'm trying to align the driver's side windows on a '74 Super Beetle Convertible. I know one of the problems that is keeping me from getting good alignment is that all the scrapers are deteriorated or missing.
I'm assuming that the leading edge of the vent window is used to set the baseline of the window and that you try to align the tilt and height of the vent window to match the convertible frame. I think I have that close (its probable a little tight because it seems to hit the frame but no pix)
Next, I would align the roll-up window to track straight up and down relative to the track in the rear of the vent window, right? My problem is that the window is rolling up slightly faster than the rear, so I end up with the front of the roll-up window about 1/4 inch higher and back from the vent window:
I can push the rear of the window and the gap will close, but it opens as soon as the window moves.
And that of course pushes the rear of the window out of alignment:
This picture shows two of my alignment issues: the front and rear windows overlap - one of them needs to tilt either in or out.
But first things first: Which alignment adjustments would make the roll-up window track straight up-and-down?
I'm off to re-read this thread, stare at the windows and scratch my head.
Thanks,
Bruce.[/i] |
Posted: Sun Apr 17, 2016 2:21 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
A little review and some guesswork and I figured it out: The rear bolt in the image below is used to adjust the for and aft position of the roll-up window.
I loosened it up, shoved the window forward and tightened up back up and got this:
Not the best picture - sorry. The problem was not all with the adjustment of the windows - the seal between the front and rear windows was out of the track some, so I reset that, and everything works better with both windows rolled up just a little less than all the way up.
There are still some issues with the windows "flopping" in and out and with the height adjustment of the roll-up windows - I would like them to go all the way down easily and to lower the upper limit just a bit - but for now this is a 100% better than before. |
TJs73Vert Samba Member
Posted: Sun Apr 17, 2016 7:43 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
BWingate wrote: |
Thanks,
Bruce.[/i] |
Good job, Bruce. I'll be tackling this in a few days. I'm going into it blind myself, so i appreciate you coming back to report what worked for you here.
I just got mine back from the painter, 3 weeks late and full of mistakes. I just spen't the day troubleshooting light failures in the rear fenders where he cut n spliced the tail light harnesses. The splice was fine, but he pulled them and unplugged the connectors in the body wall. So fun reconnecting that!
Good luck with the rest of your work! |
Posted: Fri May 06, 2016 3:12 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Tips from my reassembly for future readers:
- If it's rusted, you'll probably be drilling out the screw in the vent wing. I repaired this by using a 1/4" square plastic insert and stainless steel #6 x1.25" threaded screw, like those typically used as license plate fasteners but smaller scale. The perfect one was in an assortment pack at Pep Boys. Choose the screw to match separately.
- I left the rear vertical track in, so reassembly was
1. Press on new inner scraper,
2. Insert regulator loosely,
3. Insert vent wing frame loosely,
4. Put window glass into tracks rear first,
5. Unbolt reg, engage to glass, rebolt reg (use window crank to help realign its bolts)
6. tighten all bolts,
7. install outer scraper (roll window all the way down, use #1 Phillips).
- A helper must hold the window while you line up the tracks then tighten the front two bolts, then the regulator studs, then the adjusting studs.
- Stainless steel #4 x.5" screws available at home depot replaced lost and rusted outer scraper screws nicely. Take one to compare.
- Adjusting stud frozen? Vent wing frame can be removed with stud in place, if you turn the assembly 90*, it will fit out the top of the door. Use a wood shim if necessary but mine fit right out.
- inner scrapers i pressed on the bottom, then stretched over the top, then pressed into top notch.
- I used Gold Bond medicated powder that comes in an AEROSOL CAN. Holy smokes easy peasy to apply powder when done. Look for it!
- If it's tight at the top, confirm there's countersunk screws holding the roof seals. Larger heads will cause bind.
One window is a little high at rear, the other a little low. But my adjusters are frozen so i trimmed the roof seals just a bit and it's a perfect fit. Good luck! |
bnam Samba Member
Joined: July 02, 2006 Posts: 3481 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Apr 02, 2017 7:45 am Post subject: |
I wanted to replace my left side window regulator as the part where the winder mounts is broken on mine and winder does not stay on.
I tried to follow the steps posted by Dave, but struggled as I could not get past step 1. The vent window would not come out up as it needs to be moved backward to pull up and out. But can't be moved back until the glass is removed.
I ended up removing and replacing the regulator without taking out the vent window.
The steps I took were
1. Unbolt/unscrew the vent window.
2. Unbolt the regulator and move it to disconnect it from the glass.
3. Remove the rubber trim at the top back of the door. Then unbolt the rear guide.
4. Now pull the glass up as high as possible. Tilt the vent window and pull up as well. Have a helper hold these
5. Drop the regulator to the bottom and pull out -- with the vent window up halfway, the regulator should be able to slide out underneath and out the main hole.
6. I inserted the replacement regulator and installed it loosely with 2 bolts.
7. Dropped the vent window back and loosely installed it.
8. Removed the regulator again. Dropped the glass and mounted the regulator to the bottom of the glass. Then remounted the regulator.
9. Pulled the glass back up and inserted rear guide making sure it slotted into the slot on the frame to the glass. Then pushed the glass down a bit and got the adjustment screw of the rear guide back in the hole/slot.
Now it was all back together and since I had marked the adjustment screw position earlier, I was able ore readjust easily and tighten.
While, the needed repair is done, I'm still unclear as to how to take the glass and the vent window completely out. The glass would not pull out as there is a ledge at the bottom that hits the rubber trim. But I don't think I can pull out the vent window without taking out the glass.
djkeev wrote: |
I'll add photos as I get a chance to take them.
Step 1.
(Refer to my photos at the beginning of this post)
*Remove the two plastic caps of the upper front edge of the door.
*Remove the two 10mm bolts in front of the vent window on the front edge of the door.
(Almost covered by the rubber weatherstripping, plastic caps are removed)....
*Remove the 13mm nut at the bottom of the vent window frame
(White arrow)
Lift the VENT WINDOW ASSEMBLY up out of the door. Be careful of tearing the rubber as you do so. You need temove the adjusting stud at the bottom so it clears the window slot easily, with it on, you'll fight (and probably fail) getting that vent assembly out! Don't bugger up the threads with vise grips or pliers when removing the double adjustment stud! They are often seized and will require some "love" to convince them to rotate.
In my experience, I leave the vent assembly loose in the door cavity giving space for the window to exit easily, I then pull the vent frame assembly out afterwards. Just let it drop down in after you remove the adjuster screw from the lower leg.
Step 2
A helper is handy here to hang onto the door glass preventing it from falling down into the door cavity. I often use a rubber coated wood clamp. A simple squeeze lever type....... Like one of these...... http://www.amazon.com/Irwin-Industrial-512QCN-Gene...oodworking
*Remove the 10mm bolts for the window regulator, there should be three of them, I've painted them white in the photo below..........(ignore the white arrow)
Dave |
mr matt Samba Member
Joined: May 26, 2005 Posts: 982 Location: southeast Pa
Posted: Sun Apr 02, 2017 2:04 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Sorry, I cannot help with the above problem, been many a years since I had to take one out, but it looks as if what Dave wrote is what I remember doing, so not sure what is wrong.
A problem with a new convert I have is it seems as if the driver window cannot be rolled up far enough. I adjusted the stop as much as possible and it still needs to go up a tad to be level with the frame ( the whole driver glass does have a tilt to it - working on that..)
Is it possible to lift the whole glass frame up about 1/2 - 3/4 inch or so? Can this be accomplished by loosening the lower left hand nut ( one with screw-driver slot in it) and loosening the one in the outer door jamb to lift the whole assembly up? Maybe this does not make sense... any input would be helpful.
Thanks!! |
bnam Samba Member
Posted: Sun Apr 02, 2017 5:36 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Is it hitting the stop on the regulator? |
Posted: Mon Apr 03, 2017 3:04 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
THanks, but yes it is. I lowered the bolt & nut and bottomed them out. Window was still low. I removed the nut and put it on the underside of the holder so I could lower the bolt even more. Window is even now, but the winder does not catch until I turn it about half way. Very strange.
Have not had time to work on it lately, but just wanted to put this out in case if anyone had the same issue.
Thanks for taking the time to reply. |
azamy66 Samba Member
Joined: September 10, 2003 Posts: 147 Location: Tempe, Arizona
Posted: Sun Jan 07, 2018 2:54 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
This thread is an awesome reference. I am almost finished reinstalling all my windows. The only ones left are the door windows. The mechanics are all in place, I just need to slide the windows down inside the door and adjust using your references. But first, I need to finish outfitting my windows with the new rubber seals and chrome. Ugh.
Any suggestions on replacing and reinstalling rubber window seals and chrome on the door windows? I tried placing the seals on the glass first and then tapped the chrome on after using silicone spray, but it didn't work well. Next I tried placing the seals inside the chrome first and then used silicone to try and ease them onto the window glass. That was difficult as well. Maybe I need to use a different agent to try and glide them on? Or maybe I should take them to an auto window specialist to do it for me? ha ha I'm so afraid that I am going to crack or break the windows if I try to force things.
Amy _________________ "Life is what happens when you are busy making other plans" ~ John Lennon
1965 Java Green Sedan
1868 Yukon Yellow Convertible
2012 Passat SEL Premium PZEV |
JoeyBagaDonutz Samba Member
Posted: Sun Jan 07, 2018 3:12 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Just finished putting the rubber seals on all my windows... I put the seals on the glass first holding them in place with a few random dabs of "3m black super weatherstrip adhesive". I let that set up overnight. Next day I put some glycerine on the seals and used bar clamps to push the seals into the chrome.
Once I got the hang of it on the first window the rest were a piece of cake.
The glycerine is the key.... good luck!
Joey _________________ 1967 Beetle Sedan
1971 Super Beetle Vert
1971 Karmann Ghia Vert |
Posted: Sun Jan 07, 2018 6:25 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Thanks! I will try the same. Where did you find the glycerine? _________________ "Life is what happens when you are busy making other plans" ~ John Lennon
Posted: Sun Jan 07, 2018 6:33 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
Sorry ! forgot to mention the glycerine (or glycerin) can be found at any
drugstore. I think it was about 2 bucks for a bottle..... _________________ 1967 Beetle Sedan
RichNJohn Samba Member
Joined: April 07, 2017 Posts: 91 Location: Palm Springs, CA
Posted: Tue Feb 27, 2018 7:18 am Post subject: Re: Convertible Door and Rear 1/4 Glass |
On my 72 the scrapers are new and they fit tightly to the glass. Problem is they are so tight that they grab the chrome trim on the top of the window and pull the glass out of the regulator track. Any suggestions other than stop rolling the windows all the way down? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33196 Location: Hot Arizona
Posted: Tue Feb 27, 2018 12:13 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
RichNJohn wrote: |
Use baby powder, talcum powder, or powdered starch on the rubber scraper part that contacts the glass. I had the same issue when I replaced my convertible's scrapers about 20 years ago. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Feb 27, 2018 1:28 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
What Cusser said.....
Eventually they will slide fine. _________________ 1967 Beetle Sedan
74Shovel Samba Member
Joined: October 18, 2017 Posts: 165 Location: Yakima, WA
Posted: Wed Feb 28, 2018 2:54 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
I made a short video about replacing the rear quarter window on a convertible Super Beetle, and posted it to YouTube. I'm not sure if I cover any ground that hasn't been covered in previous posts, but I thought I'd add the link just in case.
https://www.youtube.com/watch?v=KYhri5psYxE&t=101s |
stick Samba Member
Posted: Sat Mar 17, 2018 12:49 pm Post subject: Re: Convertible Door and Rear 1/4 Glass |
So glad this is out there! Putting the glass back in a 79 and I couldn’t adjust it enough. Seems I forgot about the sliding guide being a adjustment spot as well. |
johnpernock Samba Member
Posted: Thu Mar 05, 2020 4:28 am Post subject: Re: Convertible Door and Rear 1/4 Glass |
Sorry to resurrect an old thread but I’ve been stuck for a few days trying to get my glass out. Any tips for getting the regulator unhooked from the bottom of the glass? No matter what I try it seems to be 1/10” of an inch or less off from lining up with the holes. I’m not sure if I did something wrong? I’ve followed the steps to a T, since this is the only resource I’ve seen about the vert windows.
I’m just trying to put all new seals on the doors haha. |
