T3 hightop from Norway
Page: Previous  1, 2, 3
Italjohn
Italjohn is offline
PostPosted: Fri May 26, 2017 12:54 pm    Post subject: Re: T3 hightop from Norway Reply with quote
Here is how I did the front wheels.
Follow me on facebook: https://www.facebook.com/norwayvanagon
My youtube channel: https://www.youtube.com/c/Italjohn
Instagram: https://www.instagram.com/italjohn/
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
Italjohn
Italjohn is offline
PostPosted: Wed Jul 05, 2017 2:21 am    Post subject: Re: T3 hightop from Norway Reply with quote
My new fan and ceiling lights Very Happy
Both adjustable Cool
Italjohn
Italjohn is offline
PostPosted: Tue Nov 20, 2018 6:33 am    Post subject: Re: T3 hightop from Norway Reply with quote
Got my self one of those flame lamps Very Happy
Italjohn
Italjohn is offline
PostPosted: Tue Nov 20, 2018 6:38 am    Post subject: Re: T3 hightop from Norway Reply with quote
Blew up my JX engine this summer Crying or Very sad
So now I have taken the faulty engine out, AND installed the AAZ engine.
Which I did pick in pieces and recondition.
Here back in the car.
And got my self new wheels Very Happy
And a new fridge
And a new charger/battery option.
AC inlet with watt meter
joetiger Premium Member
joetiger is offline
PostPosted: Tue Nov 20, 2018 7:48 am    Post subject: Re: T3 hightop from Norway Reply with quote
Nice work!!
Does the cover fit over your battery or do you leave it open?
Joe T.
'02 Baja-ish Beetle "Bubbles"
Italjohn
Italjohn is offline
PostPosted: Tue Nov 20, 2018 7:51 am    Post subject: Re: T3 hightop from Norway Reply with quote
joetiger wrote:
Nice work!!
No it didn't fit, so I had to remove the cover.
I'm using a rubber mat for now.
Zeitgeist 13
Zeitgeist 13 is offline
Nice work as usual. What is the device attached to the ground post on your house battery?
Casey--
'01 Weekender --> full camper
y u rune klassik?
Italjohn
Italjohn is offline
PostPosted: Tue Nov 20, 2018 7:53 am    Post subject: Re: T3 hightop from Norway Reply with quote
Thats the shunt for the volt/ammeter, see post over this one Very Happy
[email protected]
ahmed.aboudan@gmail.com is offline
PostPosted: Tue Nov 20, 2018 8:22 am    Post subject: Re: T3 hightop from Norway Reply with quote
Does it record amp in and out? So if you are charging amps in, than discharging amp out so you can see difference?
Thanks
shagginwagon83
shagginwagon83 is online now
PostPosted: Tue Nov 20, 2018 8:32 am    Post subject: Re: T3 hightop from Norway Reply with quote
I'm pretty sure that a shunt - I don't think it will tell individual input/output - but I think it will show you the "combined" number.
For example if you are charging at 10 amps and using 5 amps - it would show 5 amp charging. Or vice versa - you're charging at 5 amps and using 10 amps, it would show -5amps discharging.
[email protected]
PostPosted: Tue Nov 20, 2018 9:00 am    Post subject: Re: T3 hightop from Norway Reply with quote
Thanks what I'm wondering if it reads total in total out. So let say battery empty then I would like to say total amps in lets say 100. Then I would like reader to tell me amps out So at about 90 I would know time to charge again.
tencentlife
tencentlife is offline
PostPosted: Tue Nov 20, 2018 11:09 am    Post subject: Re: T3 hightop from Norway Reply with quote
The words you're looking for are "Amp-hours" (Ah) and "net". Amps is the present amount of current flowing, amp-hours is that rate projected over time.
Multiply amps times volts and you have power, in watts. Multiply amp-hours times volts and you have energy, in watt-hours. Both are convertible to joules which is used in much of the world, a joule is one watt-second.
A single shunt will only allow measurement of the net charge or discharge amps, not amp-hours. So if there is 10A of incoming charge while there is a 2A load in use, the net charge would be the difference, 8A. Of course the 2A powering the load isn't coming from the battery at all, it's going directly to the load from the charging source and the remainder is charging the battery.
If you have an amp-hour meter it can use a shunt and its internal clock to calculate amp-hours. Most have an programmable efficiency factor as well to compensate for the fact that it takes more than one amp-hour charge to replenish an amp-hour of discharge, usually about 95% on a newish battery and slowly (hopefully slowly) decreasing to about 85% as the battery ages.
If you want to measure net battery charge/discharge and want to separately see load amps, a second shunt is needed. Some battery monitors allow monitoring of more than one shunt. But that would be total and unnecessary geekdom, a battery monitor and a single shunt will provide voltage, amperage, and net battery amp-hours in or out , and that's all the info you need to competently manage a battery.
Experience is death to doctrine.
[email protected]
PostPosted: Tue Nov 20, 2018 1:32 pm    Post subject: Re: T3 hightop from Norway Reply with quote
Ok thanks. So would this unit provide:battery monitor and a single shunt will provide voltage, amperage, and net battery amp-hours in or out , and that's all the info you need to competently manage a battery?
So from what I understand charging battery I would look at monitor and it would tell me when I got to 100 ah. Then turn off charger. Then as power is used monitor would reach 100 ah again the I would know time to plug charger back in.
Italjohn
Italjohn is offline
PostPosted: Thu Feb 10, 2022 6:50 am    Post subject: Re: T3 hightop from Norway Reply with quote
Got myself a new volt/ammeter
Italjohn
Italjohn is offline
PostPosted: Tue Jun 14, 2022 6:20 am    Post subject: Re: T3 hightop from Norway Reply with quote
My lithium battery setup
Gnarlodious
Gnarlodious is offline
PostPosted: Tue Jun 14, 2022 9:04 am    Post subject: Re: T3 hightop from Norway Reply with quote
Thanks for that, I’m considering a battery upgrade and this is a super trim install!
dhaavers
dhaavers is offline
PostPosted: Mon Sep 02, 2024 8:53 am    Post subject: Re: T3 hightop from Norway Reply with quote
Italjohn, I recall you posting about installing LED bulbs in your E-code headlights but I can’t find it.
Remind me please, or link to the post?
Embarassed
- Dave
"The WonderVan"
Page 3 of 3
